View Poll Results: Do you think to use this plugin ?
Voters
9. You may not vote on this poll
  • yes
    8 88.89%
  • no
    1 11.11%
Page 16 of 19 FirstFirst ... 678910111213141516171819 LastLast
Results 151 to 160 of 189
Thread: RRGoogleMapsTools for RideRunner
  1. #151
    Mar 2009
    I have to try with sygic
  2. #152
    Jan 2007
    The default visible layers on the map are traffic and Bicycle. I would like to change the default visible layers, but I have been unable to find a way to do this. Is it possible to define the default layers?
    Thanks!
  3. #153
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by mfolan View Post
    Thanks!
    No, but i can change the code for that ! What is your need ?
  4. #154
    Jan 2007
    Thanks for the quick reply.
    When using traffic and bike layers together, the traffic layer displays white lines on the road instead of the normal green lines. Turning off the bike layer allows the traffic layer to be displayed properly. (confirmed in carwings as well)
    Since I mainly use the plugin for traffic, I manually turn off the bike layer every time I start the skin.
    Ideally, I would love to see the default layers be configurable from the .ini. Having the traffic layer as the only default layer would also correct the traffic layer display.
    May 2008
    Bordeaux, France
    Thanks!
    That you can do is add into your exectbl.ini file:
    ClickInd;the layer indicator name
    The indicators are:
    gmaps_trafficlayer
    gmaps_bikelayer
    gmaps_weatherlayer
    gmaps_cloudlayer
    gmaps_panoramiolayer
    gmaps_transitlayer
    gmaps_fusionlayer
    gmaps_kmllayer
    gmaps_xmllayer
    The command use a toggle mode (ON/OFF)
    So try to add to your exectbl.ini file:
    "ONSCREENCHANGE","CLICKIND;gmaps_bikelayer",RRGoog leMapsTools.skin
  6. #156
    Jan 2007
    That works great. Thanks!
    I had to make only one minor change. I was getting an exception when starting the plugin (Error: The value of the property "bikeoff" is null or undefined not a functional object) since the plugin was not fully initialized before the CLICKIND command was sent. I just added a short WAIT, and everything is fine:
    "ONSCREENCHANGE","WAIT;2||CLICKIND;gmaps_bikelayer ",RRGoogleMapsTools.skin
    I appreciate your assistance. (and great plugin!)
  7. #157
    May 2008
    Bordeaux, France
    It's my pleasure , if you like it :-)
  8. #158
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    pierrotm777,
    can we use real GPS data to update the Gmaps position in real time? Also, the GMaps now is using waze info, can we do it here? My intention is use this plugin as my only gps software.
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  9. #159
    May 2008
    Bordeaux, France
    Quote Originally Posted by marteline View Post
    pierrotm777,
    What is waze info . Does exist an API ?
  10. #160
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Waze is a GPS software for android that gives real time traffic intel based on other users input. Nowadays waze is the best GPS on Brazil. But there is no API for PC, only android...
    Can your plugin also be used as a navigation software? I really want to replace iGO!
  1. RideRunner for Android?
    By upspace in forum Road Runner
    Last Post: 09-24-2014, 02:20 PM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. Riderunner and iGo8
    By dorrisdormouse in forum Road Runner
    Last Post: 02-16-2010, 08:21 AM
  4. Not able to exit RideRunner...??
    By arb004 in forum Road Runner
    Last Post: 01-04-2010, 11:44 AM
  5. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
