View Poll Results: Do you think to use this plugin ?
Voters
9. You may not vote on this poll
  • yes
    8 88.89%
  • no
    1 11.11%
Page 8 of 19 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 189
Thread: RRGoogleMapsTools for RideRunner
  1. #71
    Mar 2011
    Quote Originally Posted by pierrotm777 View Post
    This plugin can work alone , but if you 'ADD a marker' on the map's center and click on it , the plugin return the gps coordinates. So , you can send these coordinates to your navigator, sygic or pcnavigator, or gmpc. Just select your navigator into the settings , configure the Sygic settings ,run the navigator and after that only, use the button 'SEND TO SyGIc'.
    Think that the keysequence is very important to check :
    keysequence={F1}{ENTER}{RIGHT}{RIGHT}{DOWN}{ENTER} {ENTER}{LAT}{CLICK}{LON}{CLICK}{CLICK}
    Check this sequence manually and you must to go to the 'coordinates menu' .
    If this sequence is bad for you, change it !
    hello and thank you for having responded to me, I would like to understand one thing. This plugin uses as a basis for navigation map of Sygic?
    that is thanks to your plugin if I find a way not present in the display as it happens Sygic navigation? I see the indicator of road walking in a vacuum?
  2. #72
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I work on a new version that will be easier to use (code cleaned) !!!
    You want have this feature into this plugin or into sygic ?
  3. #73
    Mar 2011
    I would like to continue to use Sygic fleet is the only browser that is fine on my PC.
    but being that the maps are old 2011.03 I wanted to use your plugin.
    I asked for explanations about this
  4. #74
    May 2008
    Bordeaux, France
    This plugin is only for search a specific POI and send these coordinates to Sygic.
    But this plugin isn't a GPS navigator with its cool features !!!!
  5. #75
    Mar 2011
    so in conclusion .. if I'm on a road that Sygic does not know the car will walk in space
  6. #76
    May 2008
    Bordeaux, France
    Yes and return you that you are out off the road but not the plugin !
  7. #77
    May 2008
    Bordeaux, France
    Sorry, i thing that the plugin can return that in update mode (map's center is updated by your gps coordinates from RR), because when is unknow the position , it don't return an available address !!!
  8. #78
    Mar 2011
    thanks for having me cleared my doubts
    curiosity, satellite navigation software that you use?
    I used that Garmin has the ability to have updated maps, but I do not understand why it works in spurts. navigation is not smooth.
    and then when I make a curve with the arrow moves the car after I affront the curve and not in real time.
    you happen to know what could be the reason?
    well i have a pc with cpu and video card, antenna gps Holux slim 236 BT.
  9. #79
    May 2008
    Bordeaux, France
    Quote Originally Posted by Carlo201983 View Post
    Do you use a splitter for your GPS ?
    If not , you must ! http://www.curioustech.net/xport.html
  10. #80
    May 2008
    Bordeaux, France
    I think that a usb gps is a better solution ! I have no gps actually and use gpsgate simulator for my tests ?
  1. RideRunner for Android?
    By upspace in forum Road Runner
    Last Post: 09-24-2014, 02:20 PM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. Riderunner and iGo8
    By dorrisdormouse in forum Road Runner
    Last Post: 02-16-2010, 08:21 AM
  4. Not able to exit RideRunner...??
    By arb004 in forum Road Runner
    Last Post: 01-04-2010, 11:44 AM
  5. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
