View Poll Results: Do you think to use this plugin ?
Voters
9. You may not vote on this poll
  • yes
    8 88.89%
  • no
    1 11.11%
Page 9 of 19 FirstFirst 123456789101112131415161718 ... LastLast
Results 81 to 90 of 189
Thread: RRGoogleMapsTools for RideRunner
  1. #81
    Mar 2011
    Quote Originally Posted by pierrotm777 View Post
    Do you use a splitter for your GPS ?
    If not , you must ! http://www.curioustech.net/xport.html
    What do you mean by splitter? I have BT and GPS antenna on the Main Board a usb BT to communicate with the GPS antenna.
  2. #82
    Mar 2011
    I think that a usb gps is a better solution ! I have no gps actually and use gpsgate simulator for my tests ?
    and I know .. and only this Holux BT antenna is well made, I paid enough in its time. then you say that the problem could be the antenna?
    But even in the garmin simulation snaps.
  3. #83
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by Carlo201983 View Post
    You can't connect RR and an external gps to your Antenna in same time .
    You need a splitter that receive in input your antenna and in output create two virtual com port , one will be connected to RR and the other to your external gps software !
    Just setup well the com port !!!
  4. #84
    May 2008
    Bordeaux, France
    New version V2.1.4
    Code rewritten and simplified
    Simplify the use
    PS : This plugin freeze with DFX5 and other skin that use 'Visual Area' into their screens (menu.skin ...)
    For DFX5 comment the lines that follow:
    [Visual Area]
    /Z,14,7,772,121
  5. #85
    Mar 2011
    expect we're doing a bit of confusion. in RR CONFIG I have not set any Com port is set as external gps. Com port from the Windows partition. I do not understand is why I have to use a virtualization software com ports. : (Well if we knew both the Italian would understand us better. Forgive me but I use a translator.
  6. #86
    May 2008
    Bordeaux, France
    1-Look at the Gps services into RRConfig !
    Set com port to 15 (by example)
    Save/Exit
    2-Run Xport
    If your Gps antenna is ready, click 'Find GPS'.
    Under this button, if the indicator pass from red to green, it's OK.
    Select the com port found !
    Select good baud rate.
    On the right, select com 15 (for RR) and why not com 16 (for your gps)
    Click 'Enable port'
    3-Run RR
    Run Skintool , click on a label and add GPSLAT or GPSLON, click AutoUpdate.
    4-Run your Gps software and set for him the com port as com 16.
    With Xport, your share your antenna with several software without freeze !!!!
  7. #87
    Mar 2011
    Save/Exit
    2-Run Xport
    Click 'Enable port'
    3-Run RR
    Ok.thank, I will test in the afternoon
  8. #88
    Mar 2011
    Hello. I downloaded and set xport so.
    garmin works slightly better. But snaps anyway.
    here's the problem, look at this video.
  9. #89
    May 2008
    Bordeaux, France
    Computer has in general 4 com port : com1 to 4 so in xport try to define outport after 4 .
  10. #90
    Mar 2011
    I do not understand, in xport to ENABLE PORTS must select a port greater than 4?
    for example. 5 or 6 etc.?
  1. RideRunner for Android?
    By upspace in forum Road Runner
    Last Post: 09-24-2014, 02:20 PM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. Riderunner and iGo8
    By dorrisdormouse in forum Road Runner
    Last Post: 02-16-2010, 08:21 AM
  4. Not able to exit RideRunner...??
    By arb004 in forum Road Runner
    Last Post: 01-04-2010, 11:44 AM
  5. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
