Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 111 to 120 of 125
Thread: RRPandora plugin for RideRunner
  1. #111
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    sonic,
    Works great with the vis now when switching from pandora to webradio to music on all the skins that I use except,,, DFX.
    Visual window seems to not fully embed its self properly. I still see the border around window. I may have to mention this on the DFX thread.
    Cheers.
  2. #112
    Oct 2010
    Ok testing it. i will try and report back in a few days. Thank you for your help.
  3. #113
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by os12tr View Post
    you might want to hold off. I found the issue. When i feed winamp the next track and set it to play, winamp will play, but if the buffer isn't filled to a certain extent in one second it will instantly set winamps status to "stop", my plugin sees this, fires the next track.
    I'm going to setup a delay after the next track is started before the status timer which searches for winamps status starts again. Shouldnt impact song load times or anything, maybe just the tracktime labels and slider. Testing today
    Live mp3Car Facebook Chat
  4. #114
    Woodbridge, VA
    Blog Entries
    41
    Updated to 0.86 This should fix the skip issue. I also fixed a bug with Quick Mix, which would default back to an artist channel on next track.
  5. #115
    Oct 2010
    I was about to post that the skip is still there when I got home and noticed you found the issue. I will try this version and see how it goes. Thank you.
    Edit: I will try again in the morning to download the update. Autoapp store is down. Just a blank page.
  6. #116
    Woodbridge, VA
    Blog Entries
    41
    0.87 available as soon as autoappmart comes back online. I added a little more discernable information to the connection methods (instead of just reading "Connecting to Pandora"). I moved the time consuming process of getting the track from pandora to its own thread (should stop RR from freezing between tracks), and i did a little bit more work with Quick Mix playback.
  7. #117
    May 2007
    Quote Originally Posted by Sonicxtacy02 View Post
    Sonic,
    I believe the autoappmart is up and running now.
    Will you be uploaded soon, or do you still need to iron out more before releasing?
    Thanks bud.
  8. #118
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by RAWPWR View Post
    Sonic,
    Thanks bud.
    Sorry, bad week in the PC world. Lost my carPC SSD to who knows what, then in an attempt to partition a removable drive to install win7 via usb my development pc killed its own partition table.
    Didnt lose any created programs (thank goodness!), but it has taken quite awhile with data recovery to recapture the auxilliary stuff. I'll try to get the latest version uploaded today.
  9. #119
    May 2007
    Ouch!,
    .....Take all the time ya need to make it right.
    I'm in no hurry by any means. Just curious tis all.
  10. #120
    Woodbridge, VA
    Blog Entries
    41
    0.87 is up.
  1. How is this car called in the U.S. ?
    By kraft in forum Off Topic
    Last Post: 12-30-2010, 12:51 AM
  2. HAHAHA busted for the cable for the XM thing you guys worked SOOO hard on
    By jimmythecow in forum General Hardware Discussion
    Last Post: 10-15-2004, 11:53 AM
  3. Replies: 1
    Last Post: 02-19-2003, 08:29 AM
  4. What do you guys thing of this screen....
    By Mwilhelm100 in forum LCD/Display
    Last Post: 07-09-2002, 06:18 PM
