Page 4 of 13 FirstFirst 12345678910111213 LastLast
Results 31 to 40 of 127
Thread: RRPandora plugin for RideRunner
  1. #31
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I was about to vote for the DirectX till ya double posted hehe. The ONLY reason is that I did not want a 3rd instance of Winamp running, the internal one for RR, the external one you use for Shoutcast, and possibly this being a 3rd instance for Pandora.
    My Fiero Build Thread
  2. #32
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by JohnWPB View Post
    Yea thats the only downside as far as i can see. I can add a setting to completely hide the winamp instance though. New version out shortly
    Live mp3Car Facebook Chat
  3. #33
    Woodbridge, VA
    Blog Entries
    53
    0.6.0 is now on App Mart! This is the most complete build thus far so download it and give it a go.
    This version uses winamp as mentioned, and shows/hides winamp instance based on the HIDEPLAYER configuration setting in RR.ini.
    There is also a new user setting called SkipOnHate. Set this setting to true if you wish Pandora to skip the currently playing track when you "hate" it (thumbsdown). The default for this setting is false, so old settings.xml files will still work.
  4. #34
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    I am testing the Pandora plugin right now and am having problems. It keeps crashing RR and the RRPANDORA command does not work. Is anyone else having this problem?
    I have narrowed it down to the plugin because it only crashes after I install it.
    RR Build 2-27-12 / Win 7 64
  5. #35
    Woodbridge, VA
    Blog Entries
    53
    Which build of RRPandora? Try the latest version I posted today
    Sent from my Transformer TF101 using Tapatalk
  6. #36
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    I was trying the new release
    v 0.6.0
  7. #37
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by suavecito View Post
    v 0.6.0
    Show me your rrpandora_debug.txt file. Its in the plugin data folder. Do you have winamp installed?
  8. #38
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    There is no rrpandora_debug.txt available becuase I am not even able to run it (checked the appdata folder and rr plugin folder). I Went back and tried it on Win 7 32bit / RR 2-5-12 and it has crashed. It may just be a 64bit problem.
    I check the RR Live Debug Log and all a got was:
    ''COMMAND NOT EXECUTED: RRPANDORA"
    I tried using it with Winamp 2.95, 5.13, 5.54 and the newest.
  9. #39
    Woodbridge, VA
    Blog Entries
    53
    I must have messed up a dependency. Ill do a bit of troubleshooting and send a fix shortly
  10. #40
    Woodbridge, VA
    Blog Entries
    53
    0.6.1 on App Mart now. That should fix the issue you have suavecito, i removed the directshow reference files but still initiated them in code. No longer an issue. 0.6.1 will also add the new SkipOnHate setting to your settings file should it not already exist (if your settings file was created prior to 0.6.0)
  1. How is this car called in the U.S. ?
    By kraft in forum Off Topic
    Last Post: 12-30-2010, 12:51 AM
  2. HAHAHA busted for the cable for the XM thing you guys worked SOOO hard on
    By jimmythecow in forum General Hardware Discussion
    Last Post: 10-15-2004, 11:53 AM
  3. Replies: 1
    Last Post: 02-19-2003, 08:29 AM
  4. What do you guys thing of this screen....
    By Mwilhelm100 in forum LCD/Display
    Last Post: 07-09-2002, 06:18 PM
