Hoof,
This is a realy gret plugin that run very well for me with the SkipOnHate setting.
I use a proxy because i live in France !
He Madonna !!!
Printable View
Hoof,
He Madonna !!!
Sonic,
Superb plug my friend!
Works fantastic, just a little tweaking here and there with the RRSkin editor for the labels etc. (1280x800 test pc).
Thanks bud. :)
RRPandora has been updated to 0.6.6. Fixes include a new resume at rr start/resume routine (requires RR ver 3/8/12+), various bug fixes and stability improvements. Mixer now works with pandora and winamp. RRPandora is now an "official" RR custom source in regard to activesource handling. This version is also compliant with the new Dynamic menu system for RR (again, version 3/8/12 or up). Everyone should download this release as it promotes a better pandora experience as a whole.
aaaand 0.6.7 is out. Quick fix to a playback bug i introduced in the last build. I also added a nifty little feature for the create station osk. Instead of having to delete the line in the osk everytime you want to add a station, just being typing (via the osk) the station name and that line will automatically clear.
0.6.9 available with improved resume support.
I'd love to be able to use this plugin, but when I try to run it I always get an "Object reference not set to an instance of an object." error in the debug log and the plugin never loads my station list. I added my user id and password through the setting screen as required. Full debug log is below if it helps, I'm using the latest RR release.
Code:3/23/2012 3:55:48 PM-->Debug mode setting found. Debug set to True
3/23/2012 3:55:48 PM-->Username setting found. Username set to myemail@somewhere.com
3/23/2012 3:55:48 PM-->Password found and decrypted
3/23/2012 3:55:48 PM-->SkipOnHate setting found. SkipOnHate set to False
3/23/2012 3:55:48 PM-->Last Station ID setting found. LastStationID is
3/23/2012 3:55:48 PM-->Settings Loaded
3/23/2012 3:55:48 PM-->Winamp Started
3/23/2012 3:55:48 PM-->Winamp Initialized
3/23/2012 3:55:48 PM-->Winamp Ready
3/23/2012 3:55:48 PM-->Pandora audio format set
3/23/2012 3:55:48 PM-->Authorization handler initiated
3/23/2012 3:55:48 PM-->Connection handler initiated
3/23/2012 3:55:48 PM-->album client handler initiated
3/23/2012 3:55:48 PM-->Image handler initiated
3/23/2012 3:55:48 PM-->Status timer initiated
3/23/2012 3:55:48 PM-->ONLINE Command executed
3/23/2012 3:55:48 PM-->ONSOURCECHANGE Command executed
3/23/2012 3:55:52 PM-->RRPANDORA command executed
3/23/2012 3:55:53 PM-->------> RRPandora method SourceActive run with parameter of False
3/23/2012 3:55:53 PM-->------> RRPandora method SourceActive run with parameter of True
3/23/2012 3:55:53 PM-->ONSOURCECHANGE Command executed
3/23/2012 3:55:53 PM-->Object reference not set to an instance of an object.
3/23/2012 3:55:54 PM-->Object reference not set to an instance of an object.
3/23/2012 3:55:55 PM-->Object reference not set to an instance of an object.
3/23/2012 3:55:56 PM-->Object reference not set to an instance of an object.
3/23/2012 3:55:57 PM-->Object reference not set to an instance of an object.
3/23/2012 3:55:58 PM-->Object reference not set to an instance of an object.
3/23/2012 3:55:59 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:00 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:02 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:03 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:04 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:05 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:06 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:07 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:08 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:09 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:10 PM-->Object reference not set to an instance of an object.
3/23/2012 3:56:11 PM-->Object reference not set to an instance of an object.
Try the latest build 0.7.1 it should fix your issue. 0.7.1 should also work with winamp visuals too. Simply use the VISU command like normal.
With the plugin finally working for me I noticed a few things on the elite 2 skin didn't work so I sorted out the additions and thought I'd outline them here for anyone else that would like to make them. Most of them boil down to not having a definition for RRPandora's ACTIVESOURCEID of 10.
1. No Track/Artist info in top bar
FIX:
Edit "Top-round.elite" found in eLite 2\elite\static and change:
toCode:L,175,2,450,28,255,255,255,16,"#FONTFAMILY#","BYVAR;ACTIVESOURCEID;=<<TAGTITLE||= - ||TAGARTIST<<RDSTEXT<<TAGTITLE||= - ||TAGARTIST<<TAGTITLE||= - ||TAGARTIST<<TAGTITLE<<=Video File<<TRACKNAME<<","SCROLL-CENTER",,"DS=1,2,0,0,0"
L,246,34,305,24,#FONTTHEMER#,#FONTTHEMEG#,#FONTTHEMEB#,14,"#FONTFAMILY#","BYVAR;ACTIVESOURCEID;=<<FREQUENCE||= ||FMAM||= - ||RDSNAME<<FREQUENCE||= ||FMAM||= - ||RDSNAME<<TAGTRACKNUMBER||= - ||TAGALBUM<<TAGTRACKNUMBER||= - ||TAGALBUM<<TAGARTIST<<TRACKTIME<<TRACKTIME<<","SCROLL-CENTER",,"DS=1,2,0,0,0"
2. Skip forward and back do not workCode:L,175,2,450,28,255,255,255,16,"#FONTFAMILY#","BYVAR;ACTIVESOURCEID;=<<TAGTITLE||= - ||TAGARTIST<<RDSTEXT<<TAGTITLE||= - ||TAGARTIST<<TAGTITLE||= - ||TAGARTIST<<TAGTITLE<<=Video File<<TRACKNAME<< << <<TAGTITLE","SCROLL-CENTER",,"DS=1,2,0,0,0"
L,246,34,305,24,#FONTTHEMER#,#FONTTHEMEG#,#FONTTHEMEB#,14,"#FONTFAMILY#","BYVAR;ACTIVESOURCEID;=<<FREQUENCE||= ||FMAM||= - ||RDSNAME<<FREQUENCE||= ||FMAM||= - ||RDSNAME<<TAGTRACKNUMBER||= - ||TAGALBUM<<TAGTRACKNUMBER||= - ||TAGALBUM<<TAGARTIST<<TRACKTIME<<TRACKTIME<< << <<TAGARTIST","SCROLL-CENTER",,"DS=1,2,0,0,0"
FIX:
Edit "Static.elite" in eLite 2\elite\static and change:
toCode:B,268,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tunedown<<tunedown<<prev<<prev<<prev<<prev<<prev)",@BYVARX;ACTIVESOURCEID;(<<prev<<prev<<prev<<prev<<FRWD<<PREVTRACK<<PREVTRACK)@
B,356,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tune<<tune<<tune<<tune<<play<<play<<play)",
B,444,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tuneup<<tuneup<<next<<next<<next<<next<<next)",@BYVARX;ACTIVESOURCEID;(<<next<<next<<next<<next<<FFWD<<NEXTTRACK<<NEXTTRACK)@
3. No play/pause buttonCode:B,268,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tunedown<<tunedown<<prev<<prev<<prev<<prev<<prev<< << <<prev)",@BYVARX;ACTIVESOURCEID;(<<prev<<prev<<prev<<prev<<FRWD<<PREVTRACK<<PREVTRACK<< << <<PREVTRACK)@
B,356,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tune<<tune<<tune<<tune<<play<<play<<play<< << <<play)",
B,444,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tuneup<<tuneup<<next<<next<<next<<next<<next<< << <<next)",@BYVARX;ACTIVESOURCEID;(<<next<<next<<next<<next<<FFWD<<NEXTTRACK<<NEXTTRACK<< << <<NEXTTRACK)@
FIX:
Duplicate a play_xx.png image in eLite 2\icons\players\controls\ and rename to play_10.png
After these changes you should see track info in the top pane and all transport controls on the bottom should function as intended.
Thanks again Sonic for a great plugin!
as per originally promised long ago, this project is at the point i feel comfortable uploading to CodePlex. So go ahead, peek into the code and tease me for my poor programming habits:)
https://rrpandora.codeplex.com/
