Page 7 of 13 FirstFirst 12345678910111213 LastLast
Results 61 to 70 of 127
Thread: RRPandora plugin for RideRunner
  1. #61
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by VegasGuy View Post
    Raises an interesting question: Since these apps are emulating the desktop/web app, WHY don't they get the higher quality stream? From the Pandora server's point of view, it's just another browser connection. In fact, since 3rd-party Pandora apps aren't "officially" recognized, the only way this (and the Centrafuse app and the apps they are based on) will work is by pretending to be a web browser. So again, why not the higher/lower quality streams?
    VegasGuy
    Beats me. Is there a way to see what the web page quality option passes to the player? Perhaps we just aren't passing the correct parameter.
    Sent from my Transformer TF101 using Tapatalk
    Live mp3Car Facebook Chat
  2. #62
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Quote Originally Posted by Sonicxtacy02 View Post
    I'll ask around with the PandoraMediaBox author and see what he says. I swear I hear a difference in the truck between the mobile and HQ settings...but on my dev box I'm not so sure. I have to remember that Pandora is not streaming media in the same sense that Shoutcast or TuneIn radio is. The data stream you receive will arrive at whatever your max available bandwidth is, regardless of the quality setting. The only way to determine if you got a 64,128 or 192kbps file is to compare the amount of data received, not how fast it arrived.
    I'll report back if I hear anything definitive.
    Cheers!
    VegasGuy
  3. #63
    Oct 2010
    I found a bug. I keep getting an error message about daily limit reached and to upgrade to pandora premium. I already have pandora one, how do I get the error message to stop?
  4. #64
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by os12tr View Post
    Well what were you doing to GET the message? that message can only occur if your sending requests to pandora's server. So more than likely you were either adding a channel, listening for a long time (several hours, pandora requires you to keep the stream "awake"), or pressing play/pause a lot causing the stream to become invalid? Send me the debug log (found in %MYDOCUMENTS%RideRunner\Plugins\RRPandora).
  5. #65
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Sonic, I found another problem.
    When adding / creating a new station the keyboard skin comes up and says "Enter the name of an artist or a song", the problem occurs when you try to clear out the text using "CLEARTEXT" command (not available in the current elite 2 alpha keyboard).
    It gives you a Microsoft .NET Framework error. I can get around the current problem by using the "Backspace" command for now.
    Code:
    See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentOutOfRangeException: Index and length must refer to a location within the string.
    Parameter name: length
       at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
       at System.String.Substring(Int32 startIndex, Int32 length)
       at RRPandora.RRExtension.OSKTextResetTimer_Tick(Object sender, EventArgs e)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400)
        CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    HDRadioRR
        Assembly Version: 1.0.0.1
        Win32 Version: 1.0.0.1
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/RadioModules/HDRadio/HDRadioRR.DLL
    System
        Win32 Version: 2.0.50727.5453 (Win7SP1GDR.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    HDRadioComm
        Assembly Version: 1.6.0.3
        Win32 Version: 1.6.0.3
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/RadioModules/HDRadio/HDRadioComm.DLL
    XMComm
        Assembly Version: 1.4.0.1
        Win32 Version: 1.4.0.1
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/MJS%20Gadgets/XMRadio/XMComm.DLL
    System.Xml
        Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    VistaMixer
        Assembly Version: 1.1.0.0
        Win32 Version: 1.1.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/VistaMixerControl/VistaMixer.DLL
    CoreAudioApi
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/VistaMixerControl/CoreAudioApi.DLL
    MobilePhone
        Assembly Version: 1.17.4070.39887
        Win32 Version: 1.17.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/plugins/Mobilephone.NET/MobilePhone.DLL
    ATSMS
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/plugins/Mobilephone.NET/ATSMS.DLL
    Microsoft.VisualBasic
        Assembly Version: 8.0.0.0
        Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System.Web
        Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    BSWrapper
        Assembly Version: 0.0.0.0
        Win32 Version:
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/plugins/Mobilephone.NET/BSWrapper.dll
    msvcm90
        Assembly Version: 9.0.30729.6161
        Win32 Version: 9.00.30729.6161
        CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
        Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    RRPandora
        Assembly Version: 0.7.1.0
        Win32 Version: 0.7.1.0
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/Plugins/RRPandora/RRPandora.DLL
    PandoraMusicBox.Engine
        Assembly Version: 1.1.4.155
        Win32 Version: 1.1.4.155
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/Plugins/RRPandora/PandoraMusicBox.Engine.DLL
    RRWebRadio
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/Plugins/RRWebRadio/RRWebRadio.DLL
    WinampProxy
        Win32 Version: 0.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/RideRunner/Plugins/RRWebRadio/WinampProxy.DLL
    System.Configuration
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    Accessibility
        Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  6. #66
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by suavecito View Post
    Code:
    mscorlib
    HDRadioRR
    System
    HDRadioComm
    XMComm
    System.Xml
    VistaMixer
    CoreAudioApi
    MobilePhone
    ATSMS
    System.Web
    BSWrapper
        Win32 Version:
    msvcm90
    System.Drawing
    RRPandora
    RRWebRadio
    WinampProxy
    Accessibility
    enabled.
    For example:
    <configuration>
    </configuration>
    I will correct the error, but there is no need to cleartext. Simply use the osk to enter the search criteria and the header message will disappear.
  7. #67
    Woodbridge, VA
    Blog Entries
    55
    Just to reiterate what the documents says for people creating skins for this plugin, you must run the command RRPANDORA to initialize the plugin and get your music playing. Just loading the skin file wont start playback. Get several PMs per week asking this question so hopefully this will help alleviate issues.
  8. #68
    Woodbridge, VA
    Blog Entries
    55
    0.7.4 is up and fixes the osk if user uses CLEARTEXT or otherwise modifies OSK text outside of using the OSK buttons.
  9. #69
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    I'd like that thank you for open sourcing the library. Justin wrote our Pandora pluign before but when he disappeared so did the code as he had never checked it in. I have debated converting other people's libraries in the past but have never done it. Having a common library that everyone on mp3car is using is awesome.
  10. #70
    Woodbridge, VA
    Blog Entries
    55
    yea doing that was bit of a learning experience for me, having never used Git before. I will be uploading a new build sometime this week, though it will have only very minor changes. Everything appears to be working for now.
  1. How is this car called in the U.S. ?
    By kraft in forum Off Topic
    Last Post: 12-30-2010, 01:51 AM
  2. HAHAHA busted for the cable for the XM thing you guys worked SOOO hard on
    By jimmythecow in forum General Hardware Discussion
    Last Post: 10-15-2004, 12:53 PM
  3. Replies: 1
    Last Post: 02-19-2003, 09:29 AM
  4. What do you guys thing of this screen....
    By Mwilhelm100 in forum LCD/Display
    Last Post: 07-09-2002, 07:18 PM
