View Poll Results: Do you think to use this interface ?
Voters
3. You may not vote on this poll
  • yes
    3 100.00%
  • no
    0 0%
Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 68
Thread: Pc_Navigator 12 Free command by TCP/IP interface
  1. #11
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by harryberlin View Post
    Hello
    i use the IBUSCommunicatoRR Plugin for BMW. i get a lot of variables from the BMW IBus.
    http://www.mp3car.com/rr-plugins-in-...17-2011-a.html
    is it posible to use these variables for navigation?
    $IBusCommunicatoRR_LATITUDE$ : Current Latitude in Degrees, Minutes and Seconds
    $IBusCommunicatoRR_LONGITUDE$ : Current Longitude in Degrees, Minutes and Seconds
    could your plugin send the current position from ibus to pc navigator?
    If your Latitude and Longitude are into two variables, i think that it's possible !
    The commands and labels are:
    [Commands]
    RRPCNAVI_GPSTONAVIGATOR send the latitude and longitude to Pc Navigator defined by =$GPSLATCLIP$ and =$GPSLONCLIP$
    RRPCNAVI_GPSTONAVIGATOR;YOURLAT;YOURLON send directly your latitude and longitude
    RRPCNAVI_STATISTICS returns distance (in meters) or time (in seconds) to destination and nearest waypoint
    RRPCNAVI_STOPNAVIGATION stop the navigation
    RRPCNAVI_LASTPOSITION get last known gps data
    [LABELS]
    RRPCNAVI_RETURN the info returned by Pc Navigator
    So, you can try:
    RRPCNAVI_GPSTONAVIGATOR;$IBusCommunicatoRR_LATITUD E$;$IBusCommunicatoRR_LONGITUDE$
    If this command don't run, i can work on it !
  2. #12
    May 2008
    Bordeaux, France
    Can you try the 1.0.1 version is say me if the plugin does what you need ?
  3. #13
    Sep 2012
    Germany - Munich
    hi
    does it curently send these vars to pc navigator, or only by command from button?
    sorry, at the moment i can't test it, because my car is far away.
    on weekend, i try to get die real varible-code. then i can try by generating positions.
  4. #14
    May 2008
    Bordeaux, France
    You can send vars or use a button with your vars !
  5. #15
    Sep 2012
    Germany - Munich
    small misstake, i did mean:
    does it autom. constant comparing the position from "IBUS-VAR" to PC Nav.?
  6. #16
    May 2008
    Bordeaux, France
    Sorry , my english is very bad !
    I don't understand your question !
  7. #17
    Sep 2012
    Germany - Munich
    i don't want to touch any button every second, to get the current position to PC Nav.
    works it automaticly? or is anything to do, that the command run?
    how often does get PC Nav. the gps-position?
  8. #18
    May 2008
    Bordeaux, France
    You can try the command RRPCNAVI_LASTPOSITION into a timer and read the label RRPCNAVI_RETURN , but the result isn't easy to read .
    I can work on that !
  9. #19
    May 2008
    Bordeaux, France
    I have added several labels and commands :
    Added the possibility to have variables as LATITUDE and LONGITUDE:
    RRPCNAVI_GPSTONAVIGATOR;$YOURLAT$;$YOURLON$
    New labels for LATITUDE, LONGITUDE, ALTITUDE, SPEED (in km/h) and HEADING .
    Code:
    [Commands]
    RRPCNAVI_UPDATELATLON_START	run the latitude and longitude labels update
    RRPCNAVI_UPDATELATLON_STOP	stop the latitude and longitude labels update
    [LABELS]
    RRPCNAVI_LATITUDE		return the LATITUDE from PC Navigator
    RRPCNAVI_LONGITUDE		return the LONGITUDE from PC Navigator
    RRPCNAVI_ALTITUDE		return the ALTITUDE from PC Navigator
    RRPCNAVI_SPEED			return the SPEED (in km/h) from PC Navigator
    RRPCNAVI_HDG			return the HEADING(in degrees) from PC Navigator
  10. #20
    Sep 2012
    Germany - Munich
    i viewed some old logs of ibus.
    now, i send this message to ibus
    IBusCommunicatoRR;sendtoibus;7F 14 C8 A2 01 00 47 22 27 20 00 11 34 10 90 04 77 00 12 27 55 DB
    and get these vars:
    IBusCommunicatoRR_LATITUDE=47 22' 27.2'' N
    IBusCommunicatoRR_LONGITUDE=11 34' 10.9'' E
    (also see screenshot)
    at the moment testing with pc navigator is unpossible. first i have to create the skin.
  1. Orderd Sirius Satalite USB interface but recived a HD radio interface
    By tech180 in forum MP3Car Products - store.mp3car.com
    Last Post: 12-07-2011, 03:38 PM
  2. Replies: 3
    Last Post: 11-07-2011, 05:24 AM
  3. LIST Command: Riderunner or skin command?
    By blazinlow in forum Road Runner
    Last Post: 10-23-2011, 02:28 PM
  4. Replies: 7
    Last Post: 07-28-2011, 09:52 PM
  5. Replies: 14
    Last Post: 10-11-2010, 03:44 PM
