View Poll Results: Do you think to use this interface ?
Voters
2. You may not vote on this poll
  • yes
    2 100.00%
  • no
    0 0%
Results 21 to 30 of 39
Thread: Pc_Navigator 12 Free command by TCP/IP interface
  1. #21
    MySQL Error
    Oct 2004
    Quote Originally Posted by pierrotm777 View Post
    I have added several labels and commands :
    Added the possibility to have variables as LATITUDE and LONGITUDE:
    RRPCNAVI_GPSTONAVIGATOR;$YOURLAT$;$YOURLON$
    New labels for LATITUDE, LONGITUDE, ALTITUDE, SPEED (in km/h) and HEADING .
    Code:
    [Commands]
    RRPCNAVI_GPSTONAVIGATOR		send the latitude and longitude to Pc Navigator defined by =$GPSLATCLIP$ and =$GPSLONCLIP$
    RRPCNAVI_GPSTONAVIGATOR;YOURLAT;YOURLON    send directly your latitude and longitude
    RRPCNAVI_STATISTICS		returns distance (in meters) or time (in seconds) to destination and nearest waypoint
    RRPCNAVI_STOPNAVIGATION		stop the navigation
    RRPCNAVI_LASTPOSITION		get last known gps data
    RRPCNAVI_UPDATELATLON_START	run the latitude and longitude labels update
    RRPCNAVI_UPDATELATLON_STOP	stop the latitude and longitude labels update
    [LABELS]
    RRPCNAVI_RETURN			the info returned by Pc Navigator
    RRPCNAVI_LATITUDE		return the LATITUDE from PC Navigator
    RRPCNAVI_LONGITUDE		return the LONGITUDE from PC Navigator
    RRPCNAVI_ALTITUDE		return the ALTITUDE from PC Navigator
    RRPCNAVI_SPEED			return the SPEED (in km/h) from PC Navigator
    RRPCNAVI_HDG			return the HEADING(in degrees) from PC Navigator
    i frown on misuse prefix RR
    that is "reserved" for RideRunner
    as you should notice any "NEW" RR command, is always prefixed with RR
    PCNAVI_xxxx
    would have been good enough
    keep this in mind please
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by harryberlin View Post
    i viewed some old logs of ibus.
    now, i send this message to ibus
    IBusCommunicatoRR;sendtoibus;7F 14 C8 A2 01 00 47 22 27 20 00 11 34 10 90 04 77 00 12 27 55 DB
    and get these vars:
    IBusCommunicatoRR_LATITUDE=47º 22' 27.2'' N
    IBusCommunicatoRR_LONGITUDE=11º 34' 10.9'' E
    (also see screenshot)
    at the moment testing with pc navigator is unpossible. first i have to create the skin.
    Attachment 68217
    I see that the latitude and longitude haven't the good format for my plugin.
    If you can convert it into the RR format , that would be a good thing :-)
  3. #23
    May 2008
    Bordeaux, France
    Quote Originally Posted by mitchjs View Post
    PCNAVI_xxxx
    Sorry for this same error. It's solved with the 1.0.2 version !
  4. #24
    Sep 2012
    Germany - Munich
    i can convert it with the calculator, but can't integreate in the plugin.
    my programmingknowledge is very bad. and i don't have the sourcecode of Ibus-plugin.
  5. #25
    May 2008
    Bordeaux, France
    Ok,
    I shall see if i can to integrate that convertion into this plugin !
  6. #26
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    PCNAVI_xxxx
    Frown all you like mitch, but you are far too late to hijack the rr prefix on commands.
    Many, if not most, plugins including all mine use rr as the prefix for their commands.
    changing that now would be quite a lot of work and break most skins.
    as long as the rr is directly followed by the plugin name (or shortened version of) it should not be a problem.
  7. #27
    May 2008
    Bordeaux, France
    Ok,
    You can test this new little plugin !!!
    GPS convert for RR
  8. #28
    MySQL Error
    Oct 2004
    Quote Originally Posted by Enforcer View Post
    i have no plans to enforce it... i have said it many times before...
    commands/variables/indicators/sliders etc, starting with RR are RESERVED for RideRunner itself
    please do not use in your own plugins
    RRxxx_xxxx
    is ok
    as RR should never use _
    but xxxx_yyyyy would be preferred
    example
    WebRadio_Play
    is all you need
    RRWebRadio_Play
    is redundant
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #29
    MySQL Error
    Oct 2004
    thanks!
    its really to prevent collisions of commands/inds/lables...etc, if i add something to RR
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #30
    Sep 2012
    Germany - Munich
    now i tested the navigator plugin. it's not possible to send coordinats to PC Navigator. or i don't know how it could work.
    pc navigator probably needs a com-port gps-mouse.
    but, i found on ebay a modul, where i can connect my car installed gps-cable.
    the converting plugin works fine.
    and the command: PCNAVI_GPSTONAVIGATOR;$YOURLAT$;$YOURLON$ does not work. i get always an error.
  1. Orderd Sirius Satalite USB interface but recived a HD radio interface
    By tech180 in forum MP3Car Products - store.mp3car.com
    Last Post: 12-07-2011, 02:38 PM
  2. Replies: 3
    Last Post: 11-07-2011, 04:24 AM
  3. LIST Command: Riderunner or skin command?
    By blazinlow in forum Road Runner
    Last Post: 10-23-2011, 01:28 PM
  4. Replies: 7
    Last Post: 07-28-2011, 08:52 PM
  5. Replies: 14
    Last Post: 10-11-2010, 02:44 PM
