View Poll Results: Do you think to use this plugin ?
Voters
4. You may not vote on this poll
  • yes
    4 100.00%
  • no
    0 0%
Results 1 to 10 of 13
Thread: Garmin Mobile Pc Plugin
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Wink Garmin Mobile Pc Plugin
    That does a long time that i try to create an interface between Garmin Mobile Pc and RR.
    A SDK exist but i am not enough strong in VB.NET for that !
    So, i had use the send key method and that run very well .
    You just need to very your size window settings !
    By example, for a with ~ 600 the sequence for acces to the 'Gps Position menu' is :
    keysequence={ESC}{F11}{DOWN 4}{ENTER}
    (see the RRGmPc.ini file)
    But, if your screen is greater you must to adapt this sequence .
    You can use the keys:
    LEFT,RIGHT,UP,DOWN and begin always by {ESC}{F11} and finish by {ENTER} .
    Version 5.00.70 only:
    But the plugin run very well
    History:
    V1.1.0 16/06/2011
    This release run only with the GMPC 5.00.70 version
    You need to update your .ini file with the version that you have:
    [RRGmPc]
    language=english
    gmpcversion=5.00.70
    windowclass=CDP_FIELD_WND
    V1.0.0 04/06/2011
    First release (run only with GMPC < or = 5.00.60)
    Attached Files Attached Files
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I'm confused, GMPC already embeds fine and there's a script somewhere on this forum to allow the volume to be handled by RR, What does this plugin do?
    Live mp3Car Facebook Chat
    May 2008
    Bordeaux, France
    The main use of this plugin is to convert gps coordinates in the GmPc format N or S DD MM.MMMM (Degrees Minutes).
    The script that already exist can just send a sequence of keys !
    This plugin does the two !
    May 2008
    Bordeaux, France
    Little update .Please re-download if you use this plugin !
    May 2008
    Bordeaux, France
    This plugin run now with only the 5.00.70 GmPc version .
    First post is updated !!!
    Oct 2006
    Instruction
    How do install this in DFX skin. I keep getting "RRgmpc skin missing error" Thanks.
    May 2008
    Bordeaux, France
    Quote Originally Posted by mrbombastic View Post
    The good way is:
    C:\Program Files\Ride Runner\Plugins\RRGmPc\
    or if you use the profile option:
    C:\Documents and Settings\UserName\Mes documents\RideRunner\
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    Garmin SDK is not really working so I can say it only exist to transfer certain data such s start guidance to specific address
    We developed Rebellium plugin for Centrafuse but not much active on that development any more, if any one needs help we can share sources with reliable developer for RR to integrate garmin with same features we did in CF
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
    May 2008
    Bordeaux, France
    Quote Originally Posted by tempgp View Post
    This is a good idea ! Can you send me message please ?
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    I've not tried Garmin but would if I could get some current UK maps....
    I'm glad there is still effort in keeping RR alive
    Vauxhall Astra SXi Car PC installed.
  1. Plugin to integrate Garmin Mobile PC into Centrafuse
    By Rogoflap in forum Garmin Mobile PC
    Last Post: 02-08-2011, 01:50 AM
  2. Garmin Mobile PC
    By ptk in forum Garmin Mobile PC
    Last Post: 08-27-2009, 05:05 PM
  3. Garmin mobile pc plugin request
    By BIGGKATT01 in forum CF Plugins
    Last Post: 08-01-2009, 08:06 AM
  4. Need help with RR and Garmin mobile pc
    By viagra in forum Road Runner
    Last Post: 05-26-2008, 05:55 AM
  5. Garmin Mobile PC
    By Bivio in forum GPS
    Last Post: 04-12-2008, 08:11 PM
