View Poll Results: Do you think to use this plugin ?
Voters
0. You may not vote on this poll
  • Yes
    0 0%
  • No
    0 0%
Results 1 to 10 of 10
Thread: RRTranslator (Yandex Translator)
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Talking RRTranslator (Yandex Translator)
    This is my last plugin for RideRunner . It's written for the first time (for me) with C# 2010 and need the Framework 3.5 .
    The result is very cool and Unicode .
    Translator's Language:
    Moneys converter:
    It is compatible with my RR plugin RRGmail (that already run very well) !
    It is compatible with my RR plugin BT MobilePhone (version 1.1.7.1 is needed !)
    You can select a text with the clipboard and use it as text to translate !
    You just need to obtain your Yandex key .
    How to use the new version:
    If you use the old version, delete the ini file !!!
    Run one time RR and quit RR.
    Edit the ini file and add your Yandex key !
    Run RR .
    Two modes:
    In 'Free mode' you need to change the from and to languages, and can save them with the' Update' button! (Free mode); Use the 'Update' button.
    In 'Detect Auto mode' , the language than you want traduce is automatically detected ; you can just select the final language; 'Use the 'Update' button.
    Attached Files Attached Files
    May 2008
    Bordeaux, France
    New installer for this plugin . (thanks to mitchjs)
    May 2008
    Bordeaux, France
    New version as soon as possible with the converter of moneys !!!
    May 2008
    Bordeaux, France
    For several months, the money don't run because the webservice used is down !
    Now , i use the Yahoo API !
    See first post !!!
    May 2008
    Bordeaux, France
    New version with Money issues solved:
    Three new commands:
    RR_TRANSLATOR_MONEYSELECT select the money into a list
    RR_TRANSLATOR_MONEYRESET read the money from the ini file
    RR_TRANSLATOR_MONEYSAVE save the money into the ini file
    May 2008
    Bordeaux, France
    Venezuelan bolivar issue is now solved !!!
    May 2008
    Bordeaux, France
    For guys who use this plugin (nobody is think !), the translator don't run in this actual version because , now the Google Translate API isn't free.
    It's why i have rewritten the code and now use the Yandex Translate API .
    You just need to obtain a key .
    Run RR .
    Two modes:
    See first post for the new version !!!
    Aug 2007
    pierro my good friend , thanks for again have the translate plugin working , I would not do it without your help
    May 2008
    Bordeaux, France
    Quote Originally Posted by mikeeps2 View Post
    Thanks to you !
    May 2008
    Bordeaux, France
    Version 1.0.6 is out !
    Very minor changes !
  1. RRTranslator
    By pierrotm777 in forum RR Plugins
    Last Post: 01-23-2011, 05:11 AM
  2. Need Finnish Translator
    By veetid in forum Centrafuse
    Last Post: 07-18-2007, 11:50 AM
  3. Google-Earth in VW by Google plus VW Front-end
    By MacMobile in forum MacCar
    Last Post: 03-28-2006, 03:38 AM
  4. Found LCD, need korean translator :)
    By marenko in forum LCD/Display
    Last Post: 11-14-2005, 05:18 PM
  5. Replies: 44
    Last Post: 04-07-2005, 09:05 AM
