I have updated the installer ! Please uninstall the plugin before and reinstall with the new installer (see the first post)
Yes
No
I have seen that i have some issues with my plugin's installer and the profile mode !
Can you see if your plugin is well into the folder C:\Program Files\RideRunner\Plugins\RRGmail and not C:\Users\username\Documents\RideRunner ?
I think that my issue is into the install that don't accept well the profile mode:
This is a part of the installer:
Code:[Files] ; NOTE: Don't use "Flags: ignoreversion" on any shared system files Source: RRGmail.dll; DestDir: {app}; Flags: ignoreversion Source: Google.GData.Client.dll; DestDir: {app}; Flags: ignoreversion Source: Google.GData.Contacts.dll; DestDir: {app}; Flags: ignoreversion Source: Google.GData.Extensions.dll; DestDir: {app}; Flags: ignoreversion Source: Newtonsoft.Json.dll; DestDir: {app}; Flags: ignoreversion Source: RRGmail.ini; Destdir: {code:DataPath}\Plugins\{#RRExtPluginName}; Flags: ignoreversion Source: Languages.txt; Destdir: {code:DataPath}\Plugins\{#RRExtPluginName}; Flags: ignoreversion Source: Profiles.txt; Destdir: {code:DataPath}\Plugins\{#RRExtPluginName}; Flags: ignoreversion Source: RRGmail Skin Commands.txt; DestDir: {app}; Flags: ignoreversion isreadme
Unfortunately the new installer still didnt make the plugin appear in the plugin manger.
It has however installed all the files into my RR folder in My Docs instead of the program files (which i understand was the point of the installer)
I got the error message from trying to manually register the dlls:
RegSvr32
The module "C:\Users\Cav\Documents\RideRunner...\RRGmail. dll" was loaded but the entry-point DllRegisterServer was not found.
Make sure that "C:\Users\Cav\Documents\RideRunner...\RRGmail. dll" is a valid DLL or OCX file and then try again.
Many thanks for the effort though - Thanks to guys like you that make this such an awesome program![]()
