View Poll Results: Do you think to use it
Voters
4. You may not vote on this poll
  • yes
    4 100.00%
  • no
    0 0%
Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 75
Like Tree2Likes
Thread: OBDXR - OBDII .NET for RideRunner
  1. #11
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    I'm running March RR as of late lastnight. Had January RR installed on my trip home lastnight. Never had these crashes until I installed OBDXR plugin.
    It works fine on my work and home PC, but they don't have any OBD readers connected. Possibly a little more delay is needed before activating the plugin on start?
    Going to update my skin in the car and change the units variable to see how everything works on my trip home again.
    Wasn't sure if that mismatch flash error was why I couldn't get the gauges to work, but the units variable makes sense.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  2. #12
    Sep 2012
    Germany - Munich
    ok, the flashfiles work with RR since Dec 2012.
    yes, you must deactivate the units. the flashfiles only need the numbers.
  3. #13
    Oct 2008
    Ontario, Canada
    Well the gauges now work... but I really need to get a new OBD scanner - this Elmscan 5 just isn't cutting it anymore.
    Still get crashes at startup and exit.
    I also have an issue with resuming. My PC is a laptop, which goes to standby when I turn the car off. The past 2 times I've started the car and RR resumes, everything is frozen... until I start to move/drive.
    It seems like OBDXR is holding the system hostage until it gets some movement data. I only waited about 3 minutes before moving the car, but in that time RR was frozen. Tonight was on the main menu screen, so not relating to the OBDscreen.
  4. #14
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    16/08/2013 V1.0.4
    Solved an issue around the colour's slider that configure the flash colours objects .
    Added a skin for Reborn
    See the first post !
  5. #15
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    I still have the issue in reborn skin where I dont see any text , please let me know how to fix this.
    here is what I see:
    Name:  settingobdxr issue.jpg
    View my worklog here
  6. #16
    May 2008
    Bordeaux, France
    I have forgotten the file COLOR.txt !
    Create a text file with:
    /DEFINE color 255,0,0
  7. #17
    May 2008
    Bordeaux, France
    First post is updated !!!
  8. #18
    Aug 2010
    thanks , I have done the update , and I changed the obdxrosk.skin so the labels are in the proper position.
    Also , when I try to set the color for the gauges in settings to red (255) the gauges remain black
    Attached Files Attached Files
  9. #19
    May 2008
    Bordeaux, France
    Quote Originally Posted by eugenweij View Post
    Uninstall your plugin and install the last version (do a backup before)
  10. #20
    Aug 2010
    please add the version of the obdxrosk.skin I uploaded to the installer, the current version has the labels in the wrong place.
    other than that , fantastic work
    also, your installer changes my menu buttons , I see you copied your exectbl.ini to the installer, now my RR version is changed to the way you have set it up , when I install this in the car I dont want my exectbl.ini to change, except the items needed to make obdxr work.
  1. windows8+riderunner
    By anuchit in forum Road Runner
    Last Post: 01-14-2014, 03:12 AM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
  4. riderunner phone help
    By danchappers in forum Road Runner
    Last Post: 05-17-2009, 03:28 AM
  5. Few Questions about RideRunner
    By flatproblem in forum Road Runner
    Last Post: 03-25-2009, 05:51 PM
