View Poll Results: Do you think to use it
Voters
4. You may not vote on this poll
  • yes
    4 100.00%
  • no
    0 0%
Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 75
Like Tree2Likes
Thread: OBDXR - OBDII .NET for RideRunner
  1. #21
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by eugenweij View Post
    please add the version of the obdxrosk.skin I uploaded to the installer, the current version has the labels in the wrong place.
    other than that , fantastic work
    also, your installer changes my menu buttons , I see you copied your exectbl.ini to the installer, now my RR version is changed to the way you have set it up , when I install this in the car I dont want my exectbl.ini to change, except the items needed to make obdxr work.
    The oskxr.skin is uncompleted ! See the Carwings exemple please !
    I will delete the exectbl.ini and the menu.ini file for the las installer
  2. #22
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    yes , when I posted the skin files I said it was by no means complete, I will complete the skins asap
    edit:
    I finished the skin , also made a folder with lines to add to the menu.ini to make flash files work
    Attached Files Attached Files
    View my worklog here
  3. #23
    Aug 2010
    okay , I installed it in the car , flash files seem to work , rest of the skin seems to work , only issue is that the plugin doesnt seem to get the data from the comport.
    I have checked my comport traffic and it is receiving and sending , my obd reader also works with dashcommand on my phone.
    I am using a bluetooth obd reader connected through bluesoleil , which created a virtual comport for my device
    I looked up the debug, this is what I find:
    19:12:36.352: Executing: LOAD;OBDXR_FLASH1.SKIN
    19:12:36.570: SKIN ERROR (AddFlash)--->Type mismatch
    19:12:36.625: SKIN ERROR (AddFlash)--->Type mismatch
    19:12:36.680: SKIN ERROR (AddFlash)--->Type mismatch
    19:12:36.734: SKIN ERROR (AddFlash)--->Type mismatch
    19:12:36.789: SKIN ERROR (AddFlash)--->Type mismatch
    19:12:36.844: SKIN ERROR (AddFlash)--->Type mismatch
    these I get from obdxr debug:
    8/18/2013 1:56:31 PM-->OBD Interface connected to COM7 38400
    8/18/2013 1:56:31 PM-->OBD Interface Error :
    8/18/2013 1:58:27 PM-->OBD Interface connected to COM7 38400
    8/18/2013 1:58:34 PM-->pfuel --> 0
    8/18/2013 1:58:34 PM-->Trip Fuel Used --> 0
    8/18/2013 1:58:34 PM-->obdxr_avgcount --> 161
    Then I try a different baud rate ( my reader supports both 9600 and 38400 baud rate)
    8/18/2013 7:10:11 PM-->OBD Interface connected to COM7 9600
    8/18/2013 7:10:20 PM-->pfuel --> 0
    8/18/2013 7:10:20 PM-->Trip Fuel Used --> 0
    8/18/2013 7:10:20 PM-->obdxr_avgcount --> 160
    all options I try I see no pid values , all counters remain at 0 except obdxr avg count
    last entry it is:
    8/18/2013 7:22:26 PM-->obdxr_avgcount --> 23367
  4. #24
    Aug 2010
    and I updated some skin files, now the flash files fit better and obdxr.skin had volume slider
  5. #25
    May 2012
    Grandville, MI
    So are the gauges done with flash or .net VB?
    I ask because I am looking to make some gauges like that and I would love to see how the graphics worked out.. Not sure if I will be writing mine in C# or what yet but I am making a digital dash to replace my dash cluster and something like this would be killer.
  6. #26
    May 2008
    Bordeaux, France
    last entry it is:
    I think you can test a baud rate <= 9600 !!!
    And check you .ini file with mine !
    NB:
    If you have a Gps connected you must have GPS=True into your .ini and GPS=False if you haven't !
  7. #27
    May 2008
    Bordeaux, France
    Quote Originally Posted by redheadedrod View Post
    They are done in flash !
  8. #28
    May 2008
    Bordeaux, France
    Thanks for this work ;-) !!!
  9. #29
    Aug 2010
    gonna set my ini straight with yours I have some stuff set to true , and baud 9600 has same results so far
  10. #30
    May 2008
    Bordeaux, France
    What OS do you have ?
  1. windows8+riderunner
    By anuchit in forum Road Runner
    Last Post: 01-14-2014, 03:12 AM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
  4. riderunner phone help
    By danchappers in forum Road Runner
    Last Post: 05-17-2009, 03:28 AM
  5. Few Questions about RideRunner
    By flatproblem in forum Road Runner
    Last Post: 03-25-2009, 05:51 PM
