View Poll Results: Do you think to use it
Voters
4. You may not vote on this poll
  • yes
    4 100.00%
  • no
    0 0%
Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 75
Like Tree2Likes
Thread: OBDXR - OBDII .NET for RideRunner
  1. #31
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    windows embedded 7 32bit
    View my worklog here
  2. #32
    Aug 2010
    I tried the settings , no result , I thin I am going to buy an obd scanner with usb , I think the issue is somewhere in bluesoleil.
  3. #33
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    can you test with obdsimulator ?
    You need to create a virtual com port with com0com !!!
  4. #34
    Aug 2010
    obdsimulator doesnt want to work in embedded, I have found an issue that is related to the embedded image I have , I guess I need to install normal win7
  5. #35
    May 2008
    Bordeaux, France
    Quote Originally Posted by eugenweij View Post
    obdsimulator doesnt want to work in embedded, i have found an issue that is related to the embedded image i have , i guess i need to install normal win7
    ha ha ... :-(
  6. #36
    Sep 2012
    Germany - Munich
    Quote Originally Posted by redheadedrod View Post
    So are the gauges done with flash or .net VB?
    I ask because I am looking to make some gauges like that and I would love to see how the graphics worked out.. Not sure if I will be writing mine in C# or what yet but I am making a digital dash to replace my dash cluster and something like this would be killer.
    the gauges were created with adobe flash CS5.5. Code is AS2. the graphics were designed with corel draw.
    in the flash exist just one frame. the needle turns by script. no other frames are needed.
  7. #37
    Jan 2006
    Dublin, Ireland
    I have installed this plugin on an XP SP3 machine and RR hangs when loading this plugin. If I remove RROBDXR from the plugins folder, RR loads perfectly. Below is what is recorded in the Debug File. Despite what it says, it can't be fully loaded since when removed, RR loads OK
    WITH
    18:18:37.141: Plugin Manager: loading Global Plugins...
    18:18:37.234: Plugin Manager: Plugin Found: MobilePhone(.NET)
    18:18:37.234: Plugin Manager: Plugin loaded (Global): MobilePhone
    18:18:38.750: Plugin Manager: Plugin Found: RRObdXR(.NET)
    18:18:38.750: Plugin Manager: Plugin loaded (Global): RRObdXR
    WITHOUT
    20:22:25.094: Plugin Manager: loading Global Plugins...
    20:22:25.297: Plugin Manager: Plugin Found: MobilePhone(.NET)
    20:22:25.313: Plugin Manager: Plugin loaded (Global): MobilePhone
    20:22:27.125: Plugin Manager: Plugin Found: RRTrafficCam
    20:22:27.125: Plugin Manager: Plugin loaded (Global): RRTrafficCam
    20:22:30.797: Plugin Manager: Plugin Found: SkinTool
    20:22:30.797: Plugin Manager: Plugin loaded (Global): SkinTool
    20:22:30.813: Plugin Manager: Plugin Found: Weather
    20:22:30.813: Plugin Manager: Plugin loaded (Global): Weather
    20:22:30.828: Plugin Manager: loading Global Plugins Completed.
    Any ideas ?
  8. #38
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Hey Pierrotm777, what about we try again on the PID-31 issues? I was wondering if you can just provide the "PID-31 as a VAR" and I provide a Script to read it and write back the obdxr_ovrdst and obdxr_trpdst values on the RRObdXR.INI.
    And by "PID-31 as a VAR" i mean that old version, when it used to show those 2 different values... I handle the selection on the script. What about that?
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  9. #39
    May 2008
    Bordeaux, France
    Quote Originally Posted by marteline View Post
    The var exist already as OBDXR_DTDTC !
    Do your script and i shall convert it into the plugin after that !
  10. #40
    May 2008
    Bordeaux, France
    Quote Originally Posted by championc View Post
    WITH
    WITHOUT
    Any ideas ?
    I don't understand why !
    I haven't issue with other plugins!
    What is your .ini file ? What com port do you use ? Can you unload mobilephone ?
  1. windows8+riderunner
    By anuchit in forum Road Runner
    Last Post: 01-14-2014, 03:12 AM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
  4. riderunner phone help
    By danchappers in forum Road Runner
    Last Post: 05-17-2009, 03:28 AM
  5. Few Questions about RideRunner
    By flatproblem in forum Road Runner
    Last Post: 03-25-2009, 05:51 PM
