View Poll Results: Do you think to use it
Voters
4. You may not vote on this poll
  • yes
    4 100.00%
  • no
    0 0%
Page 1 of 8 12345678 LastLast
Results 1 to 10 of 75
Like Tree2Likes
Thread: OBDXR - OBDII .NET for RideRunner
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I wanted to play with the OBD value and for help marteline that have issue with the OBDMPG by mezz64, i have rewritten this plugin for the Framework .NET 3.5 .
    I must to say a great thank to :
    - marteline that helped me as beta tester
    - harry-berlin for its very nice flash files!
    Main screen:
    Settings screen 1:
    Settings screen 2:
    Flash screen METRIC vresion:
    Flash screen no METRIC version:
    Differences betwwen the plugins OMPG and RROBDXR:
    Written in VB.ET 3.5
    Full settings on two screens
    Dynamics menu compatible
    New PIDs added (asked by marteline)
    If you want to use the FLASH files:
    "UNITS" - Set to True to display the units after the value ( Put this setting to 'False' if you want to use the FLASH swf files !!!).
    History:
    24/10/2015 V1.0.6
    Run on start changes !!!
    Hope resume is solved !!!
    19/10/2015 V1.0.5
    Change variables type for better compatibility
    16/08/2013 V1.0.4
    Solved an issue around the colour's slider that configure the flash colours objects .
    Settings screens are updated.
    Added a skin for Reborn
    21/02/2013 V1.0.1
    Add units for RPM , FRP, RTP and AAT
    20/02/2013 V1.0.0
    First Version
    Attached Files Attached Files
    DigitalVampire and sargeants like this.
    Sep 2012
    Germany - Munich
    very nice
    if i get some time, i'm going to make analog indicators in flash, like this:
    http://www.mp3car.com/attachments/rr...011-bmw_ai.png
    tell me which parameters do you think are good to use.
    May 2008
    Bordeaux, France
    Quote Originally Posted by harryberlin View Post
    very nice
    Fantastic idea !
    I think that would be a cool idea to create one swf file by value ! So each user use the swf that he want !
    I thank that each label can to have his flash file but it's a big job !
    [LABELS]
    Generic PID Functions: Code:
    PID 04 - Calculated Engine Load Value % - "obdxr_celv"
    PID 05 - Engine Coolant Temp degC - "obdxr_ect"
    PID 06 - Short Term Fuel % Trim Bank 1 - "obdxr_stft1"
    PID 07 - Long Term Fuel % Trim Bank 1 - "obdxr_ltft1"
    PID 08 - Short Term Fuel % Trim Bank 2 - "obdxr_stft2"
    PID 09 - Long Term Fuel % Trim Bank 2 - "obdxr_ltft2"
    PID 0A - Fuel Pressure kPa- "obdxr_fp"
    PID 0B - Intake Manifold Pressure - "obdxr_map"
    PID 0C - Engine RPM - "obdxr_rpm"
    PID 0D - Vehicle Speed (kmh or mph)- "obdxr_vss"
    PID 0F - Intake Air Temp degC - "obdxr_iat"
    PID 10 - MAF air flow rate g/s - "obdxr_maf"
    PID 11 - Throttle Position % - "obdxr_tp"
    PID 22 - Fuel Rail Pressure kPa - "obdxr_frp"
    PID 45 - Relative Throttle Position % - "obdxr_rtp"
    PID 46 - Ambiant Air Temperature degC - "obdxr_aat"
    PID 21 - DISTANCE TRAVELED MIL "obdxr_dtmil"
    PID 31 - DISTANCE TRAVELED DTC "obdxr_dtdtc"
    PID 42 - Control module voltage "obdxr_cmv"
    PID 44 - FUEL/AIR RATIO "obdxr_far"
    [MPG Calculation Functions]
    Instant Fuel Efficiency - "obdxr_insfe"
    Trip Fuel Efficiency - "obdxr_trpfe"
    Overall Average Fuel Efficiency - "obdxr_avgfe"
    X Minute Average Fuel Efficiency - "obdxr_davgfe"
    Distance Traveled Overall - "obdxr_ovrdst"
    Distance Remaining (Based on Tank size) - "obdxr_dstrem"
    Distance Traveled Trip - "obdxr_trpdst"
    Overall Fuel Used - "obdxr_ovrfuel"
    Trip Fuel Used - "obdxr_trpfuel"
    For more detail, please read the RRObdXR Skin Commands.txt file
    May 2008
    Bordeaux, France
    very nice
    I should like to know with what software you create this flash file and how you write that !
    If you have an example !
    For understand how to create it i have downloaded Flash Decompiler Trillix but i don't how to create one file !
    May 2008
    Bordeaux, France
    Little update , please see the first post !
    May 2008
    Bordeaux, France
    See first post for a new version with new flash gadgets . Great thanks to harry-berlin for these flash files !
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    THANK YOU!!
    I do believe I'm going to install this in the car tonight.
    Now to tweak my skin to let it work nicely.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    May 2008
    Bordeaux, France
    Quote Originally Posted by sargeants View Post
    THANK YOU!!
    Cool, Say me if RR crash sometime .
    Oct 2008
    Ontario, Canada
    Okay, here are my findings and issues.
    Crashes - yes, but only when either starting or exiting RR... or if I 'click' on the connector indicator(sometimes crashes). If it crashes on starting, it's within 10 seconds - even with doing nothing. Winamp continues to run in the background, so a simple re-launch of RR brings everything backup.
    - Distance calculation WITHOUT GPS is WAAAy off - this was the same with OBDMPG. Travel 10kms, only records as ~1.5 - guessing, but it's a large difference like that. Turning the GPS back on and it reads distance accurately.
    - Flash gauges don't work - in either my skin or Carwings. I created a button in Carwings to get to that screen... not sure if they're supposed to work yet. The speedo tries to work, but is constantly jumping from 0 up to try and reach my speed, but then back to 0. The VSS readout is proper in text form.
    - I set my VE to something in the 70-90 range (don't know what mine is - help?) - but then going back and checking, it's showing up as 54.xxxx. Not sure if this is something in my config or how it's supposed to work. I have a MAP car, not MAF, so I've turned the MAF setting to false.
    Some bits from my RRdebug:
    08:31:17.566: Executing: LOAD;OBDXR.SKIN
    08:31:17.848: SKIN ERROR (AddFlash)--->Type mismatch
    08:31:17.871: SKIN ERROR (AddFlash)--->Type mismatch
    08:31:17.895: SKIN ERROR (AddFlash)--->Type mismatch
    08:31:17.920: SKIN ERROR (AddFlash)--->Type mismatch
    08:31:17.941: SKIN ERROR (AddFlash)--->Type mismatch
    08:31:17.963: SKIN ERROR (AddFlash)--->Type mismatch
    This is the code in the skin file:
    [Labels]
    L,0,0,0,0,,,,,,"obdxr_vss",
    L,0,0,0,0,,,,,,"obdxr_rpm",
    L,0,0,0,0,,,,,,"obdxr_ect",
    L,0,0,0,0,,,,,,"obdxr_cmv",
    [Flash]
    F,3,338,136,136,"Flash/OBDXR_TANK_Scene1.swf"
    F,135,354,250,243,"Flash/OBDXR_RPM.swf"
    F,383,354,250,243,"Flash/OBDXR_VSS_KMH.swf"
    F,629,338,136,136,"Flash/CLOCK4.swf"
    F,3,477,136,136,"Flash/OBDXR_CMV.swf"
    F,629,477,136,136,"Flash/OBDXR_ECT_C.swf"
    I will send you a link to my debug file from lastnight and this morning - though doesn't seem to have the times where I have RRdebug logs from. I can go back out to the car and see about another debug file being created.
    Sep 2012
    Germany - Munich
    i had seen the skin error too. but don't know what the problem is. and RR crashs only with the OBDXR-Plugin.
    maybe we should ask mitchjs about this error.
    gets RR an error with other falsh-files also?
    edit:
    i tested some other SWF from iGO2009 Skin and get the same error.
    @sargeants
    which RR Version do you have?
  1. windows8+riderunner
    By anuchit in forum Road Runner
    Last Post: 01-14-2014, 03:12 AM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
  4. riderunner phone help
    By danchappers in forum Road Runner
    Last Post: 05-17-2009, 03:28 AM
  5. Few Questions about RideRunner
    By flatproblem in forum Road Runner
    Last Post: 03-25-2009, 05:51 PM
