Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: IBusCommunicatoRR (pt2) [Update Dec30 2013]
    Sep 2012
    Germany - Munich
    Hi People
    I was in contact with JanneH0. And we decided that i will continue the Development of his great I-Bus Plugin.
    Why new Thread? Because it's difficult to add changes in his Thread. So i started an own. I tested the new Version in my Car 5er E39 with IKE High and 16:9 MK4 Navigation.
    The old Thread is here: http://www.mp3car.com/rr-released-pl...29-2013-a.html
    Please tell me, when you have trouble with the new Version.
    Some information about PDC IBusmsg via Diagnostic:
    SET PDC-ON : 3F 04 60 0C 80 D7
    SET PDC-OFF: 3F 04 60 0C 40 17
    My adds since Version Dec17 2011:
    Oct 29 2013 Update
    Added setting to ini file: load/save obc values,
    Added setting to show/hide units of obc values
    Added IbusCommunicatoRR.log to log some Strings
    Updated IbusCommunicatoRR;sendtoibus (now it works without Checksum)
    Updated increased the Ibus IDs up to 300
    Updated ReplyMsgID function
    Updated ReadMe.txt
    Updated Text Scrolling function
    Updated Sample Skin
    Added new Variables:
    $IBusCommunicatoRR_ARRIVAL$
    $IBusCommunicatoRR_LIMIT$
    $IBusCommunicatoRR_OBCTIMER1$
    $IBusCommunicatoRR_OBCTIMER2$
    $IBusCommunicatoRR_STOPWATCH$
    $IBusCommunicatoRR_IBUSCLOCK$
    $IBusCommunicatoRR_IBUSDATE$
    $IBusCommunicatoRR_NETWORK$
    $IBusCommunicatoRR_LANG$
    $IBusCommunicatoRR_DISTUNIT$
    $IBusCommunicatoRR_SPDUNIT$
    $IBusCommunicatoRR_TEMPUNIT$
    $IBusCommunicatoRR_CLKFM$
    $IBusCommunicatoRR_CNSUNIT$
    $IBusCommunicatoRR_MOTOR$
    Added new CMDs to
    -Set Distance
    -Set Speedlimit
    -Set Timer 1 or 2
    -Call a Phonenumber
    -OBC Request
    -Set OBC IKE Units/Formats
    Added new INDs:
    !IbusCommunicatoRR_LIMIT
    !IBusCommunicatoRR_MEMO
    !IBusCommunicatoRR_AUXHEAT
    !IBusCommunicatoRR_TIMER1
    !IBusCommunicatoRR_TIMER2
    Nov20 2013 Update
    Added CMDs when you turn your Key
    IBUSCOMMUNICATORR_IGN_OFF
    IBUSCOMMUNICATORR_IGN_ACC
    IBUSCOMMUNICATORR_IGN_ON
    IBUSCOMMUNICATORR_IGN_START
    Added CMD IbusCommunicatoRR;PDCSCROFF : Stops the PDC-Request-Timer and exit the pdc.skin
    Added Function if you drive faster than 30km/h or 18mph, the PDC-Request-Timer stops and exit the pdc.skin
    Updated ReadMe.txt
    Nov23 2013 Update
    fixed some Bugs
    updated Sample Skin
    Updated ReadMe.txt
    Nov25 2013 Update
    added/updated real AUX Heat Indicator
    !IBusCommunicatoRR_AUXVENT:B : State of AUX Ventilation LED (BLINK / OFF)
    !IBusCommunicatoRR_AUXHEAT:B : State of AUX Heating LED (BLINK / OFF)
    Dec24 2013 Update hoo hoo hooooooo
    added new CMD to tune a frequenz directly on radio: ex. IbusCommunicatoRR;FM;96,3
    added new errorscreen when exist a com-port error on RR start
    updated ReadMe.txt
    updated un-/register.cmd for all windows ( XP --> 8 )
    Dec30 2013 Update
    bugfix about the ignition commands
    Next Steps
    Add a Videofield for Rearcam on PDC.SKIN <-- not possible
    maybe add CD Status for the other Typ of CD-Changer
    Optimize Flash Gauges
    Sample Skin, Flash Gauges seperated to next Post
    Attached Files Attached Files
    Sep 2012
    Germany - Munich
    The Sample Skin got new CMD-Buttons, Indicators, Label and 3 Flashgauges(for F and mph in progress)
    Found out a nice workaround to get tranparent background for osk "textbox". The textbox is hidden outside the viewing area. The text you can see is a label. Negativ side is, you can't see and change the cursor position.
    You can add this Lines to Menu.lst
    Code:
    IBus1           = "LOAD;IbusCommunicatoRR.skin",IBus1,
    IBus2           = "LOAD;IbusCommunicatoRR2.skin",IBus2,
    IBus3           = "LOAD;IbusCommunicatoRR3.skin",IBus3,
    Than you can change Button on Main Menu by holding down and choose IBus1-3 from List.
    Screenshot:
    Sep 2012
    Germany - Munich
    res 2
    Sep 2012
    Germany - Munich
    res 3
    Sep 2013
    hello you have a setup tutorial please thank you
    Sep 2012
    Germany - Munich
    Setup tutorial to install the plugin?
    Exist in ReadMe File.
    Install Instructions:
    Extract all files to your plugin directory .
    i.e for profile mode .../user/documents/riderunner/skins/../plugin
    If you don't already have MSCOMM32.OCX registered.
    Move it into C:\WINDOWS\SYSTEM32 folder (for 32bit OS)
    and run this command: regsvr32 C:\WINDOWS\SYSTEM32\MSCOMM32.OCX
    Register IBusCommunicatoRR.dll by double-clicking "Register.bat"
    Nov 2013
    Quote Originally Posted by harryberlin View Post
    But here in short steps for XP:
    -copy the pluginfolder "IBusCommunicatoRR" to plugin path. profile or programfiles mode is equal.
    -register the plugin.dll with batchfile in pluginfolder
    -copy mscomm32.ocx to system32 and register the ocx file
    that's it
    Hi I've installed your plugin and it's loaded during startup.
    Where I have to put the skin included?
    When RR startup in the plugin manager i see the plug in running, but I've no windows showing PDC only standard RR windows.
    My car is BMW E90 '05, with PDC and control wheel.
    I used the cable that I use for diagnosi and code.
    Nothing happen when I activate PDC or control wheel in my car.
    I'm using XP 32bit
    Can you help me?
    thanx
    Hi I've installed the plugin and it's loaded during RR startup, the .ini config file is loaded too because if I change the com port it stop and fail but I can't find
    Sep 2012
    Germany - Munich
    E90 don't work with ibus. follow this thread to get more information:
    http://www.mp3car.com/road-runner/15...k-can-bus.html
    Sep 2013
    es that your software operates
    the auxiliary heating are that it allows switching of webasto
    (your email box and full)
    Sep 2012
    Germany - Munich
    Do you have I-Bus log files when you turn on your auxiliary heating?
    I don't have auxiliary heating, just ventilation. Don't know how it works.
  1. Simplistique III, Update 10.Nov.2013
    By GF-ler in forum RR Released Skins
    Last Post: 11-24-2013, 01:28 AM
  2. IBusCommunicatoRR [Update Dec 2011]
    By JanneH0 in forum RR Released Plugins
    Last Post: 11-22-2013, 06:31 AM
  3. RR 02-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 03-03-2013, 12:00 PM
  4. RR 01-01-2013 Release
    Last Post: 01-02-2013, 12:16 PM
