Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 86
Like Tree2Likes
Thread: IBusCommunicatoRR (pt2) [Update May03 2015]
  1. #41
    Newbie GeddyT's Avatar
    Oh, and thanks for the help.
    This goes for the guys, too. Because sometimes the guys are tapped out. But check your lease, Man, 'cause you’re living in F*bleep* City!
  2. #42
    Sep 2012
    Germany - Munich
    with this plugin you can handle what you want with only one button.
    Attached Files Attached Files
  3. #43
    Thanks, I'll give that a try. I used the hold command on the phone button this morning, and I think it's definitely a solution I can live with if that plugin doesn't work out.
  4. #44
    Jan 2006
    Dublin, Ireland
    Hi all,
    I have an '04 BMW E46 which has factory installed PDC. I am nearing the end of my new build. I have a Resler interface on my CarPC and using the Reborn skin. Has anyone merged the Rear Camera functionality of RRPDC with the PDC triggers from this iBusCommunicatorRR plugin ? Is it just a case of some changes to the RRPDC skin to take PDC details from IbusCommunicatorRR instead ?
  5. #45
    Sep 2012
    Germany - Munich
    Hi
    I don't exactly understand what you mean.
    I tried to integrate a RearCam Function in IBusCommunicatoRR, but it would only work with Webcams.
    I tested some USB Videograbber interfaces, with non acceptable result.
    If your Cam works with Plugin RRCam, you could add the RearCam picture to the Skin file and use the ONSCREENCHANGE command to run RRCam.
    If you want add the IBusCommunicatoRR PDC Values to the RRPDC skin, you must edit the skin file.
    But it is difficult, because IBusCommunicatoRR loads the pdc skin directly.
  6. #46
    Jan 2006
    Dublin, Ireland
    Sorry, maybe I am coming at this all wrong. I know the download includes no skin files. What skin files can I use and can I select the video source to use for a Camera if a skin with this includes a window for displaying a USB Webcam ? And will this skin then read PDC values from IbusCommunicatorRR ?
  7. #47
    Sep 2012
    Germany - Munich
    Yes, you can find CarWings example Skin files for IBusCommunicatoRR in Post 2
    No, the plugin don't support a webcam currently.
  8. #48
    Jan 2006
    Dublin, Ireland
    Exactly, so has anyone taken the original RRPDC webcam enabled skin and changed it to then read the PDC graphic on the right from IbusCommunicatorRR's PDC data ?
    Original RRPDC skin image
  9. #49
    Sep 2012
    Germany - Munich
    nobody did it.
    if you include the sliders to the RRPDC screen and set PDCskin=False, then it could work.
    Better would be to use the RRCam Plugin/Tool and add the RRCam Window to PDC.skin.
    RRPDC is a complete PDC and RearCam Plugin. But you only need to add a RearCam.
  10. #50
    Newbie PCBum's Avatar
    Jun 2005
    Sunny California!
    I have an '01 E39, using Reslers usb and was using iBusRR v2.0.5 until going from Windows XP to Vista. I'm using a modified version of E36 skin.
    The iBusRR plugin was working well for me and I only used it for steering wheel functions. It does not want to run in Vista and I have switched to this Plugin.
    I cant seem to get the "switchscreens" function to work with the phone button nor the "mute" to work with RT. It was all working before in iBusRR.
    Can someone point me in the right direction? I would also like to get the gamma working with headlights on/off. Here is what I have...
    ; Steering Wheel ------------------------------------------------------------------
    [ID=130]
    IDName=STW_PREV_PRES
    MsgTemplate="5004683B080F"
    Label="S. Wheel < Press"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=True
    ReleaseID=132
    PressOrHoldID=
    RRCommand="RRPREV"
    [ID=131]
    IDName=STW_PREV_HOLD
    MsgTemplate="5004683B181F"
    Label="S. Wheel < Hold"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=132
    RRCommand="STARTFRWD"
    [ID=132]
    IDName=STW_PREV_REL
    MsgTemplate="5004683B282F"
    Label="S. Wheel < Release"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="STOPFRWD"
    [ID=135]
    IDName=STW_NEXT_REL
    MsgTemplate="5004683B2126"
    Label="S. Wheel > Release"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="RRNEXT"
    [ID=136]
    IDName=STW_PLUS_PRES
    MsgTemplate="50046832111F"
    Label="S. Wheel + Press"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="VOL+"
    [ID=137]
    IDName=STW_MINUS_PRES
    MsgTemplate="50046832101E"
    Label="S. Wheel - Press"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="VOL-"
    [ID=138]
    IDName=STW_PHONE_PRES
    MsgTemplate="5004C83B8027"
    Label="S. Wheel Phone Press"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=""!SWITCHSCREENS 0 2!"
    ;[ID=141]
    IDName=STW_RT_PRES
    MsgTemplate="5003C8019A"
    Label="S. Wheel RT Press"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="MUTE"
    Thanks all,
    Mark
  1. Simplistique III, Update 10.Nov.2013
    By GF-ler in forum RR Released Skins
    Last Post: 11-24-2013, 01:28 AM
  2. IBusCommunicatoRR [Update Dec 2011]
    By JanneH0 in forum RR Released Plugins
    Last Post: 11-22-2013, 06:31 AM
  3. RR 02-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 03-03-2013, 12:00 PM
  4. RR 01-01-2013 Release
    Last Post: 01-02-2013, 12:16 PM
