Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 91
Like Tree3Likes
Thread: IBusCommunicatoRR (pt2) [Update Nov29 2015] / BMW IBus
  1. #11
    Sep 2013
    ok I'll try to recover
    what software I can do that?
  2. #12
    Sep 2013
    On
    Name:  mise en route.png
    off
  3. #13
    Sep 2013
    how to install the skin
    I can not get
    this
    Screenshot:
    Attachment 70619
    Attachment 70620
    Attachment 70621
    Attachment 70622
    Attachment 70623
    Attachment 70613[/QUOTE]
  4. #14
    Sep 2013
    hello you can be proud of your work
    I'm happy
    you know
  5. #15
    Sep 2012
    Germany - Munich
    added a new function to tune a frequenz on radio
  6. #16
    May 2007
    Thanks for you work on this.
    I'm having some trouble with the plug in. It works fine (I can control the volume and change songs) until I turn the ignition on, then it crashes with error message "Run-time error 438 Object doesn't support this property or method"
    I've attached the RR and Ibus debug logs be low.
    Ibus log
    Code:
    "Date & Time","IbusMessage","ID Name","Label"
    #2013-12-29 14:51:40#,"50 04 68 3B 21 26","STW_NEXT_REL","S. Wheel > Release"
    #2013-12-29 14:51:43#,"50 04 68 32 11 1F","STW_PLUS_PRES","S. Wheel + Press"
    #2013-12-29 14:51:48#,"80 05 BF 18 00 00 22","OBCSPEEDRPM","OBC Speed&RPM"
    RR Log
    Code:
    12/29/2013 2:51:39 PM: IBusCommunicatoRR: '2005 New Mix (Dj Mil' Sent to the IKE Display.
    12/29/2013 2:51:39 PM: Enter Exec: False, menu.skin, "shuffle", False
    12/29/2013 2:51:39 PM: Que Exec: True, menu.skin, "shuffle", False
    12/29/2013 2:51:39 PM: Executing: shuffle
    12/29/2013 2:51:39 PM: Leave Exec: False, menu.skin, shuffle, False
    12/29/2013 2:51:40 PM: IBusCommunicatoRR: Ibus Message S. Wheel > Release received
    12/29/2013 2:51:40 PM: IBusCommunicatoRR: RR Command was NEXT
    12/29/2013 2:51:40 PM: Enter Exec: False, menu.skin, , False
    12/29/2013 2:51:40 PM: Que Exec: True, menu.skin, "NEXT", False
    12/29/2013 2:51:40 PM: Executing: NEXT
    12/29/2013 2:51:41 PM: Leave Exec: False, menu.skin, NEXT, False
    12/29/2013 2:51:41 PM: Enter Exec: False, menu.skin, , False
    12/29/2013 2:51:41 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
    12/29/2013 2:51:42 PM: IBusCommunicatoRR: '     Can't Stop     ' Sent to the IKE Display.
    12/29/2013 2:51:42 PM: EXECTBL Translation: ONSONGSTART -> RM_ONSONGSTART
    12/29/2013 2:51:42 PM: Executing: RM_ONSONGSTART
    12/29/2013 2:51:42 PM: Command not executed: RM_ONSONGSTART
    12/29/2013 2:51:42 PM: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
    12/29/2013 2:51:42 PM: Executing: ONCOMMANDINVALID
    12/29/2013 2:51:42 PM: Que Exec: True, menu.skin, "Reset_Stars||SENDMSG;MediaDB_plugin;RCheck", False
    12/29/2013 2:51:42 PM: Executing: Reset_Stars
    12/29/2013 2:51:42 PM: Command not executed: Reset_Stars
    12/29/2013 2:51:42 PM: Que Exec: True, menu.skin, "SENDMSG;MediaDB_plugin;RCheck", False
    12/29/2013 2:51:42 PM: Executing: SENDMSG;MediaDB_plugin;RCheck
    12/29/2013 2:51:42 PM: Leave Exec: False, menu.skin, SENDMSG;MediaDB_plugin;RCheck, False
    12/29/2013 2:51:42 PM: Enter Exec: False, menu.skin, , False
    12/29/2013 2:51:42 PM: Que Exec: True, menu.skin, "RM_Rated0", False
    12/29/2013 2:51:42 PM: Executing: RM_Rated0
    12/29/2013 2:51:42 PM: Command not executed: RM_Rated0
    12/29/2013 2:51:42 PM: Leave Exec: False, menu.skin, ONCOMMANDINVALID, False
    12/29/2013 2:51:43 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||PLAY", False
    12/29/2013 2:51:43 PM: Que Exec: True, menu.skin, "ONBTNPRESS||PLAY", False
    12/29/2013 2:51:43 PM: Que Exec: True, menu.skin, "PLAY", False
    12/29/2013 2:51:43 PM: Executing: PLAY
    12/29/2013 2:51:43 PM: Leave Exec: False, menu.skin, play, False
    12/29/2013 2:51:43 PM: IBusCommunicatoRR: Ibus Message S. Wheel + Press received
    12/29/2013 2:51:43 PM: IBusCommunicatoRR: RR Command was VOL+
    12/29/2013 2:51:43 PM: Enter Exec: False, menu.skin, , False
    12/29/2013 2:51:43 PM: Que Exec: True, menu.skin, "VOL+", False
    12/29/2013 2:51:43 PM: EXECTBL Translation: VOL+ -> VOL+||SENDMSG;RRVoiceControl;RRVC_VOLUME
    12/29/2013 2:51:43 PM: Executing: VOL+
    12/29/2013 2:51:43 PM: Que Exec: True, menu.skin, "SENDMSG;RRVoiceControl;RRVC_VOLUME", False
    12/29/2013 2:51:43 PM: Executing: SENDMSG;RRVoiceControl;RRVC_VOLUME
    12/29/2013 2:51:43 PM: Leave Exec: False, menu.skin, SENDMSG;RRVoiceControl;RRVC_VOLUME, False
    12/29/2013 2:51:44 PM: Que Exec: True, menu.skin, "SENDMSG;RRVoiceControl;RRVC_VOLUME", False
    12/29/2013 2:51:44 PM: Executing: SENDMSG;RRVoiceControl;RRVC_VOLUME
    12/29/2013 2:51:44 PM: Leave Exec: False, menu.skin, SENDMSG;RRVoiceControl;RRVC_VOLUME, False
    12/29/2013 2:51:48 PM: IBusCommunicatoRR: Ibus Message OBC Speed&RPM received
  7. #17
    Sep 2012
    Germany - Munich
    Hi
    Try the new version of today. i changed some things on ignition commands. but i don't know exactly was the problem is.
    can i get a screenshot of the error?
    i will add some other debug possibilities.
    and please attach the debug files, don't quote.
    Did you get the same error with carwings skin?
    To disable the IKE Display just set DisplayEnable=False in ibuscommunicatorr.ini.
  8. #18
    May 2007
    Wow, thanks for the quick response. I'll give the new version a try later on today and let you know the result. I was getting the error with Digital FX 4.0 skin, haven't tried the Carwings one.
  9. #19
    May 2007
    Unfortunately, the latest version is giving me the same error.
    Attached are the log file, screenshot of the error and my ini file. Any ideas would be appreciated.
    Attached Files Attached Files
  10. #20
    Sep 2012
    Germany - Munich
    use this new dll. this don't solve the problem, but save more information to log-file.
    enable both debug options in ini file.
    Debug=True
    ExtendedDebug=True
    in C:\IBusCommunicatoRR_LOG should exist log files too. attach these after test.
    you can also contact me by e-mail. read top of ibuscommunicatorr.ini. the second one.
  1. Simplistique III, Update 10.Nov.2013
    By GF-ler in forum RR Released Skins
    Last Post: 11-24-2013, 02:28 AM
  2. IBusCommunicatoRR [Update Dec 2011]
    By JanneH0 in forum RR Released Plugins
    Last Post: 11-22-2013, 07:31 AM
  3. RR 02-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 03-03-2013, 01:00 PM
  4. RR 01-01-2013 Release
    Last Post: 01-02-2013, 01:16 PM
