Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 91
Like Tree3Likes
Thread: IBusCommunicatoRR (pt2) [Update Nov29 2015] / BMW IBus
  1. #51
    Sep 2012
    Germany - Munich
    RT does not work. you need to delete the ; before the ID. and set system=true
    the same with switchscreens.
    what command is that? can RideRunner handle that?: "!SWITCHSCREENS 0 2!
    [ID=138]
    IDName=STW_PHONE_PRES
    MsgTemplate="5004C83B8027"
    Label="S. Wheel Phone Press"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=""!SWITCHSCREENS 0 2!"
    [ID=141]
    IDName=STW_RT_PRES
    MsgTemplate="5003C8019A"
    Label="S. Wheel RT Press"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="MUTE"
    For Gamma, you must add new IDs with the Light IBusMsg
    Do you have these IDs in your INI File:
    Yes? Replace the RRComannd with gamma command
    No? Add them with gamma command
    And try it.
    [ID=211]
    IDName=LIGHTS_ON
    MsgTemplate="D008BF5B01000000003D"
    Label="Lights on"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=LIGHTSON
    [ID=212]
    IDName=LIGHTS_OFF
    MsgTemplate="D008BF5B00000000003C"
    Label="Lights off"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=LIGHTSOFF
  2. #52
    Newbie PCBum's Avatar
    Jun 2005
    Sunny California!
    Quote Originally Posted by harryberlin View Post
    Ok, thanks. That was the way (I think) that I used to switch between the main menu (o) and navigation screen (2) with the other plugin using the phone button. How would I set this up now?
    Thanks again for all the hard work and help
    Mark
  3. #53
    Sep 2012
    Germany - Munich
    i would solve this so:
    edit in IBusCommunicatoRR.ini
    Code:
    [ID=138]
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=MFLSWITCHSCREENS
    add to Skin Skin.ini:
    Code:
    MFLSWITCHSCREENS=00
    add to Skin ExecTBL.ini:
    Code:
    "MFLSWITCHSCREENS","BYVARX;MFLSWITCHSCREENS;(SETVAR;MFLSWITCHSCREENS;01||GPS<<SETVAR;MFLSWITCHSCREENS;02||AUDIO<<SETVAR;MFLSWITCHSCREENS;00||MAIN)"
    you can replace the commands "GPS", "AUDIO", "MAIN" by whatever
  4. #54
    Nov 2010
    Quote Originally Posted by PCBum View Post
    Mark
    Hi Mark,
    Do as suggested by harryberlin or
    Code:
    [ID=138]
    Change to RRCommand="MAIN"
    And add one line in execTBL.ini:
    Code:
    "MAIN","GPS",menu.skin
    If your navigation skin name is something else just change "GPS" to the name of your navigation skin.
    /JanneH0
  5. #55
    Sep 2012
    Germany - Munich
    Yes, there are some ways to get the result.
    Oh, heh just want switch between MAIN and GPS. Small mistake by me.
  6. #56
    Nov 2010
    Quote Originally Posted by GeddyT View Post
    I'm sure there's a really simple answer to this that's going to make me feel stupid, but here goes:
    I'm trying to map a steering wheel button to where in the audio browser it will act essentially like a mouse double-click. I've yet to find one that gets the job done. What I want is to be able to browse through folders by scrolling up or down to the folder I want and then hitting this button to open it. Once I get to all the way down to individual song files, though, I want to be able to click this same button to select one for playing.
    "BROWSE" works great for moving through folders, but once I find the song I want, that command won't play it. "SELECT" is great for playing songs, but it also automatically loads folders into the playlist instead of opening them. I tried "ENTER", but that was definitely not what I was looking for.
    When I'm using the mouse in testing, double-clicking works just fine. Double-click a folder to open it, double-click a song to play it. So what's the double-click command?
    Thanks.
    Hi GeddyT
    Little late but you can try to change "PLAY" with "CTRLEXEC" on R/T button, that's how I used it.
    if you use CTRLEXEC on a FOLDER in either on the audio or video browser, it will first "BROWSE", then execute "SELECT" when used on a file.
    Downside is (if i remember correct) it add all files in the current folder, not just a single song.
    /JanneH0
  7. #57
    Jun 2005
    Sunny California!
    I really appreciate all the help guys.
    Now when I try to fast rewind or fast forward (< >) the previous (or next) song is loaded AND ffwd or frwd when holding button. How would I get it to only act on current song?
    [ID=130]
    IDName=STW_PREV_PRES
    MsgTemplate="5004683B080F"
    Label="S. Wheel < Press"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=True
    ReleaseID=132
    PressOrHoldID=
    RRCommand="RRPREV"
    [ID=131]
    IDName=STW_PREV_HOLD
    MsgTemplate="5004683B181F"
    Label="S. Wheel < Hold"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=132
    RRCommand="STARTFRWD"
    [ID=132]
    IDName=STW_PREV_REL
    MsgTemplate="5004683B282F"
    Label="S. Wheel < Release"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="STOPFRWD"
    "If at first you don't succeed, keep on suckin' till ya do succeed" (Stooges)
  8. #58
    Sep 2012
    Germany - Munich
    If i understand correct.
    all is working fine, but you want fast << or >> on current song?
    that means for me, you seek the prev or next song? how can you listen on which position you are seeking the prev or next song?
    otherwise, write down in steps what you need.
  9. #59
    Jun 2005
    Sunny California!
    When playing mp3 files and I press AND HOLD > button, I want the current song to fast forward as long as I am HOLDING button. Same with < button for rewinding current song.
  10. #60
    Sep 2012
    Germany - Munich
    That means, it's not working?
    Try to set System=True
  1. Simplistique III, Update 10.Nov.2013
    By GF-ler in forum RR Released Skins
    Last Post: 11-24-2013, 02:28 AM
  2. IBusCommunicatoRR [Update Dec 2011]
    By JanneH0 in forum RR Released Plugins
    Last Post: 11-22-2013, 07:31 AM
  3. RR 02-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 03-03-2013, 01:00 PM
  4. RR 01-01-2013 Release
    Last Post: 01-02-2013, 01:16 PM
