Page 1 of 10 12345678910 LastLast
Results 1 to 10 of 91
Like Tree3Likes
Thread: IBusCommunicatoRR (pt2) [Update Nov29 2015] / BMW IBus
    Sep 2012
    Germany - Munich
    Hi People
    I was in contact with JanneH0. And we decided that i will continue the Development of his great I-Bus Plugin.
    Why new Thread? Because it's difficult to add changes in his Thread. So i started an own. I tested the new Version in my Car 5er E39 with IKE High and 16:9 MK4 Navigation.
    The old Thread is here: http://www.mp3car.com/rr-released-pl...ec-2011-a.html
    Please tell me, when you have trouble with the new Version.
    My adds since Version Dec17 2011:
    Oct 29 2013 Update
    Added setting to ini file: load/save obc values,
    Added setting to show/hide units of obc values
    Added IbusCommunicatoRR.log to log some Strings
    Updated IbusCommunicatoRR;sendtoibus (now it works without Checksum)
    Updated increased the Ibus IDs up to 300
    Updated ReplyMsgID function
    Updated ReadMe.txt
    Updated Text Scrolling function
    Updated Sample Skin
    Added new Variables:
    $IBusCommunicatoRR_ARRIVAL$
    $IBusCommunicatoRR_LIMIT$
    $IBusCommunicatoRR_OBCTIMER1$
    $IBusCommunicatoRR_OBCTIMER2$
    $IBusCommunicatoRR_STOPWATCH$
    $IBusCommunicatoRR_IBUSCLOCK$
    $IBusCommunicatoRR_IBUSDATE$
    $IBusCommunicatoRR_NETWORK$
    $IBusCommunicatoRR_LANG$
    $IBusCommunicatoRR_DISTUNIT$
    $IBusCommunicatoRR_SPDUNIT$
    $IBusCommunicatoRR_TEMPUNIT$
    $IBusCommunicatoRR_CLKFM$
    $IBusCommunicatoRR_CNSUNIT$
    $IBusCommunicatoRR_MOTOR$
    Added new CMDs to
    -Set Distance
    -Set Speedlimit
    -Set Timer 1 or 2
    -Call a Phonenumber
    -OBC Request
    -Set OBC IKE Units/Formats
    Added new INDs:
    !IbusCommunicatoRR_LIMIT
    !IBusCommunicatoRR_MEMO
    !IBusCommunicatoRR_AUXHEAT
    !IBusCommunicatoRR_TIMER1
    !IBusCommunicatoRR_TIMER2
    Nov20 2013 Update
    Added CMDs when you turn your Key
    IBUSCOMMUNICATORR_IGN_OFF
    IBUSCOMMUNICATORR_IGN_ACC
    IBUSCOMMUNICATORR_IGN_ON
    IBUSCOMMUNICATORR_IGN_START
    Added CMD IbusCommunicatoRR;PDCSCROFF : Stops the PDC and exit the pdc.skin
    Added PDC stops and exit the pdc.skin if you drive faster than 30km/h or 18mph
    Updated ReadMe.txt
    Nov23 2013 Update
    fixed some Bugs
    updated Sample Skin
    Updated ReadMe.txt
    Nov25 2013 Update
    added/updated real AUX Heat Indicator
    !IBusCommunicatoRR_AUXVENT:B : State of AUX Ventilation LED (BLINK / OFF)
    !IBusCommunicatoRR_AUXHEAT:B : State of AUX Heating LED (BLINK / OFF)
    Dec24 2013 Update
    added new CMD to tune a frequenz directly on radio: ex. IbusCommunicatoRR;FM;96,3
    added new errorscreen when exist a com-port error on RR start
    updated ReadMe.txt
    updated un-/register.cmd for all windows ( XP --> 8 )
    Dec30 2013 Update
    bugfix about the ignition commands
    Apr26 2014 Update
    few changes on sample skin
    Jun01 2014 Update
    small changes in Text Scrolling Function. IKE Textbar switches back after a moment to ike msg when scrolling was stopped.
    Jul03 2014 Update V2.0
    New Version 2.0 works with RR Version Jul01_2014
    added function by fastforward and -backward for IKE Display if enabled (shows Tracktime on Display)
    new function to import Contacts (Name, Numbers and Photo) from VCard. i simple exported my Android S3 mini Contacts as *.vcf file.
    optimized the IBUSCOMMUNICATORR;CALL command
    updated Sample Skin (BMW Phone, Active Call Popup, Add Contact)
    updated ReadMe.txt
    tried to add all of them to an installer, but needs some time for installer release
    new CMDs:
    IBUSCOMMUNICATORR;BMWPHONE (loads the BMW Phone skin and adds the Contacts from VCard to List)
    IBUSCOMMUNICATORR;ADDCONTACT; (adds new Contact to VCard)
    IBUSCOMMUNICATORR;REMOVECONTACT; (deletes Contact from VCard)
    new VARs:
    $IBUSCOMMUNICATORR_VCARD_NAME$
    $IBUSCOMMUNICATORR_VCARD_NUMBER$
    $IBUSCOMMUNICATORR_VCARD_IMG$
    new INDs:
    !IBUSCOMMUNICATORR_PHONE_GREEN
    !IBUSCOMMUNICATORR_PHONE_YELLOW
    !IBUSCOMMUNICATORR_PHONE_RED
    !IBUSCOMMUNICATORR_PHONE_BTN
    Jul08 2014 Update
    Installer is ready for Release
    Oct11 2014 Update/Teststate
    Integrated RearCam(Webcam) Feature works only with UVC Devices
    add this to plugin ini-file. The Installer don't overwrite an existing ini file.:
    Code:
    ; Enable RearCam Integration, True or False (default False)
    RearCam=True
    add this to your pdc.skin file:
    Code:
    [ RearCam Area ]
    AX,200,140,400,300
    for Test you can use this command to enable/disable:
    IBUSCOMMUNICATORR;REARCAM
    There is a new RearCamFull.skin file. If you click the video screen, you can switch between full or normal view.
    For connecting my Rearcam on PC i found a usb uvc video grabber on ebay. itemnumber: 310916545175
    Also i did some changes on Phone popup skin.
    But the Phone Keys don't work at the moment.
    Now the Songpos on seeking is only shown in Radiomode Aux.
    Some time left, nobody told me about problems with the RearCam(Webcam) version. that's why i delete the older version in this thread.
    Nov08 2014 small Update
    added Flash Gauges for F, mph and rpm for Diesel on second post of this thread
    Dec14 2014 Update
    updated doing with Ignition Commands
    added a new indicator
    !IBUSCOMMUNICATORR_IGN
    Dec19 2014 Update
    fixed some bugs
    optimized OBC Request
    Jan27 2015 Update
    fixed some bugs
    updated Carwings Sample Skin
    added Elite 2 Sample Skin ( big thanx to robsbmwerks )
    Jan29 2015 Update
    added Config Tool for ini file
    Apr03 2015 Update
    fixed some Bugs
    updated SampleSkin, The Radio Screen is only Beta state.
    updated ReadMe, Check for some new Commands/Vars/Indicators.
    updated Config Tool
    added new Flashgauge for Fuel level
    Simplistique Skin prepared for IBusCommunicatoRR is placed in 2nd post.
    edit:
    Fuel Level has a mistake
    May03 2015 Update
    i think i have fixed the fuel level issue
    now there is a new debug mode
    replace the existing debug settings with this in your ini file:
    Code:
    ;Debug Level for different Debug Modes (default 1) [0 = off, 1 = low, 2 = mid, 3 = high]
    DebugLevel=0
    Oct01 2015 Update
    updated pdc handling
    updated IBusCommunicatoRRConfigTool; you should delete your existing ini file(don't forget backup) and run the config tool.
    new CMDs:
    IBUSCOMMUNICATORR_DOORS_OPENED
    IBUSCOMMUNICATORR_DOORS_CLOSED
    new INDs:
    !IBusCommunicatoRR_DRV_F_DOOR
    !IBusCommunicatoRR_DRV_R_DOOR
    !IBusCommunicatoRR_PSG_F_DOOR
    !IBusCommunicatoRR_PSG_R_DOOR
    !IBusCommunicatoRR_DRV_F_WDW
    !IBusCommunicatoRR_DRV_R_WDW
    !IBusCommunicatoRR_PSG_F_WDW
    !IBusCommunicatoRR_PSG_R_WDW
    !IBusCommunicatoRR_TRUNK
    !IBusCommunicatoRR_BONNET
    !IBusCommunicatoRR_CTR_LOCK
    Oct15 2015 Update
    small bugfix
    Nov29 2015 Update
    new RemoteControl CMDs:
    IBUSCOMMUNICATORR_RC_LOCK_PRES
    IBUSCOMMUNICATORR_RC_UNLOCK_PRES
    IBUSCOMMUNICATORR_RC_BOOT_PRES
    IBUSCOMMUNICATORR_RC_REL
    new RemoteControl IND:
    !IBusCommunicatoRR_RC_BAT_LOWLVL
    Next Steps
    need some tests for skin and commands to use phonebuttons for hotline menus
    maybe add CD Status for the other Typ of CD-Changer
    Optimize Flash Gauges
    Sample Skin, Flash Gauges seperated to next Post
    Attached Files Attached Files
    Pocmen likes this.
    Sep 2012
    Germany - Munich
    The Sample Skin got new CMD-Buttons, Indicators, Label and 7 Flashgauges.
    For the Fuel Gauge you have to add the maximum fuel size of your tank to skin.ini
    example: 65 liters
    Code:
    IBUSCOMMUNICATORR_FUELMAX=65
    RearCam Demo:
    Old Video of first test: https://www.youtube.com/watch?v=MIetX0SXaBo
    Screenshots:
    Config Tool
    CarWings
    elite 2
    Simplistique
    Sep 2012
    Germany - Munich
    To get your Steering Wheel working use/replace these IDs and Settings:
    Code:
    [ID=130]
    IDName=STW_PREV_PRES
    MsgTemplate="5004683B080F"
    Label="S. Wheel < Press"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=True
    ReleaseID=132
    PressOrHoldID=
    RRCommand="PREV2"
    [ID=131]
    IDName=STW_PREV_HOLD
    MsgTemplate="5004683B181F"
    Label="S. Wheel < Hold"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=132
    RRCommand="STARTFRWD"
    [ID=132]
    IDName=STW_PREV_REL
    MsgTemplate="5004683B282F"
    Label="S. Wheel < Release"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="STOPFRWD"
    [ID=133]
    IDName=STW_NEXT_PRES
    MsgTemplate="5004683B0106"
    Label="S. Wheel > Press"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=True
    ReleaseID=135
    PressOrHoldID=
    RRCommand="NEXT"
    [ID=134]
    IDName=STW_NEXT_HOLD
    MsgTemplate="5004683B1116"
    Label="S. Wheel > Hold"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=135
    RRCommand="STARTFFWD"
    [ID=135]
    IDName=STW_NEXT_REL
    MsgTemplate="5004683B2126"
    Label="S. Wheel > Release"
    Parse=True
    System=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="STOPFFWD"
    Sep 2012
    Germany - Munich
    Backup of older Version
    Sep 2013
    hello you have a setup tutorial please thank you
    Sep 2012
    Germany - Munich
    Setup tutorial to install the plugin?
    Exist in ReadMe File.
    Install Instructions:
    Extract all files to your plugin directory .
    i.e for profile mode .../user/documents/riderunner/skins/../plugin
    If you don't already have MSCOMM32.OCX registered.
    Move it into C:\WINDOWS\SYSTEM32 folder (for 32bit OS)
    and run this command: regsvr32 C:\WINDOWS\SYSTEM32\MSCOMM32.OCX
    Register IBusCommunicatoRR.dll by double-clicking "Register.bat"
    Nov 2013
    Quote Originally Posted by harryberlin View Post
    But here in short steps for XP:
    -copy the pluginfolder "IBusCommunicatoRR" to plugin path. profile or programfiles mode is equal.
    -register the plugin.dll with batchfile in pluginfolder
    -copy mscomm32.ocx to system32 and register the ocx file
    that's it
    Hi I've installed your plugin and it's loaded during startup.
    Where I have to put the skin included?
    When RR startup in the plugin manager i see the plug in running, but I've no windows showing PDC only standard RR windows.
    My car is BMW E90 '05, with PDC and control wheel.
    I used the cable that I use for diagnosi and code.
    Nothing happen when I activate PDC or control wheel in my car.
    I'm using XP 32bit
    Can you help me?
    thanx
    Hi I've installed the plugin and it's loaded during RR startup, the .ini config file is loaded too because if I change the com port it stop and fail but I can't find
    Sep 2012
    Germany - Munich
    E90 don't work with ibus. follow this thread to get more information:
    http://www.mp3car.com/road-runner/15...k-can-bus.html
    Sep 2013
    es that your software operates
    the auxiliary heating are that it allows switching of webasto
    (your email box and full)
    Sep 2012
    Germany - Munich
    Do you have I-Bus log files when you turn on your auxiliary heating?
    I don't have auxiliary heating, just ventilation. Don't know how it works.
  1. Simplistique III, Update 10.Nov.2013
    By GF-ler in forum RR Released Skins
    Last Post: 11-24-2013, 02:28 AM
  2. IBusCommunicatoRR [Update Dec 2011]
    By JanneH0 in forum RR Released Plugins
    Last Post: 11-22-2013, 07:31 AM
  3. RR 02-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 03-03-2013, 01:00 PM
  4. RR 01-01-2013 Release
    Last Post: 01-02-2013, 01:16 PM
