Results 1 to 3 of 3
Thread: RRTPMS - Tyre Pressure Monitoring System Released 29/11/13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Press the button below to download from my forum
    or download it from the AutoAppMart - nb registration on my forum still required
    RRTPMS is a plugin for RideRunner (FKA RoadRunner).
    This plugin is to be used with the Third-Eye Tyre Pressure Monitoring System using the USB Interface designed by RobbyBMW on mp3car.com.
    Custom USB Tyre Pressure Monitoring Interface
    Whilst RobbyBMW has already written a RideRunner plugin (see thread below) it is now a little bit out of date.
    RRTMS Roadrunner Tire Monitoring System Extension Plugin
    What’s new in this plugin
    • Comes with an installer
    • Designed to be used with the new dynamic menus
    • Has Carwings skin files
    • Fixes the silent mode toggle not saving
    • Displays date each sensor last updated
    • Visual indication of connection/no connection
    • Each sensor can be toggled on/off. To save on continual alerts if a sensor has been removed
    • User configurable refresh rate (default is 10 sec)
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    F.A.Q.
    Q. Why should I use this plugin as opposed to the one RobbyBMW did?
    A.
    There is no reason why you shouldn't use Robby’s one. However I have updated the plugin to be compatible with the latest version of RideRunner and added a few new features.
    Q. How do I change the size?
    A.
    The plugin will run at the same size as RoadRunner/RideRunner.
    Q. Can I use RRSkineditor to edit the skin files?
    A.
    Yes.
    Q. How do I add this is my skin?
    A.
    Add a button with the command RRTPMS, and then design the screens to match your skin. Use the Carwings skin files as a guideline
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Screenshots
  1. Custom USB tyre pressure monitoring interface
    By Robby BMW in forum Portal Media Car PC Gadgets and Accessories
    Last Post: 01-10-2016, 10:28 AM
  2. Tire Pressure Monitoring System
    By vinzer in forum DigitalMods (Scripts / API)
    Last Post: 02-22-2008, 01:39 AM
  3. [Request] Tyre Pressure Monitoring Software Plugin
    By mrbean_phillip in forum CF Plugins
    Last Post: 01-21-2008, 01:53 AM
  4. Tire Pressure monitoring System
    By sfay93 in forum General Hardware Discussion
    Last Post: 03-29-2007, 07:04 PM
