Results 1 to 2 of 2
Thread: RRm3uCreator [Update Feb14 2014]
    Sep 2012
    Germany - Munich
    Hello
    Here is a very helpful plugin for me.
    My problem was, RR always adds audiofiles to playlist incl. Subfolders.
    So i coded an own plugin which can do this job without Subfolders.
    I included an extra function, to browse through paths and add files with only one button.
    Update 2014 Feb14:
    upd: small changes to work better with new RR Release (maybe this mounth) great thx to mitchjs for the optimized ONDLPOSCHANGE event
    Update 2014 Feb08:
    bugfix: some files were missed and unsorted before
    add: new var for button optics
    new: playlist file now in unicode
    With this plugin you can load audiofiles only from current browserpath (without subfolders) to playlist.
    Has just 2 Commands:
    RRm3uCreator;select : see descriptions below
    RRm3uCreator;!select : same above without cancel. to stay on the screen
    Variable for Button Icon:
    RRM3UCREATOR_BT : gets three states 00, 01, 02 for using with indicator
    example:
    B23,948,282,104,104,"RRM3UCREATOR;!SELECT",""
    I23,962,295,078,078,"VAR;RRM3UCREATOR_BT",,,"BT_SE LECT_*.png"
    About the Doing:
    if you select a folder, the plugin reply "BROWSE" to open the folder
    if you select "..", the plugin reply "BACK" to go up one folder
    if you select an audiofile,
    - the plugin saves all audiofiles incl. path (added in rr.ini at AudioFiles) to RRm3uCreator.m3u in pluginpath.
    - the plugin compare the selected file by postion in playlist and plays the song after loading playlist in RideRunner.
    - the Plugin names the playlist Label in RideRunner like folder name.
    when you add these line to ExecTBL.ini, it should work without editing skin files:
    "SELECT","RRm3uCreator;SELECT",audio_browser.s kin
    if you need it, try it.
    Attached Files Attached Files
    Sep 2012
    Germany - Munich
    did some changes
  1. Garmin Mobile PC 2014 Maps install - Success
    By Dluvr22 in forum Garmin Mobile PC
    Last Post: 08-03-2015, 06:50 PM
  2. Can-am 2014
    By SNOtwistR in forum MP3Car Gatherings
    Last Post: 07-24-2014, 10:40 AM
  3. RR 01/01/2014 Release
    By mitchjs in forum Road Runner
    Last Post: 02-21-2014, 01:07 AM
  4. Need some help on 2014 and 4034
    By peter3 in forum LCD/Display
    Last Post: 08-10-2001, 09:22 AM
  5. LCD 2014 ?s
    By Frickn in forum General Hardware Discussion
    Last Post: 09-09-2000, 08:46 PM
