View Poll Results: Do you think use it ?
Voters
0. You may not vote on this poll
  • YES
    0 0%
  • NO
    0 0%
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By pierrotm777
Thread: RRDuino ARDUINO plugin for RR
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Arduino plugin
    Tested with an Arduino Uno
    You must install the .ino file into the Arduino with the Arduino IDE
    You must define the com port and baud rate settings into the .xml file
    Main screen
    History:
    v0.0.4 23-9-2015
    - Add calculation on a duino LABEL (other is possible) (+, -, *, /, ^ and Modulo)
    With this feature, you can convert an analog value as LABEL by a calculation (Uno analog pins are A0 to A5 ,from 0 to 1024)
    examples:
    Code:
    DUINO_CALC;ADD;DUINO_AVALUE_1;0.01953125;2 	return the calcul on a label DUINO_AVALUE_1, DUINO_AVALUE_1 + 0.01953125 with 2 numbers after the dot
    DUINO_CALC;MIN;DUINO_AVALUE_1;0.01953125;2 	return the calcul on a label DUINO_AVALUE_1, DUINO_AVALUE_1 - 0.01953125 with 2 numbers after the dot
    DUINO_CALC;MUL;DUINO_AVALUE_1;0.01953125;2 	return the calcul on a label DUINO_AVALUE_1, DUINO_AVALUE_1 * 0.01953125 with 2 numbers after the dot
    DUINO_CALC;DIV;DUINO_AVALUE_1;0.01953125;2 	return the calcul on a label DUINO_AVALUE_1, DUINO_AVALUE_1 / 0.01953125 with 2 numbers after the dot
    DUINO_CALC;PWR;DUINO_AVALUE_1;3;2 		return the calcul on a label DUINO_AVALUE_1, DUINO_AVALUE_1 Power 3 with 2 numbers after the dot
    DUINO_CALC;MOD;DUINO_AVALUE_1;2 		return the calcul on a label DUINO_AVALUE_1, DUINO_AVALUE_1 Modulo 2
    Particular example (read a voltage from 0 to 20V):
    Code:
      Vs = Vin * (R2 / (R1 + R2))
      Here R1 = 3300 ohms (3k3) and R2 = 1100 ohms (1k1), we get for Vin = 20v (maximum) :
      Vs = 20 * (1100 / (3300 + 1100)) = 20 * (1100 / 4400) = 20 * 0.25 = 5
      Vs = 5v for Vin = 20v, the maximum that can measure the Arduino's  converter  analog -> digital ( 5V supply of course) .
            +20V maxi
    ----.   # R1=3k3 = Orange Orange Red Gold
      A1|---+
    Uno |   # R2=1k1 = Brown Brown Red Gold
        |  GND
    NB: In this example, the LABEL will be DUINO_AVALUE_1
    Into the skin file:
    Code:
    L,148,311,87,24,255,0,0,16,"Arial:B","DUINO_CALC;MUL;DUINO_AVALUE_1;0.01953125;2|| V","CENTER",,"DS=2,2,0,0,0"
    where 0.01953125 = label value * (5.0 / 1024)) * 4.0 (!!! You can use dot or comma !!!)
    v0.0.3 31-8-2015
    -Add read Digital input pins
    -Ckeck if com port is ready (Arduino connected or not)
    -Rewrite code
    v0.0.2 30-8-2015
    -Add read Analog input pins
    -Add servo possibility on digital pins
    v0.0.1 27-8-2015
    -Only DIGITAL output command accepted
    Attached Files Attached Files
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    I'll definitely try this in two months time when I'm back in the UK . Cheers
    Sent from my GT-I9505 using Tapatalk
    Vauxhall Astra SXi Car PC installed.
    May 2011
    Wow, what I need!
    Thank you.
    I was thinking about FusionBrain but your plug-in opens up possibilities
    Envoyé de mon Nexus 6 en utilisant Tapatalk
    May 2008
    Bordeaux, France
    Quote Originally Posted by Rollus.MkIII View Post
    Wow, what I need!
    Thank you.
    Teint un Français ?
    Send me your return !!!
    I search a way for do an operation (calcul) from a label but EVAL don't run with labels , only in a command !!!
    May 2008
    Bordeaux, France
    New version with new feature, see first post please !!!
    May 2011
    Merci
    I will test in few weeks, my carPC isn't completly installed yet..
    May 2008
    Bordeaux, France
    Merci
    I wait your comments !
    Mar 2005
    Norfolk UK
    Right, I'm back in the UK now and keen to try this plugin. Is it just the UNO or can the NANO be used too?
    Regards,
    Dave
    May 2008
    Bordeaux, France
    Quote Originally Posted by Dave One View Post
    Regards,
    Dave
    Nano can be used also !
  1. Arduino PI?
    By Dave One in forum RR Plugins
    Last Post: 08-27-2015, 01:31 PM
  2. Can Arduino sensors be used with the FB v6?
    By Dave One in forum Fusion Brain
    Last Post: 10-20-2014, 06:05 AM
  3. Arduino Uno Kit
    By SNOtwistR in forum Classifieds
    Last Post: 02-07-2014, 10:08 PM
  4. Arduino as a touchscreen controller. Is it possible?
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 11-23-2012, 02:20 AM
  5. Arduino for OM - In progress
    By jmullan99 in forum OpenMobile
    Last Post: 03-13-2011, 05:43 PM
