Page 11 of 26 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 252
Thread: Ratings plugin
  1. #101
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Sorry, I haven't read the whole thread but just a quick question, with your rating system, how are the ratings saved?
    I understand you make a playlist for each number of stars, but is that the only way to reference how many stars a song has?
    I'm not so if you know but, ID3v2 tags have a rating system build in. You can just change that part of the tag for each song. That way you don't have to continuously have to save to a playlist, you can just use RR to sort according to the rating.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #102
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Enforcer View Post
    It happens, change of mind
    Takes longer to write out the whole path
    No difference. It actually creates two m3u files, one it leaves empty the other it sticks the filename in, neither are the one I selected
    eg
    Selected a song, gave it one star, 4 star.m3u created empty and 5 star.m3u created with file in.
    select another song give it two star, 2 star.m3u created with correct song in
    select a third song give it one star 1 star.m3u created with correct song it, but only that one, not the one that I did first.
    I could now carry on infinitium and it will now correctly assign songs and even move them. It's just that first one.
    OH! and still that I need this dummy road runner directory, rr.ini and ratings folder with contents on my C: drive for it to work.
    i'm gonna have to set up my home pc the way yours is setup (with different drive letters doing different things) and see if i can recreate the problem. As of now there are NO paths in any of the exe's, they're all be received from road runner or ratingsconfig.ini.
    Live mp3Car Facebook Chat
  3. #103
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Quattro View Post
    unfortunately this just manages the ratings in a playlist. Autoit doesnt have the ability to read or write to ID3 tags.
  4. #104
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Sonicxtacy02 View Post
    I don't have different drives doing different things normally, normally OS and Programs are on my E: drive, and everything works fine. It's just for this to work at the moment I have to make a dummy PF and RR folder for it to work. So something is defaulting to C:
    can you share the actual scripts and let me a have a look.
    cheers
  5. #105
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    this is what i'd prefer
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  6. #106
    Dec 2003
    New York
    Quote Originally Posted by Ruffy View Post
    I am gonna begin writing a tag editor plugin for RR (because there is always this one tag that I mess up and I always wished there was a way to change it within RR) and I will see if I can integrate the ratings part of the tag. I'll give Sonic the info so he can integrate it with his plugin.
    Installed
  7. #107
    Woodbridge, VA
    Blog Entries
    32
    if you write a tag editor it'd be easy for me to adjust my plugin to make use of it... but can rr read the tag information and load songs according to the rating inside the tag is the question.
  8. #108
    Dec 2003
    New York
    Good question, that is something we have to ask guino
    Installed
  9. #109
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    ADDTOFILE command in Road Runner
    Any luck sonix? One thing that MAY save you a little bit oof coding, is RR now has the ability internally to append a line to a file.
    ADDTOFILE;$PLAYLISTPATH$5Star.M3U;=$CURRENTTRACK$"
    You would still have to look and see if the song is in that list already, but it would make adding a line to a playlist very easy, instead of having to read the file in, add the line, and then save the file back out again.
    I am anxious to get this working in my skin, as it is a fantastic plugin! I have it all skinned and ready to go, just waiting on the bug fixes ect.
    My Fiero Build Thread
  10. #110
    Woodbridge, VA
    Blog Entries
    32
    I've been working with enforcer on some fixes. He donated some of his time and code and i'll have the results of that out tomorrow hopefully.
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
