Originally Posted by
Ruffy
I'm having the same problem with my indicators
Ive tried both CUSTOM and ! in front, CUSTOM Does nothing, ! flashes the indicator quickly on then shuts off.
heres how they are atm
I,268,288,24,24,"!5starindicator"
I,235,288,24,24,"!4starindicator"
I,199,288,24,24,"!3starindicator"
I,165,288,24,24,"!2starindicator"
I,128,288,24,24,"!1starindicator"
And the plugin isnt writing any m3u files in my playlist directory, I pointed it to my directory in rating config
Playlistpath=C:\Program Files\Road Runner\Playlist\
you havent read the readme.txt have you? The playlist path is determined by rr.ini. You MUST have playlistpath defined in rr.ini for it to work. The reason its not writing the m3u's is because u have playlistpath set in the ratingsconfig. As for the indicators, they do work like this
Code:
I,268,288,24,24,"CUSTOM5starindicator"
I,235,288,24,24,"CUSTOM4starindicator"
I,199,288,24,24,"CUSTOM3starindicator"
I,165,288,24,24,"CUSTOM2starindicator"
I,128,288,24,24,"CUSTOM1starindicator"
if they're flashing with the "!" in front i have no idea why. I having nothing in the code telling "!" to work because "!" doesnt work with flash skins. Download the latest version and just copy the skin file over if you want.
