after changing the paths in the scripts and recompile,
there is still something that is forceing it to save all the playlist .m3u files into
C:\Program Files\Road Runner\Ratings
also tried to change the ratingsconfig.ini to my playlist path, but it keeps overwriteing it to this
Playlistpath=default5 stars.m3u
which is in Ratings folder so im assumeing thats why it saves the files there and not where i specified in RR.ini
I actually dont see anywhere where you are reading the playlist path in RR.ini ?
Are you counting the line numbers in RR.ini? If so that may also be an issue as the lines could be in any order, and RR dosent care what order they are in.
I ask this cause i see you have to add the brackets on the first line and i know autoit uses those for section names.
_____________________________________
(after some testing and editing)
I have gotten it to work sort of, it saves the playlist files (still in wrong dir) but now they have data in them, before they were empty but i knew it was writeing to the file from the time stamps.
I think its not finding my playlist file cuz its set to a line number in RR.ini and my playlist= line prob is not on that line.
______________________________________
(some more digging)
ok, i see why it saves the playlist in the wrong dir.
ratewrite.au3 is set to save to musicpath= from RR.ini and not playlistpath=
so now i have it fully working, but i dont see how this would work on anyone elses setup with making those changes.
also i notice, nothing happens when you rate a file as 1 star, files get written for all the other stars except 1star.
looking at your included .skin files
if you move the indicators from ontop of the buttons they will stick.
Maybe set it up so there are numbers on top with a star below.
The numbers can be the actual buttons and the stars below the indicators.
even with my hicups, nice job, ive been wanting this feature for a while.
LinkBack URL
About LinkBacks
