Page 3 of 26 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 252
Thread: Ratings plugin
  1. #21
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    ok, so far everything seems to be working fine.
    Only issue was the 1star.au3 still didnt create a playlist file or anything.
    I took a look at the soucre and compared it to the others and noticed there is a filedelete line that was missing but present in all the others.
    When i added it to 1star.au3 and recompiled then it worked fine.
    other than that, everything else works perfect without any modifications.
    The only real issue i think that's going to comeback and bite you again and again is reading the RR.ini file and requireing the brackets at the first line.
    I completely understand why it has to be there, else autoIT wouldnt read the file properly.
    I thought about asking guino to reformat the RR.ini file to a standard .ini file format a long time ago when i wanted to read and write to RR.ini, but figured i would try to find another way first.
    I think it may be better to just have the user set the paths manually in seperate file, maybe ratingsconfig.ini so you dont have to deal with having to put the brackets back in everytime you save the file from RR.ini
    I take a look also and see if there are any other alternative options for reading and writeing to RR.ini with autoIT
    but as far as everything else, everything seems to be in order.
    Nice Job.
    beer replenishment fund
    mp3car live search
  2. #22
    May 2006
    Good plugin. Just installed and tested it whit freedom skin.
    Works well, but what is this nag window saying TEST and deafult after i rate song?
  3. #23
    Aug 2003
    Chicago
    the test and default pop up is kind of a debug screen that was put in to make sure things were running correctly. The next version i believe will not have this pop up.
    If you pop up says TEST default, then you dont have the plugin setup correctly.
    Open RR.ini and add
    "[]" without quotes! on the FIRST line of the file
    The playlist files should be saved into the dir specified in RR.ini as the playlistpath
    If the plugin cant find the playlistpath= line in RR.ini it will use the default which is the musicpath.
    But if it cant find that, which its prob not if you dont have the brackets in RR.ini it will save the playlist in the same dir as the script files.
    mp3car live search
  4. #24
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Tippa View Post
    whoops thought i took that out updated first post with version without debug msgbox.
    Live mp3Car Facebook Chat
  5. #25
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by liquid_smoke View Post
    Open RR.ini and add
    Thanks for the help again.. today i'm gonna look into a way to do it without the brackets. I do think rr.ini needs the standard format though just to avoid the same problem with other programs.
    I also corrected the 1 star playlist. Thanks!
  6. #26
    Aug 2003
    Chicago
    np,
    Ive been wanting something like this for a while, so im glad to help out anyway i can.
    I see guino is going to make the RR.ini follow standard ini formats, so thats good news.
    mp3car live search
  7. #27
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Too late...
    You can read the so called rr.ini file and pull any info you want from it with it being in any order...been there done that.. I'm sending sonic my snipet to do this...
    you just have to think out-side the box sometimes...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #28
    Woodbridge, VA
    Blog Entries
    32
    new version in first post!
  9. #29
    May 2006
    Tested new version, works great
    Next it is going to the car.
  10. #30
    Woodbridge, VA
    Blog Entries
    32
    might as well wait. I've got the latest version 90% done. Just have to figure a way to remove a song from the playlist.
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
