only for people using lsxvoid RR skin
STEP1:
download the attached file and unzip it into the lsxvoid skins dir, overwrite any existing files.
STEP2:
DONOT copy and paste, these lines already exist , they just need to be found and updated
ExecTBL.ini entries, found in skin dir, not root of RR
Code:
"ONSKINSTART","SETUPMENULABEL01||SETTOPAPPSALL||SETTOPLABELALL||LSONSKINSTART||SETVARBYCODE;ANTISTATUS;STATUS||SETVARBYCODE;curtrack;trackpath"
"RATINGS","MENU;ratings.skin||RunQW;$rrpath$Ratings\ratecheck.exe|$curtrack$"
"ONSONGSTART","SETVARBYCODE;curtrack;trackpath||ratecheck"
"ratecheck","setind;CUSTOM1starindicator;OFF||setind;CUSTOM2starindicator;OFF||setind;CUSTOM3starindicator;OFF||setind;CUSTOM4starindicator;OFF||setind;CUSTOM5starindicator;OFF||SETVARBYCODE;curtrack;trackpath||RunQ;$rrpath$Ratings\ratecheck.exe|$curtrack$"
"ratecheck2","RunQW;$rrpath$Ratings\ratecheck.exe|$curtrack$"
STEP3:
menu and audio player indicators need to be updated.
in "menu.skin" and "audio_player.skin" edit the 5 indicators in these files so the format is like below
before "!5starindicator"
after "CUSTOM5starindicator"
i would just include the .skin files and ExecTBL.ini for you to copy over your existing ones, but my local copies of these files have other changes that are not compatible with the current released version of lsxvoid. So you have to manually update these files till the next full release of lsxvoid.
if anyone has any serious problems doing the manual update of those files, send them to me and ill update them for you and post them back.
I dont have a local copy of the release ver of lsxvoid, only the unreleased update.
if someone wants to post those files, the only files i would need are
menu.skin
audio_player.skin
ExecTBL.ini (found in skin dir)
but the instructions above should be good to follow.
