Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 65
Thread: ScreenLock plugin
  1. #21
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    tested the new one and it works great! thanks
    Now i have to go redo my skin for it. Damn LSX showin me up! lol
    Live mp3Car Facebook Chat
  2. #22
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Got it working too Sweet. I just modified my old background I had for the stevieg's access control panel...
  3. #23
    Low Bitrate frangolfgt's Avatar
    Jul 2006
    Lancs, UK
    @ Liquid_smoke (or anyone who can help)
    i knoticed that you have a button that pauses the music when you open the screenlock screen. I know very little about the commands but I don't understand why this will not work, plz could you help me?
    I have the screenlock as the first skin that comes up when you load roadrunner, so you have to input your code to gain access. I want to do the same sort of thing as you. The difference for me is that when you press exit to exit RR, I get it to pause the music and bring up the exit menu which gives options to hibernate, exit roadrunner, shutdown etc. or you can cancel this screen and go back into roadrunner and it resumes the music. This part works fine with the following code:
    in the skin (call it skin 1) that contains the exit button, after the button size etc., I have:
    "LOAD;exit_menu.skin||PLAY",
    which pauses any music playing at the time and goes into exit menu, which has the following after the cancel button size etc.:
    "CANCEL||RESUME",
    which resumes the music.
    As I have said, the above works fine.
    If I exit roadrunner, open it up again and type the right code in, i want it to resume the music from where it was when it paused it last time roadrunner was open, so i put this into the screenlock skin button:
    "LOCK_ENTER||RESUME",
    which should give access to skin 1
    for some reason, it doesnt resume the music or even play it, but the track timer is reset to zero, so i have to manually press play and it starts the track from scratch. Is there a way around this. (hopefully you will understand my explaination).
    Thanks in advance.
  4. #24
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    in screenlock.ini
    CMD=EXIT||RESUME
    in ExecTBL.ini
    "SCREENLOCK","PAUSE||MENU;ScreenLock.skin"
    in ScreenLock.skin
    use only "LOCK_ENTER" on the enter button code
    beer replenishment fund
    mp3car live search
  5. #25
    Jul 2006
    Lancs, UK
    This doesn't work but it is because my expalination is bad - it just circles between the exit menu and the screenlock screen if I do it that way (i open rr up, input my code, it opens the exit menu, i press cancel, it opens the screenlock screen again and so-on forever until i press exit on the exit menu which shuts down rr). The first screen that comes up when I run roadrunner is a file named menu.skin, but is actually the screenlock skin containing the code entering bit (this is so roadrunner knows to load this skin on opening). after typing the correct code, it opens a file called screenlock.skin, which is actually my main menu (i.e. the file names are just swapped round). (I wonder is there a way to put the names back and get roadrunner to open the screenlock.skin first?) Sorry if this is confusing, it was the only way I could think of. Thanks for answering so quickly.
  6. #26
    Aug 2003
    Chicago
    you can change the file names back around to normal and just use a command to start screenlock when RR loads.
    method one:
    In RRConfig.exe under General Settings>Start Command to execute:
    put your command ("SCREENLOCK") here to load screenlock
    method two:
    In ExecTBL.ini
    "ONSKINSTART","SCREENLOCK"
    after you rename the files back around the code in my other post should work.
    Or you can also change the code around to work for how you have the files named.
    CMD=LOAD;screenlock.skin||RESUME
    but when i think about it, this realy dosent make much since. If you have the screenlock as the first skin that loads (renamed to menu.skin) when you exit it what do you want it to do? resume? and if so how did the music get into the paused state? Or do you want RR to always start with no audio playing, then when you enter the code it plays?
    mp3car live search
  7. #27
    Jul 2006
    Lancs, UK
    Thanks this worked a treat! I thought I needed to pause the music when going into the exit screen and exiting rr so i put play commands on the exit button in the menu skin and cancel button in the exit menu, but these just interfered with it. I took them out and it worked. Thanks very very much
  8. #28
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    It looks like I'm a bit late on this but I just noticed that due to LS skin that I used. I have been using the other script on this forum that locks your screen and also records voice and video if you enter the wrong password. I was hoping LS could incorporate that into the skin but used this one which works great BTW. I love it and really that's all you need. For me I was also hoping that I could record the voice so that I could find out who was tampering with my car (like a mechanic) and what they were doing. Is there a way to get that code and incorporate it into this one?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  9. #29
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @festy: you can intercept the commands as they come through ProcessCommand and change the parameter to "" so RR won't execute any commands that are not from your plugin (while it is still locked), then once the pin has been entered you can execute the exit command and release normal processing of all commands.
    Ride Runner RR's Myspace
  10. #30
    Low Bitrate festy's Avatar
    Jun 2006
    Sydney, OZ
    Of course - I've been trying to work out an easy way of trapping the keypress, but all it needs to do is trap the command the keypress generate.
    This one traps 'cancel' and 'exit' while waiting for a PIN.
    Attached Files Attached Files
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
