Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 65
Thread: ScreenLock plugin
  1. #31
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    I got this to work, but seems intermittent. After locking the system, I can depress the keypad, but the *'s won't read and won't let me enter the access code. Worked initially when I first installed it, but then just stopped and couldn't get it to work again. I've tried re-installing, but still doesn't work. I used the files in the attached zip w/ the following commands in the screenlock.ini file in RR.
    PIN=1234
    CMD=Play||EXIT
    TIA!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  2. #32
    Aug 2006
    Hi, I have the same problem like yours just the other day. I think it's got something to do with your DLL files. You should not delete the file after you registered it. Just keep it somewhere safe (like in the windows directory) and register it again. Should work though...
  3. #33
    Aug 2006
    Sun Diego
    I moved the .dll file into the RR directory and seems to have fixed it.
  4. #34
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Festy - This app works very well indeed, however when i have now music playing (as i pause this when the lock screen is loaded), when i press a button RR actually speaks it.
    So it actually says for pin 1234 followed by the enter key "LOCK UNDERSCORE 1, LOCK UNDERSCORE 2, LOCK UNDERSCORE 3,LOCK UNDERSCORE 4,LOCK UNDERSCORE ENTER"
    Is there a way of stopping this as it could cause a problem if i try and hide the enter of the pin and RR says it aloud.
    Many thanks.
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  5. #35
    May 2005
    Yes, when there are no music playing, pressing the keypads actually causes RR to speaks it. Which is a pain like what Tissy has mentioned. Can this be fixed? Thanks.
  6. #36
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    turn off voice in RRConfig
    beer replenishment fund
    mp3car live search
  7. #37
    Sep 2005
    That is one option, but you then loose it in any other apps.
    I think it is a slight fault with the plug-in as it "says" everything that is pressed. Not a good security feature as illustrated above.
    Perhaps Festy can look at the code to get rid of this feature / bug ?
  8. #38
    May 2005
    Yeah, I wouldn't mind if it just says "ZERO" when I press the 0 button. But instead it is adding the prefix (and saying it) "LOCK UNDERSCORE" to every button you pressed
  9. #39
    Low Bitrate festy's Avatar
    Jun 2006
    Sydney, OZ
    It's not a fault with the plugin - RR 'says' any command, before it gets handled by a plugin or anything.
    I spent a couple of hours reading the RR source yesterday trying to find a way to disable voice... I'll keep working on it.
  10. #40
    May 2005
    Thanks for the update. Hope you find the fix soon
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 12:32 PM
  2. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 10:07 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 05:10 PM
