Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 65
Thread: ScreenLock plugin
  1. #41
    FLAC djmickyg's Avatar
    Feb 2004
    hi,
    i would like to use this plugin with the LSXVOIS skin..
    but..
    in my ExecTBL.ini file i have ONSUSPEND,"MAIN"
    i only want to use the lock screen when i park in certain area's, but having the above code brings back the menu without having to put the pin in,
    i spose this is same as pressing the ESC key, is there a way to disable this also?
    thakns
  2. #42
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Is there a way to Make this work so that when I enter a specific pin number it will execute a corresponding command?
    I want to password protect the ability to exit RR as well as password protect the skin chooser menu and other RR features.
    New Age Garmin - Skin for RR
  3. #43
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    usually, i use a standby mode like, something like audio off, and from there a lock the system, "MUTE||LOCK", so when i unlock the system, the command executed will be unmute and some other things.thats how i avoid this speech issue.what i would like is a command for WRONGCODE=
  4. #44
    Nov 2005
    Is it possible to use a gesture to unlock the screen instead of code?
    Proposed process:
    (Gestures are in the OFF state)
    Press the lock button/autolock (locks the screen and turns mute ON and gestures ON)
    if correct gesture is detected it unlocks the screen (perhaps the gesture issues the correct pin to the keypad?)
    As the unlock is issued it unmutes RR and turns gestures OFF.
    If so, the keypad can be replaced with a lock/combination lock picture and no keypad .. will be almost impossible to get into without knowledge of what to do
    Each incorrect attempt shows a little lock picture flash onscreen.. so you can see that the system is responding. So people dont just bash away at the screen
  5. #45
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    should be already able to do that.
    Just define some querky gestures to four numbers and then have that as your pin code.
    then design a skin jpg for that screen without the numbers.
  6. #46
    Nov 2005
    sweet!
    Can a single gesture be assigned to 4 numbers, rather than 1 gesture for each?
  7. #47
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    well if you look at the gestures.ini under global commands, they have a command with a gesture. I just wonder if you can put, say "1234" and then the directions of the gesture.
  8. #48
    Newbie superman_sean's Avatar
    Jan 2006
    Oklahoma
    Issue
    I have also posted this in the LSVOID skin form, just in case its a skin issue and not a plug in issue.
    I have the screenlock appear on startup, but once I unlock and then try lock the screen, RR freezes. tried this on both my test machine and my car pc.
    Any ideas ???
  9. #49
    Low Bitrate festy's Avatar
    Jun 2006
    Sydney, OZ
    There's a new version attached to the first post.
    This is a major rewrite, ScreenLock's usage has changed and existing skins will need some modification.
    There's also a couple of new features like muting audio, failed PIN notifications and commands etc, but this version is mainly a bugfix.
    As always, feedback and bug reports are appreciated.
  10. #50
    EL CAMINO's Avatar
    Jul 2005
    great news checking out now, thanks again!!!
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
