I can get nothing to work with this screenlock. I tryed my skin, nothing, I tryed DFX3.0, nothing. The DLL is registered (so it say's), if I call the command "LOCK_START" nothing comes up. Is there a trick to it?
Tried the new version and after logging in with the wrong password it does log 1, but if I try the correct password it will not exit. Also the FAILCMD wouldn't work. I have attached the my debug.txt Hope this helps![]()
Why buy it if you can build it? Even if it cost twice as much to build.
Well, 8 days and now answer ? Must be then, just bumping.
Try access control![]()
Just uploaded the locker script I've been using for quite a while. Seems to work fine for me.
locker
CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
MediaLaunch for RR
Online Check for RR
Locker for RR
did anyone ever get the FAILCMD function to work on this plugin ?
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
i dont know which one to get,
but one i downloaded from the URL
is bugged
KILLS "IDLE"
.ScreenLock-0.5 is FINE at least with IDLE
the bug is in processcommand()
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
hey i'm from sweden so my english isn't verry good. but i hope you do understand me.
I can't get the screenlock to work, i putted register.bat, screenlock.dll and screenlock.ini i my roadrunner dir. I runned register.bat and it says that it did success.
And than i put my screenlock_on.jpg, Screenlock_off.jpg, screenlock_down.jpg and screenlock.skin i my skin folder.
than i added (X,screenlock) under (IDL ,300) and
B22,116,66,570,284,"load;screenlock.skin"
in my menu.skin file
when i press the button the screenlock pops up but when i press the numbers it doesn't pop up any " * " and i can't login.
please can somebody help me
/Mathias
I can't even get mines to work on DXF3 Followed all instructions in the readme file. Just can't figure where to put the Buttons:
Buttons:
LOCK_0 - LOCK_9 buttons for the numbers 0 - 9 for entering PIN
LOCK_CLR button to clear entered PIN
LOCK_ENTER button to attempt unlock with entered PIN
LOCK_START button to load ScreenLock
Labels:
LOCK_PIN label containing *'s corrisponding to the PIN being entered
LOCK_FAILS number of incorrect PINS entered since last unlock
Indicators:
LOCK_ATTEMPT indicator true if unsuccessful PINS were entered
ScreenLock.ini:
LOCK_CMD cmd to load Screenlock skin
PIN PIN ie. 1234
CMD RR cmd to be executed on successful PIN, set to 'exit' to return to previous screen.
FAILCMD RR cmd to be executed on incorrect PIN entry.
MUTE seconds to mute audio for while a PIN is entered
Code at. Can anyone HELP PLEASE!!! Thanks
Thread is getting old, but is there a way to make the pin a variable, say using the date as DDMM? Such as today being the 10th of december, the pin would be 1012.
would be handy as if anyone saw you put in the pin, it would be different the next day.
