Page 1 of 7 1234567 LastLast
Results 1 to 10 of 65
Thread: ScreenLock plugin
    Low Bitrate festy's Avatar
    Jun 2006
    Sydney, OZ
    ScreenLock plugin
    ScreenLock Plugin
    ScreenLock attempts to prevent unauthorized access to RoadRunner,
    by requiring a PIN to execute a chosen function.
    The main intended use is to lock the screen while unattended.
    It can also be used to prevent unauthorized access to components,
    for example launching RRConfig.
    When ScreenLock is activated, commands including EXIT and CLOSE are
    disabled, which prevents backing-out of the lock.
    0.5.0 - 8/2/08
    This is a major rewrite, and ScreenLock's operation has changed.
    *** The plugin is now loaded from menu.skin, not the lock skin.
    ScreenLock is called with the command 'LOCK_START', which will then
    execute LOCKCMD from screenlock.ini.
    An example of LOCKCMD might be "LOAD;Screenlock.skin".
    This release also includes new features for executing an RR cmd on failed PIN,
    muting speech and notofocation of failed attempts.
    See the README.txt for more details and examples
    Attached Files Attached Files
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    cool!
    busy man arent you
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    this isnt working for me. The .dll is registered, screenlock.ini is in C:\program files\road runner and the skins are installed in my freedom skin folder. I use load;screenlock.skin to present the screenlock screen. type in my pin listed in the .ini and hit enter. after hitting enter the *'s go away but it doesnt go thru with the command listed in the second line.
    Live mp3Car Facebook Chat
    Jun 2006
    Sydney, OZ
    What command are you trying to execute? I tested it with a couple of different commands, but can't say I spent a lot of time testing. If you're getting the *s then the dll is obviously loading ok.
    Does it work if you just have exit on the second line? (no quotes around it)
    Woodbridge, VA
    Blog Entries
    55
    i tried PHOCO, then i tried it with EXIT.. didnt make a difference.
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Does not work for me. See the *'s go away but nothing happens. Like to have working tho
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
    Jun 2006
    Sydney, OZ
    There's a new version for download now from http://www.festy.org/files/ScreenLock.zip - this one's a little bit smarter...
    If it still doesn't work, try adding a blank like to screenlock.ini under the command to execute.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    works good for me, nice job
    beer replenishment fund
    mp3car live search
    Woodbridge, VA
    Blog Entries
    55
    works for me too now.. Thanks!
    Aug 2003
    Chicago
    one issue i just found, is in the screenlock.ini the command to execute when the correct password is given. The commands only work if its a single command and dosent recognize custom commands from ExecTBL.ini
    Im trying to use RESUME||EXIT
    In my button that goes to the screenlock screen i have a pause so it pauses the music when the screen is locked.
    mp3car live search
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
