Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 60
Thread: PowerMon plugin - for laptop carpcs
  1. #41
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    A good plugin will have a register.bat file which you just click on.
    Failing that create a text file (register.txt)
    type in
    regsvr32 name of plugin
    and save it in the plugins folder
    rename to register.bat
    double click
    so if a plugin dll was called powermon.dll you would enter the following in the text file
    regsvr32 powermon.dll
  2. #42
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    I may have missed a step here.
    I created a text file called register.txt
    Opened up the text file and wrote regsvr32 powermon.dll
    Saved it in plugins folder
    renamed folder to register.bat
    Right clicked, then selected "register"
    Then I get a weird massage saying something like
    "The module (Bunch of chinese letters) failed to load. Make sure the binary is stored in the specific path or debug it to check for problems with the binary or .dll files. The Specific binary could not be found.
  3. #43
    Low Bitrate festy's Avatar
    Jun 2006
    Sydney, OZ
    Quote Originally Posted by Startingline13 View Post
    try just double-clicking on register.bat.
  4. #44
    Nov 2007
    Long Island, NY
    Same thing.
  5. #45
  6. #46
    Nov 2007
    Long Island, NY
    The North American Version of Vista 32. That's why I can't understand why it is coming up with Chinese symbols.
  7. #47
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ah! vista, you need to be running in XP compatability mode I believe as Vista doesn't like some VB6 runtimes. (at least I think that is it)
  8. #48
    Nov 2007
    Long Island, NY
    Ahhh, have to love Microsoft
    Ok I'll try that out when I get home a bit later.
  9. #49
    Nov 2007
    Long Island, NY
    I've been searching for ways to run this in compatibility mode but have come up with nothing. It seems you can only run specific programs in compatibility mode, and not something such as a .dll
  10. #50
    Low Bitrate docbreezy's Avatar
    Feb 2008
    Maryland
    Nice lil plugin. I actually got it to work first time with no hitch. Now i can see whats happening in the trunk from up front. So now i woul like to explore a bit further
    1. would it be possible (from rr) to monitor the power source, whether battery or external and then execute a command (Lets say, hibernate) when source changes from external to battery.
    2 what would that command look like? (Maybe using that BYVAR command??)
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 06:20 PM
  3. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
