Originally Posted by
festy
Can you test this one for me? I went back and re-read your previous posts, then I actually understood what you were saying - and you're spot on, it's the comma causing the problems.
I can replicate what you were seeing easy enough.
I didn't realise VB's input # function treated commas in the read string as a delimiter. I've switched to pipes in tripmeter.ini in this test dll, hopefuly it will work for you.
This one's version is 0.5.0.37 if you're having caching problems
Nice... I'm stuck at work right now but I'll try it on the way home, your last update worked great anyway, it starts with RR now... I'll get bacj to you later today if it worked or not!
[edit]
Well it didn't work
, I still get the same strange numbers after shuting RR down once and then going to the tripmeter screen.
Code:
25,5734605188611
25,4936885519087
That's what I have in my tripmeter.ini file, the first line is the total & trip distance and the second one is what I logged as "work". in the tripmeter skin I only see:
Total: 25
Trip:0
Work: *60518*, * is some more numbers that doesn't fit.
thanks for the try anyway!
