Page 22 of 53 FirstFirst ... 121314151617181920212223242526272829303132 ... LastLast
Results 211 to 220 of 528
Thread: Needed: BETA Testers for Google Earth Plugin
  1. #211
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    it closes most of the time.. but it seems like a few times i had it hide itself behind rr with the gps dialog box up too
    Live mp3Car Facebook Chat
  2. #212
    May 2006
    working dll and RoadRunner.exe ???
    hi guys,
    reading through this whole thread and trying everything, it didnt work,
    so can anyone post his WORKING rrearth.dll and Roadrunner.exe,seems that
    the old version of this dll is working, but i cant find the old one.
    i tried all of the available dll's in this thread.
    in the debuf i can see
    11.11.2006 16:22:31: Error loading plugin: RREarth (Type mismatch)
    thanks a lot, this plugin is great !!!!!!
    enzo
  3. #213
    Woodbridge, VA
    Blog Entries
    32
    you usually get that error when you dont have all your skin files in the directory.. which skin are you using
  4. #214
    May 2006
    hi,
    thanks for your answer, i'll try this with BMV2
    i added x,rrearth to menu.skin at the bmv2 skin folder.
    also copied the skin files from the rrearth folder to bmv2 skin folder.
    i think i've set all but the error-message is the same.
    which command must be set in the exectbl.ini ????
    many thanks for your help
  5. #215
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try this DLL: http://www.rrdownloads.net/BETA/RREarth.dll -- then post c:\rrearth.txt (it will create it). I would also recommend you run the RR beta in the same site/folder above.
    Ride Runner RR's Myspace
  6. #216
    May 2006
    hi guino,
    thanks for helping in this issue:
    message changed in debug.txt since installing your new dll.
    also switchd to freedom skin.
    sorry i've no rrearth.txt, maybe because of my root disk is not C: it's I:
    12.11.2006 16:07:22: Start -- Version: 11.11.2006
    12.11.2006 16:07:22: Master Vol: Volume Control/4
    12.11.2006 16:07:22: GetLineControl Failed: 401
    12.11.2006 16:07:22: No Treble Support
    12.11.2006 16:07:22: No Bass Support
    12.11.2006 16:07:22: No Master ON/OFF
    12.11.2006 16:07:22: Source: Wave=&H1008/1
    12.11.2006 16:07:22: Source: SW Synth=&H1004/2
    12.11.2006 16:07:22: Source: BassBoost=&H100A/3
    12.11.2006 16:07:22: Source: CD Player=&H1005/4
    12.11.2006 16:07:22: Source: Microphone=&H1003/5
    12.11.2006 16:07:22: Source: Aux=&H100A/6
    12.11.2006 16:07:22: Source: Line In=&H1002/7
    12.11.2006 16:07:22: Source: Phone=&H1006/8
    12.11.2006 16:07:22: Source: Mono Out=&H100A/9
    12.11.2006 16:07:22: Source: Wave=&H1008/10
    12.11.2006 16:07:22: Can't Open Source
    12.11.2006 16:07:22: No Mute for Source
    12.11.2006 16:07:23: Winamp window not found.
    12.11.2006 16:07:23: Shell: "I:\Program Files\Winamp\winamp.exe" /CLASS="Winamp v1.x"
    12.11.2006 16:07:24: Error loading plugin: RREarth (Automation error
    ClassFactory cannot supply requested class )
    12.11.2006 16:07:24: Enter Exec: False, menu.skin, , False
    12.11.2006 16:07:24: Que Exec: True, menu.skin, "gesturesoff", False
    12.11.2006 16:07:24: Executing: gesturesoff
    12.11.2006 16:07:24: Que Exec: True, menu.skin, "run;$skinpath$colour.EXE;", False
    12.11.2006 16:07:24: Executing: run;J:\rr\skins\Freedom 2.1\colour.EXE;
    12.11.2006 16:07:24: Shell: "J:\rr\skins\Freedom 2.1\colour.EXE"
    12.11.2006 16:07:24: Que Exec: True, menu.skin, "stop", False
    12.11.2006 16:07:24: Executing: stop
    12.11.2006 16:07:24: Leave Exec: False, menu.skin, stop, False
    12.11.2006 16:07:25: Enter Exec: False, menu.skin, , False
    12.11.2006 16:07:25: Que Exec: True, menu.skin, "ONSONGSTART", False
    12.11.2006 16:07:25: Executing: ONSONGSTART
    12.11.2006 16:07:25: Leave Exec: False, menu.skin, ONSONGSTART, False
    12.11.2006 16:07:26: Enter Exec: False, menu.skin, , False
    12.11.2006 16:07:26: Que Exec: True, menu.skin, "ONSKINSTART", False
    12.11.2006 16:07:26: Executing: ONSKINSTART
    12.11.2006 16:07:26: Leave Exec: False, menu.skin, ONSKINSTART, False
    12.11.2006 16:07:27: Enter Exec: False, menu.skin, , False
    12.11.2006 16:07:27: Que Exec: True, menu.skin, "run;$skinpath$/AutoNetDetect/AutoNetDetect.EXE;", False
    12.11.2006 16:07:27: Executing: run;J:\rr\skins\Freedom 2.1\/AutoNetDetect/AutoNetDetect.EXE;
    12.11.2006 16:07:27: Shell: "J:\rr\skins\Freedom 2.1\/AutoNetDetect/AutoNetDetect.EXE"
    12.11.2006 16:07:28: Leave Exec: False, menu.skin, run;J:\rr\skins\Freedom 2.1\/AutoNetDetect/AutoNetDetect.EXE;, False
    12.11.2006 16:07:30: Enter Exec: False, menu.skin, , False
    12.11.2006 16:07:30: Que Exec: True, menu.skin, "play", False
    12.11.2006 16:07:30: Executing: play
    12.11.2006 16:07:30: Leave Exec: False, menu.skin, play, False
    12.11.2006 16:07:40: Enter Exec: False, menu.skin, , False
    12.11.2006 16:07:40: Que Exec: True, menu.skin, "LOAD;status.skin", False
    12.11.2006 16:07:40: Executing: LOAD;status.skin
    12.11.2006 16:07:41: Que Exec: True, status.skin, "gesturesoff", False
    12.11.2006 16:07:41: Executing: gesturesoff
    12.11.2006 16:07:41: Leave Exec: False, status.skin, gesturesoff, False
    12.11.2006 16:07:42: Enter Exec: False, status.skin, , False
    12.11.2006 16:07:42: Que Exec: True, status.skin, "LOAD;gpsfull.skin;$gpsname$;$gpspath$;$gpsnam e$", False
    12.11.2006 16:07:42: Executing: LOAD;gpsfull.skin;FreeDrive;C:\Program Files\FreeDrive\FreeDrive.exe;FreeDrive
    12.11.2006 16:07:43: Enter Exec: True, gpsfull.skin, , False
    12.11.2006 16:07:43: Shell: "C:\Program Files\FreeDrive\FreeDrive.exe"
    12.11.2006 16:07:43: Que Exec: True, gpsfull.skin, "gesturesoff", False
    12.11.2006 16:07:43: Executing: gesturesoff
    12.11.2006 16:07:43: Leave Exec: False, gpsfull.skin, gesturesoff, False
    12.11.2006 16:07:47: Enter Exec: False, gpsfull.skin, , False
    12.11.2006 16:07:47: Que Exec: True, gpsfull.skin, "main", False
    12.11.2006 16:07:47: Executing: main
    12.11.2006 16:07:47: Leave Exec: False, gpsfull.skin, load;menu.skin, False
    12.11.2006 16:07:54: Enter Exec: False, menu.skin, , False
    12.11.2006 16:07:54: Que Exec: True, menu.skin, "quit", False
    12.11.2006 16:07:54: Executing: quit
    12.11.2006 16:07:55: Winamp window not found.
    12.11.2006 16:07:56: Shutdown
  7. #217
    guino's Avatar
    Nov 2004
    Toronto, Canada
    doesn't seem like you've ran regsvr32 on the DLL -- this is on the readme.txt install instructions. Follow the steps in there and try again.
  8. #218
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Guino: Here are my logs from the current version of RREarth.dkk/RoadRunner.exe from the beta site. I ran RR in BMV2, launched RREarth, opened the menu, gave it and address, hit fly-to (nothing happened), gave it another address, hit fly-to, directions, tour, etc. (nothing happened), hit clear on the top address (changed to "GPS Position"), moved the map, hit fly-to on the address (nothing happened), hit fly-to on GPS Position (it did move the map back to the GPS Position), exited.
    I deleted the logs before that test run.
    Also, thar version forced the left-nav bar open instead of closed (and would not let me close it). I would eventually like to have RREarth working (including all the fly-to/direction buttons) with center-on-gps dissabled on startup, and with the Left-Nav bar forced closed once on start-up, but allowed to be opened by sending Ctrl-Alt-B. Then I will be able to make a very full-featured Google Earth screen using RREarth and GooPs.
    Thanks for looking in to this.
    Thanks for looking in to it.
    Attached Files Attached Files
  9. #219
    Apr 2006
    Don't know what I am doing wrong, followed the instructions but rrearth does not show up
    1. Installed Google Earth 4 to the standard installation path
    2. Unzipped the .zip in the RR dir, replaced rr.exe
    3. Registered the dll.
    4. Added the skin files to my skin dir
    5. Added X,RREarth to menu.skin
    6. Added B09,420,562,93,38,"GE_START",GE_START
    If I click the button nothing happens
    I tried "LOAD;RREARTH.skin","RREarth", this works but only shows the skin... nothing running in there.
    What else could be wrong? Went through nearly the whole thread here, and someone mentioned rrearth.exe, which i don't have... what's that?
  10. #220
    Woodbridge, VA
    Blog Entries
    32
    rrearth.exe is not used anyone it was the actual plugin prior to being converted to a dll. Have you run GE in standalone to insure it works?
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 12:24 PM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 04:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
