Page 35 of 54 FirstFirst ... 252627282930313233343536373839404142434445 ... LastLast
Results 341 to 350 of 532
Thread: Needed: BETA Testers for Google Earth Plugin
  1. #341
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    I use it in a Jetway C7 1.5ghz mobo & processor & it works fine. Initially, it didn't work & there was a blocky polygon problem, but they updated their drivers & now it is as smooth as a hot knife in butter!
    Quote Originally Posted by xpluis View Post
    Its time to change of mobo and procesor (actualy I have P4 2.2ghz) and works exelent but mobo are big and its power expensive. Dual core are money expensive and my election can be Jetway c7 2.0ghz System. But my principal fear is earth plugin work fine.
    Google earth can work fast and good in a Jetway c7 2.0ghz mobo?
    2001 PT Cuiser
    VoomPC with 1.5Ghz C7
    M2 power supply
    in dash slim tray dvd drive
    DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
    See my install here
  2. #342
    May 2005
    Vienna, VA
    Is there a command to toggle on/off autozoom?
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  3. #343
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by b8bboi View Post
    Because of how the integration with GE works, I can't update the gps position without loading a view to it (it is possible but it would require deleting/re-adding the link inside GE -- this stuff tends to break and be unstable).. if you don't want to zoom center to a location, you can turn off the GPS view .. or if you just want a specific zoomed out view, you can write a zoom ini file and load it so it zooms to the desired level at any speed.
    Ride Runner RR's Myspace
  4. #344
    Jul 2006
    are there any skins that implement this natively? i am a new rr user (debating the switch from cf) and have downloaded simplistique, iphone, and FU. any way to get this to run inside of those skins?
  5. #345
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can add this to any skin. If it doesn't already have a screen made for it, you can either make one or just use the default red/black one provided. I know there are some skins with screens made for it..
  6. #346
    Jun 2002
    Virginia
    Quote Originally Posted by hari-bhari View Post
    DigitalFX has a skin for it. You still need to reassign a button to launch it, but it's really very easy to do.
  7. #347
    Jan 2007
    2 guino:
    First of all - thanks for this great plugin!
    I noticed one issue. I'm Russian user of RoadRunner. And here is one problem because of Russian regional setting in Windows.
    i saw the "GPS.kml.ini" file, it' ok with it - let's look at this line:
    <coordinates>[GPSLON],[GPSLAT],0</coordinates>
    in USA and europe Regional settings the separator in numbers is "." so in GPS.kml-file this line will generated as
    <coordinates>-90.86948943473118,48.25450093195546,0</coordinates>
    the goole will understand it.
    But with Russian regional settings the separator is "," and the line will generated as:
    <coordinates>-90,86948943473118,48,25450093195546,0</coordinates>
    loook at the commas! and the goggle will not understand coordinates of the label.
    we will see the right view because of this section will be OK:
    <LookAt>
    <longitude>-90,86948943473118</longitude>
    <latitude>48,25450093195546</latitude>
    <range>305,8880792294568</range>
    <tilt>46,72425699662645</tilt>
    <heading>331</heading>
    </LookAt>
    but the Label will be in another place and we won't see it.
    Hope you understand situation. maybe you will fix the plugin for the write the numbers with dots, not commas.
    And another question - is there a button code for temporary disable GPS.KML-file updating in google? Sometimes i need manually rotate a globe to see another location, but i can't do this because it quickly return back to GPS location.
  8. #348
    Jul 2006
    i tried to get the plugin to work with the iphone skin by modifying the following code in the menu.txt:
    &mainbut9=GE@icons/gps.png@LOAD;RREARTH.skin;GE_START
    i also added 'X,RREarth' to the end of the menu.skin file.
    when i click the GE icon in the skin, if i dont have GE running in the background beforehand, the GE skin pulls up (which i have copied into the iphone directory) but GE doesnt embed. If i load up GE beforehand and then load the plugin, GE embed only after i hit the menu button. However, GE does not respond to any of the buttons in the window except the 'toggle GPS' one which seems to get stuck halfway across the world (since I dont have a gps receiver at my test bench) and i can't untoggle it.
    i also copied the rest of the rrearth files into the road runner directory (inside their own subfolder), and ran the rr.bat file to register the dll. do these files need to be moved into the directory of the skin, or the root of rr?
    i am assuming that i am just embedding this plugin all wrong, but this is my first time playing with RR. is there a general guide anywhere on how to use the commands for button actions and loading up plugins? i didnt see one in the FAQs
    EDIT:
    i got rid of the rrearth.skin and load commands from the menu.txt file and it loads it up properly now with the skin and all. the toggle gps button seems to work, but the fly to button does not...
  9. #349
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @hari: you have to enter an address first to use the fly to button -- is that what you're doing ? You also need to have working internet for it to work.
    @Nimar: It's easy to make it always write . instead of ,
  10. #350
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @Nimar: try the new DLL in www.kompassist.co.uk/BETA/
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-10-2005, 11:39 PM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 11:24 AM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 03:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 03:54 AM
