Guino...is the rrearth download link dead? I tried to download it (off the first page of this thread) and it downloaded an 11kb empty zip file.
post the contents of net.kml and tell me what regional settings (language/locaiton) you have setup in Control Panel.
Ride Runner RR's Myspace
see post #350 of this thread.
Net.kml contents:
<NetworkLink>
<name>RR Earth - GPS</name>
<open>0</open>
<flyToView>1</flyToView>
<Url>
<href>C:\VBStuff\RREarth\GPS.KML</href>
<refreshMode>onExpire</refreshMode>
<viewRefreshMode>onStop</viewRefreshMode>
<viewRefreshTime>0</viewRefreshTime>
</Url>
</NetworkLink>
language: english
region: us
Guino,
which is the correct .dll to use, the one in the z'd file or the one that on its own?
Hi there,
I am using LSXVOID 3.2 skin. Running IGuidance 2.1 Europe and GG Earth 4...
Got both of them integrated in the skin and working fine. (downloaded latest rrearth.dll (post #350), placed it in LSX void folder and registered it)
When I am in the GPS screen in Lsxvoid, I can switch between IG map view and GGErath view.
IG shows my position, but GG just shows the planet and don t move. Isn t is suppose to locate where I am? What did I miss in the set up?
you probably need a port spliter like xport3 so RR and IG can both read the GPS at the same time.
OK thanks. Got Xport3.
I have IG working on 15 and RR working on 16. Got it working in a way.
When in LSXVoid, in NAV menu (IG2), if I click SAT view, I have this google message saying i need to be a GE Plus suscriber to do that, open explorer , etc...
But seems I can use the GE button on the side ( in lsxvoid GPS skin) instead .
Last thing, I was able to set up the level of zoom in the GGE options, but I don t see where I can set the angle of the view.
Many thanks
1-There's probably a difference in the code/skin used for the two buttons.
2-You can set the default tilt angle in the GE_START command, or you can make buttons to set the tilt angle while GE is running -- this is described in skin commands.txt of the plugin.
ive got the same parse error as mentioned above using lsx void 3.2. i had it working fine on my machine before, im not sure what happened on this new one. am i supposed to register any dlls? is it because i ran it the first time without any gps receiver connected? now im not really sure what to do...
