Page 43 of 54 FirstFirst ... 333435363738394041424344454647484950515253 ... LastLast
Results 421 to 430 of 532
Thread: Needed: BETA Testers for Google Earth Plugin
  1. #421
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have a test version for GE5 - if anyone wishes to try it, PM me.
    Ride Runner RR's Myspace
  2. #422
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    09/28/09
    Quote Originally Posted by guino View Post
    I messed with GE5 quite a bit yesterday, and it's requiring to almost to re-write the whole plugin, but let's see how far it gets..
    09/29/09
    Guino... you never cease to amaze me! ! ! ! !
    My Fiero Build Thread
  3. #423
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Test plufin Google Earth V5
    Ok Guino,
    Thanks for your dll . I had created a skin for this plugin and GE5 is very well embedded .
    The menu run very well tilt + and - , gps on/off also .
    I think that my skin file is incomplete (button don't run)
    I upload my files here with probably bugs or error .
    Attached Files Attached Files
  4. #424
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I've just tested it with LSX Void 3.0.
    GPS on/off does not work, but it was embbeded perfectly. It only shows a snag screen if you're not connected to the internet. I went to a farm location, expecting my 3g connection to drop but it didn't so I was dowloading maps as I needed, and it looked much faster than with version 4.xx (as google claims see release history above). I even filmed it a little bit, I may post a video later if I have the time. (Can I post .mov files here or people use utube?). It was loading images seemlessly, I was impressed. Before, it was like slowly gaining details, it looked instant.
    Do you have your config files regarding zoom, tilt, speed, etc. I'll look for them in this thread again. My settings were optimized for my previous config, where the images were coming slow, so I use little zoom, constant height, less tilt, etc. I'll try a full blown show with rotation and zoom in and out at different speeds, etc. Overall it's a much better experience.
    It did not work with DFX4.0 though, it was just showing the background picture and GE didn't even start in the background.
    I tried fly to it did work a bit, but since it was always returning to GPS mark, I didn't get too far. Tilt worked fine.
    I'd like to have buttons to turn on and off street view, traffic etc, is it possible, or is this a skin related feature?
  5. #425
    guino's Avatar
    Nov 2004
    Toronto, Canada
    A Few notes for you beta testers.
    -GE5 does NOT have a "stop" button for the tour, so it's the same as "ge_showroute" right now.
    -Open GE OUTSIDE (with RR CLOSED) and select the layers, tour speed, and nav speed there -- that's what will be used in RR (I recommend making them faster).
    -Open GE OUTSIDE (with RR CLOSED) and MAKE SURE that you don't have "RR Earth - GPS" saved under "my places" - if so, delete it (or you won't be able to turn GPS ON/OFF)
    -GE5 roadmode doesn't look as good as in GE4 (it's a bit faded).
    -Yes, it does seem a lot faster (specially on my ond machine here)
    -Yes, GE 5 is very *****Y about no internet connections -- instead of showing 1 popup it shows at least 3 in different times.
    It should be very simple/easy to make commands to turn off/on layers in the map.
  6. #426
    May 2008
    Bordeaux, France
    My little contribution
    I had modified the .png and skin file (errors)
  7. #427
    Dec 2007
    Danville, CA
    Quote Originally Posted by pierrotm777 View Post
    Sorry, I'm having trouble updating my exectbl file. How can I add this RREarth skin to the dynamic menus?
    Thanks!
  8. #428
    May 2008
    Bordeaux, France
    Quote Originally Posted by RipplingHurst View Post
    Thanks!
    Upload your exectbl.ini file or pm me your exectbl.ini file and i see you want you must to do .
  9. #429
    Dec 2007
    Danville, CA
    PM sent, but I can't attach there.
    So here is goes.
    Thanks.
  10. #430
    May 2008
    Bordeaux, France
    So here is goes.
    Thanks.
    Please added the red words in your exectbl.ini file:
    Code:
    /, This (OPTIONAL) file contains translation commands.
    /, RR will accept the commands defined on the LEFT
    /, and execute them as expressed on the RIGHT
    /, you can use this to create or redefine any command
    /, (or to add functionality to any syandard command).
    /, The Format of this file is (by choice):
    /, "<COMMAND>","<EXEC COMMAND>"
    /, "<COMMAND>","<EXEC COMMAND>",filename.skin
    /, Examples:
    /, "AUDIO","LOAD;audio_player.skin;Audio Player"
    /, "RESTARTSONG","SEEKTO;00:00",audio_player.skin
    /, Extas:
    /, XM, FM and MM can be used instead of a skin file
    /, to be translated when XM, FM or MM is turned ON.
    /, PLAY, PAUSE and STOP can be used instead of skin
    /, file name so it executes commands based on MP3 or
    /, Video playback status.
    /, You can add commands to execute before suspend
    /, and after resume, using the codes bellow:
    "IDLE","CANCEL"
    "ONBTNPRESS","PlayWAv;$RRPath$button1.wav"
    "ONBTNHOLD","PlayWAv;$RRPath$button2.wav"
    "CHANGEBG","SETVARBYCODE;BKGNDPOS;LISTPOS||SAVETOSKIN;BKGND;$BKGNDPOS$||SETVARBYCODE;BKGND;LISTTEXT||SETVAR;BACKGROUND;$backgroundspath$\$BKGND$||SAVETOSKIN;BACKGROUND;$backgroundspath$$BKGND$||RELOADSKIN||Load;bg_browser.skin||SETLIST;$BKGND$"
    / ------------------   Change iList settings in the skin   ----------------------------
    "TurnOffiLists","ESC||OneMomentPlease||SAVETOSKIN;usedx;false||SAVETOSKIN;iListStatus;Off||RELOADSKIN||Load;SkinSettings.skin"
    "TurnOniLists","ESC||OneMomentPlease||SAVETOSKIN;usedx;true||SAVETOSKIN;iListStatus;On||RELOADSKIN||Load;SkinSettings.skin"
    "OnSkinStart","SetApps||SetCommandLabels01||SetAppLabels||SetIcons||$default$"
    "CAMERA","LOAD;RRCam.skin;;$skinpath$\..\..\RRCam\RRCam.exe;RRCam.exe"
    "COVERFLOW","LOAD;COVERFLOW.SKIN"
    "GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL.skin"
    "GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK.skin"
    "X_OVERLAY","SENDMSG;ElcosMenu;Exit"
    "GMPC","LOAD;GMPC.skin"
    "RUNGMPC","RUN;$garminpath$;!CDP",GMPC.skin
    "IGLINKS","RUN;$skinpath$CWiG.exe||GPS"
    "GASNAV","GPS"
    "ONFILECLICK","SETVARBYCODE;imagefilename;LISTTEXT",bg_browser.skin
    "UPDATE_IMAGE","SETVARBYCODE;imagefilename;LISTTEXT"
    "RRTCSEARCHING","menu;tc_loading.skin",trafficcam_search.skin
    "RRTCDONE","ESC",tc_loading.skin
    ****************** RRGAS **************************
    "RRGASSEARCHING","menu;gas_loading.skin",gas.skin
    "RRGASDONE","ESC",gas_loading.skin
    ****************** RRPETROL **************************
    "RRPETROLSEARCHING","menu;petrol_loading.skin",petrol.skin
    "RRPETROLDONE","ESC",petrol_loading.skin
    /, For MediaCar Compatibility only:
    "AUDIONEXT","RRNEXT"
    "AUDIOPREV","RRPREV"
    /-----------------  Dynamic Menu Buttons -----------------------
    /----- Pre-setup the Applications and labels into arrays -------
    / DO NOT ALTER any of the below Lines, Use BlueZX3's GUI Editor instead!
    "SetApps","SETVAR;AppToRun;MyApp01<<MyApp02<<MyApp03<<MyApp04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp32<<MyApp33<<MyApp34<<MyApp35<<MyApp36<<MyApp37<<MyApp38<<MyApp39<<MyApp40<<MyApp41<<MyApp42<<MyApp43<<MyApp44<<MyApp45<<MyApp46<<MyApp47<<MyApp48<<MyApp49<<MyApp50<<MyApp51<<MyApp52<<MyApp53<<MyApp54<<MyApp55<<MyApp56<<MyApp57<<MyApp58<<MyApp59<<MyApp60<<MyApp61<<MyApp62<<MyApp63<<MyApp64<<MyApp65<<MyApp66<<MyApp67<<MyApp68<<MyApp69<<MyApp70<<MyApp71<<MyApp72<<MyApp73<<MyApp74<<MyApp75<<MyApp76<<MyApp77<<MyApp78<<MyApp79<<MyApp80<<MyApp81"
    /----------------This is the label that is displayed on the Main Menu Buttons ----------------
    "SetAppLabels","SETVAR;ButtonLabel;=MUSIC<<=HD RADIO<<=VIDEO<<=DVD<<=XM RADIO<<=SIRIUS<<=PHONE<<=WEATHER<<=PICTURES<<=BROWSER<<=RREARTH <<=MAP POINT<<=STREETS & TRIPS<<=iGUIDANCE<<=GARMIN<<=CAMERA<<=TRAFFIC CAMS<<=UPD8<<=THEATERS<<=DIMMER<<=GAS PRICES<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed"
    / RR Command to execute when button is pressed
    "MyApp01","Audio"
    "MyApp02","RADIO"
    "MyApp03","CloseGamma||VIDEO"
    "MyApp04","DVD"
    "MyApp05","XM"
    "MyApp06","SIRIUS"
    "MyApp07","LOAD;freefone.skin;FreeFone;$skinpath$\FreeFone.EXE;FreeFone"
    "MyApp08","HOMEWEATHER"
    "MyApp09","LOAD;ImageViewer.skin||Run;$RRPATH$ImageViewer\ImageViewer.exe;ImageViewer||SETTOPMOST;ImageViewer;true"
    "MyApp10","WEB"
    "MyApp11","GE_START||GE_EMBED"
    "MyApp12","LOAD;Mappoint_GPS.skin;Mappoint;C:\Program Files\Microsoft Mappoint\Mappoint.exe;Mappoint"
    "MyApp13","LOAD;StreetsTrips.skin||RUN;C:\Program Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips"
    "MyApp14","RUN;$skinpath$CWiG.exe||GPS"
    "MyApp15","LOAD;GMPC.skin||RUN;$SKINPATH$ElcosMenu.exe|GMPCOL.skin||RUN;$garminpath$;!CDP"
    "MyApp16","LOAD;RRCam.skin;;$skinpath$\..\..\RRCam\RRCam.exe;RRCam.exe"
    "MyApp17","RRTC"
    "MyApp18","RRUPD8"
    "MyApp19","MOVIETIMES||FAVTHEATERS"
    "MyApp20","menu;dimmer.skin"
    "MyApp21","RRGas"
    "MyApp22",""
    "MyApp23",""
    "MyApp24",""
    "MyApp25",""
    "MyApp26",""
    "MyApp27",""
    "MyApp28",""
    "MyApp29",""
    "MyApp30",""
    "MyApp31",""
    "MyApp32",""
    "MyApp33",""
    "MyApp34",""
    "MyApp35",""
    "MyApp36",""
    "MyApp37",""
    "MyApp38",""
    "MyApp39",""
    "MyApp40",""
    "MyApp41",""
    "MyApp42",""
    "MyApp43",""
    "MyApp44",""
    "MyApp45",""
    "MyApp46",""
    "MyApp47",""
    "MyApp48",""
    "MyApp49",""
    "MyApp50",""
    "MyApp51",""
    "MyApp52",""
    "MyApp53",""
    "MyApp54",""
    "MyApp55",""
    "MyApp56",""
    "MyApp57",""
    "MyApp58",""
    "MyApp59",""
    "MyApp60",""
    "MyApp61",""
    "MyApp62",""
    "MyApp63",""
    "MyApp64",""
    "MyApp65",""
    "MyApp66",""
    "MyApp67",""
    "MyApp68",""
    "MyApp69",""
    "MyApp70",""
    "MyApp71",""
    "MyApp72",""
    "MyApp73",""
    "MyApp74",""
    "MyApp75",""
    "MyApp76",""
    "MyApp77",""
    "MyApp78",""
    "MyApp79",""
    "MyApp80",""
    "MyApp81",""
    / These are the labels for the application that will show
    / up on the screen that gives the selection of buttons to choose from
    "SetCommandLabels01","SETVAR;MyApp01LB;Music||SetCommandLabels02"
    "SetCommandLabels02","SETVAR;MyApp02LB;HD Radio||SetCommandLabels03"
    "SetCommandLabels03","SETVAR;MyApp03LB;Video||SetCommandLabels04"
    "SetCommandLabels04","SETVAR;MyApp04LB;DVD||SetCommandLabels05"
    "SetCommandLabels05","SETVAR;MyApp05LB;XM Radio||SetCommandLabels06"
    "SetCommandLabels06","SETVAR;MyApp06LB;Sirius||SetCommandLabels07"
    "SetCommandLabels07","SETVAR;MyApp07LB;Phone||SetCommandLabels08"
    "SetCommandLabels08","SETVAR;MyApp08LB;Weather||SetCommandLabels09"
    "SetCommandLabels09","SETVAR;MyApp09LB;Pictures||SetCommandLabels10"
    "SetCommandLabels10","SETVAR;MyApp10LB;Browser||SetCommandLabels11"
    "SetCommandLabels11","SETVAR;MyApp11LB;RREarth||SetCommandLabels12"
    "SetCommandLabels12","SETVAR;MyApp12LB;Map Point||SetCommandLabels13"
    "SetCommandLabels13","SETVAR;MyApp13LB;Streets & Trips||SetCommandLabels14"
    "SetCommandLabels14","SETVAR;MyApp14LB;iGuidance||SetCommandLabels15"
    "SetCommandLabels15","SETVAR;MyApp15LB;Garmin||SetCommandLabels16"
    "SetCommandLabels16","SETVAR;MyApp16LB;Camera||SetCommandLabels17"
    "SetCommandLabels17","SETVAR;MyApp17LB;Traffic Cams||SetCommandLabels18"
    "SetCommandLabels18","SETVAR;MyApp18LB;UPD8||SetCommandLabels19"
    "SetCommandLabels19","SETVAR;MyApp19LB;Movie Showtimes||SetCommandLabels20"
    "SetCommandLabels20","SETVAR;MyApp20LB;Dimmer||SetCommandLabels21"
    "SetCommandLabels21","SETVAR;MyApp21LB;Gas Prices||SetCommandLabels22"
    "SetCommandLabels22","SETVAR;MyApp22LB;<Unused>||SetCommandLabels23"
    "SetCommandLabels23","SETVAR;MyApp23LB;<Unused>||SetCommandLabels24"
    "SetCommandLabels24","SETVAR;MyApp24LB;<Unused>||SetCommandLabels25"
    "SetCommandLabels25","SETVAR;MyApp25LB;<Unused>||SetCommandLabels26"
    "SetCommandLabels26","SETVAR;MyApp26LB;<Unused>||SetCommandLabels27"
    "SetCommandLabels27","SETVAR;MyApp27LB;<Unused>||SetCommandLabels28"
    "SetCommandLabels28","SETVAR;MyApp28LB;<Unused>||SetCommandLabels29"
    "SetCommandLabels29","SETVAR;MyApp29LB;<Unused>||SetCommandLabels30"
    "SetCommandLabels30","SETVAR;MyApp30LB;<Unused>||SetCommandLabels31"
    "SetCommandLabels31","SETVAR;MyApp31LB;<Unused>||SetCommandLabels32"
    "SetCommandLabels32","SETVAR;MyApp32LB;<Unused>||SetCommandLabels33"
    "SetCommandLabels33","SETVAR;MyApp33LB;<Unused>||SetCommandLabels34"
    "SetCommandLabels34","SETVAR;MyApp34LB;<Unused>||SetCommandLabels35"
    "SetCommandLabels35","SETVAR;MyApp35LB;<Unused>||SetCommandLabels36"
    "SetCommandLabels36","SETVAR;MyApp36LB;<Unused>||SetCommandLabels37"
    "SetCommandLabels37","SETVAR;MyApp37LB;<Unused>||SetCommandLabels38"
    "SetCommandLabels38","SETVAR;MyApp38LB;<Unused>||SetCommandLabels39"
    "SetCommandLabels39","SETVAR;MyApp39LB;<Unused>||SetCommandLabels40"
    "SetCommandLabels40","SETVAR;MyApp40LB;<Unused>||SetCommandLabels41"
    "SetCommandLabels41","SETVAR;MyApp41LB;<Unused>||SetCommandLabels42"
    "SetCommandLabels42","SETVAR;MyApp42LB;<Unused>||SetCommandLabels43"
    "SetCommandLabels43","SETVAR;MyApp43LB;<Unused>||SetCommandLabels44"
    "SetCommandLabels44","SETVAR;MyApp44LB;<Unused>||SetCommandLabels45"
    "SetCommandLabels45","SETVAR;MyApp45LB;<UnUsed>||SetCommandLabels46"
    "SetCommandLabels46","SETVAR;MyApp46LB;<UnUsed>||SetCommandLabels47"
    "SetCommandLabels47","SETVAR;MyApp47LB;<UnUsed>||SetCommandLabels48"
    "SetCommandLabels48","SETVAR;MyApp48LB;<UnUsed>||SetCommandLabels49"
    "SetCommandLabels49","SETVAR;MyApp49LB;<UnUsed>||SetCommandLabels50"
    "SetCommandLabels50","SETVAR;MyApp50LB;<UnUsed>||SetCommandLabels51"
    "SetCommandLabels51","SETVAR;MyApp51LB;<UnUsed>||SetCommandLabels52"
    "SetCommandLabels52","SETVAR;MyApp52LB;<UnUsed>||SetCommandLabels53"
    "SetCommandLabels53","SETVAR;MyApp53LB;<UnUsed>||SetCommandLabels54"
    "SetCommandLabels54","SETVAR;MyApp54LB;<UnUsed>||SetCommandLabels55"
    "SetCommandLabels55","SETVAR;MyApp55LB;<UnUsed>||SetCommandLabels56"
    "SetCommandLabels56","SETVAR;MyApp56LB;<UnUsed>||SetCommandLabels57"
    "SetCommandLabels57","SETVAR;MyApp57LB;<UnUsed>||SetCommandLabels58"
    "SetCommandLabels58","SETVAR;MyApp58LB;<UnUsed>||SetCommandLabels59"
    "SetCommandLabels59","SETVAR;MyApp59LB;<UnUsed>||SetCommandLabels60"
    "SetCommandLabels60","SETVAR;MyApp60LB;<UnUsed>||SetCommandLabels61"
    "SetCommandLabels61","SETVAR;MyApp61LB;<UnUsed>||SetCommandLabels62"
    "SetCommandLabels62","SETVAR;MyApp62LB;<UnUsed>||SetCommandLabels63"
    "SetCommandLabels63","SETVAR;MyApp63LB;<UnUsed>||SetCommandLabels64"
    "SetCommandLabels64","SETVAR;MyApp64LB;<UnUsed>||SetCommandLabels65"
    "SetCommandLabels65","SETVAR;MyApp65LB;<UnUsed>||SetCommandLabels66"
    "SetCommandLabels66","SETVAR;MyApp66LB;<UnUsed>||SetCommandLabels67"
    "SetCommandLabels67","SETVAR;MyApp67LB;<UnUsed>||SetCommandLabels68"
    "SetCommandLabels68","SETVAR;MyApp68LB;<UnUsed>||SetCommandLabels69"
    "SetCommandLabels69","SETVAR;MyApp69LB;<UnUsed>||SetCommandLabels70"
    "SetCommandLabels70","SETVAR;MyApp70LB;<UnUsed>||SetCommandLabels71"
    "SetCommandLabels71","SETVAR;MyApp71LB;<UnUsed>||SetCommandLabels72"
    "SetCommandLabels72","SETVAR;MyApp72LB;<UnUsed>||SetCommandLabels73"
    "SetCommandLabels73","SETVAR;MyApp73LB;<UnUsed>||SetCommandLabels74"
    "SetCommandLabels74","SETVAR;MyApp74LB;<UnUsed>||SetCommandLabels75"
    "SetCommandLabels75","SETVAR;MyApp75LB;<UnUsed>||SetCommandLabels76"
    "SetCommandLabels76","SETVAR;MyApp76LB;<UnUsed>||SetCommandLabels77"
    "SetCommandLabels77","SETVAR;MyApp77LB;<UnUsed>||SetCommandLabels78"
    "SetCommandLabels78","SETVAR;MyApp78LB;<UnUsed>||SetCommandLabels79"
    "SetCommandLabels79","SETVAR;MyApp79LB;<UnUsed>||SetCommandLabels80"
    "SetCommandLabels80","SETVAR;MyApp80LB;<UnUsed>||SetCommandLabels81"
    "SetCommandLabels81","SETVAR;MyApp81LB;<UnUsed>||SetCommandLabels82"
    / This sets up the applications for when you press and HOLD a main
    / menu button
    / *******  DO NOT EDIT THE FOLLOWING 2 GROUPS!  *********
    "HOLDMAINBT1","SETVAR;CHANGEBUTTON;MAINBUTTON1||LOAD;APP_Chooser.skin"
    "HOLDMAINBT2","SETVAR;CHANGEBUTTON;MAINBUTTON2||LOAD;APP_Chooser.skin"
    "HOLDMAINBT3","SETVAR;CHANGEBUTTON;MAINBUTTON3||LOAD;APP_Chooser.skin"
    "HOLDMAINBT4","SETVAR;CHANGEBUTTON;MAINBUTTON4||LOAD;APP_Chooser.skin"
    "HOLDMAINBT5","SETVAR;CHANGEBUTTON;MAINBUTTON5||LOAD;APP_Chooser.skin"
    "HOLDMAINBT6","SETVAR;CHANGEBUTTON;MAINBUTTON6||LOAD;APP_Chooser.skin"
    "HOLDMAINBT7","SETVAR;CHANGEBUTTON;MAINBUTTON7||LOAD;APP_Chooser.skin"
    "HOLDMAINBT8","SETVAR;CHANGEBUTTON;MAINBUTTON8||LOAD;APP_Chooser.skin"
    "HOLDMAINBT9","SETVAR;CHANGEBUTTON;MAINBUTTON9||LOAD;APP_Chooser.skin"
    "HOLDMAINBT10","SETVAR;CHANGEBUTTON;MAINBUTTON10||LOAD;APP_Chooser.skin"
    "HOLDMAINBT11","SETVAR;CHANGEBUTTON;MAINBUTTON11||LOAD;APP_Chooser.skin"
    "HOLDMAINBT12","SETVAR;CHANGEBUTTON;MAINBUTTON12||LOAD;APP_Chooser.skin"
    "HOLDMAINBT13","SETVAR;CHANGEBUTTON;MAINBUTTON13||LOAD;APP_Chooser.skin"
    "HOLDMAINBT14","SETVAR;CHANGEBUTTON;MAINBUTTON14||LOAD;APP_Chooser.skin"
    "HOLDMAINBT15","SETVAR;CHANGEBUTTON;MAINBUTTON15||LOAD;APP_Chooser.skin"
    "HOLDMAINBT16","SETVAR;CHANGEBUTTON;MAINBUTTON16||LOAD;APP_Chooser.skin"
    /Create buttons from variables for use in the skin
    / on the 16 main menu buttons (8 x 2 menu screens)
    "SkinButton1","BYVAR;MAINBUTTON1;$AppToRun$”
    "SkinButton2","BYVAR;MAINBUTTON2;$AppToRun$”
    "SkinButton3","BYVAR;MAINBUTTON3;$AppToRun$”
    "SkinButton4","BYVAR;MAINBUTTON4;$AppToRun$”
    "SkinButton5","BYVAR;MAINBUTTON5;$AppToRun$”
    "SkinButton6","BYVAR;MAINBUTTON6;$AppToRun$”
    "SkinButton7","BYVAR;MAINBUTTON7;$AppToRun$”
    "SkinButton8","BYVAR;MAINBUTTON8;$AppToRun$”
    "SkinButton9","BYVAR;MAINBUTTON9;$AppToRun$”
    "SkinButton10","BYVAR;MAINBUTTON10;$AppToRun$”
    "SkinButton11","BYVAR;MAINBUTTON11;$AppToRun$”
    "SkinButton12","BYVAR;MAINBUTTON12;$AppToRun$”
    "SkinButton13","BYVAR;MAINBUTTON13;$AppToRun$”
    "SkinButton14","BYVAR;MAINBUTTON14;$AppToRun$”
    "SkinButton15","BYVAR;MAINBUTTON15;$AppToRun$”
    "SkinButton16","BYVAR;MAINBUTTON16;$AppToRun$”
    /-----------------  END Dynamic Menu Buttons --------------------
    This is the manual methode, but you can to use more easier Dfx4 Button Editor who run very well .
    Good Use
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 12:24 PM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 04:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
