Page 44 of 54 FirstFirst ... 3435363738394041424344454647484950515253 ... LastLast
Results 431 to 440 of 532
Thread: Needed: BETA Testers for Google Earth Plugin
  1. #431
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Only one line in red? Great!
    Thanks a lot.
  2. #432
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by RipplingHurst View Post
    Thanks a lot.
    There are 2 (TWO) changes -- search for MyApp11 and you'll see them in red.
    Ride Runner RR's Myspace
  3. #433
    Dec 2007
    Danville, CA
    You're correct, I saw the second one now.
    It worked fine, only I get no GPS signal now. But it embeded okay, I'll try to test the skin commands tomorrow or later this week.
    I'm installing it on Windows 7 now, so far RR runs okay, only all the skins have huge font size, they go beyond the buttons limits. It's my second install on Windows 7, and it also happened this time, must be some Windows 7 issue.
    That happens with Carwings also, but with your solution posted above, I see RREarth option in the pop up menu, click on it, it erases the previous button on the main Menu, but it remains blank. The button works, calls the RRearth plugin, embeds, etc.; but "RRearth" only appears on the pop up menu, not on the main menu screen. Is that a graphic file?
    The tilt option is not making much of a difference in real time, though. When I click on the screen, I was expecting a zoom/tilt menu to appear, isn't that so?
    Thanks again, lots of options to control RREarth with your skin, sounds interesting.
  4. #434
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    You must to install the font ArialGreek in your Windows 7 .
    Or you can to change in the RREARTH.SKIN file all ArialGreek words by the font name you like .
  5. #435
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Also, check that you have your fonts set to NORMAL DPI (or windows will scale the fonts).
    Regards to tilt/zoom -- those functions ONLY WORK WITH GPS signal. If you have no GPS or the GPS position is toggled OFF, the tilt/zoom will only work when you toggle it back ON -- basically, if GPS is OFF you have control of the view using the GE controls.
  6. #436
    Dec 2007
    Danville, CA
    I suppose Arial Greek is free around the web/came with Vista/XP?
    Thanks A LOT guys, I'll test that.
  7. #437
    May 2009
    Timisoara , Romania
    GE in LSX VOID?
    Hi guys
    I need some info with guino project , first it is integrable in LSX VOID skin or just for Carvings?
    Second if thet is posible, some info to how can I integrate in to lsx skin
    Ty
  8. #438
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by xanderx View Post
    Hi guys
    Ty
    Pretty sure LSX already has a GE screen - just make sure the GE version you're using matches the GE plugin version you're using.
    the Carwings files are posted on this thread - just download and update as per instructions on the thread.
  9. #439
    moahdib's Avatar
    Jul 2000
    Guino, can you post an updated RREarth.dll for GE v5?
    I don't see it in any of the posts above.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  10. #440
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Did you guys get anywhere with the GEv5? I'd like to give it a go
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-10-2005, 11:39 PM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 11:24 AM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 03:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 03:54 AM
