Page 45 of 54 FirstFirst ... 3536373839404142434445464748495051525354 LastLast
Results 441 to 450 of 532
Thread: Needed: BETA Testers for Google Earth Plugin
  1. #441
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The RREarth DLL for GE5 is here:
    http://guino.home.insightbb.com/RREarth.dll
    Please keep in mind GE5 complains a lot about running without an internet connection so all we can do is close the popups when they come up.
    Ride Runner RR's Myspace
  2. #442
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    This thing is great, and runs great in my car. It's a show, but what a show. I bought an external antenna for the 3G network just to use it better...
  3. #443
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Works Pretty good so far. I may need to skin something different from the standard LSXVoid skin for directions. Seems counter intuitive.
  4. #444
    Jan 2004
    California
    I noticed when not remote desktoping into my carpc that when it embedds into the LSXvoid Skin (havent tried any other skin) it wont take up the full amount of space allotted. Basically it won't stretch to fit.
    I am running 800x600 resolution on a 7" liliiput.
    Anyone have any ideas?
  5. #445
    Jan 2004
    California
    I am retarded... Running it at full screen outside of RideRunner did the trick.
    I have two other questions though.
    Is there a way to adjust the transparancy of the roads... It seems that certain zoom levels make the road overlay dissapear entirely.
    Also, When getting directions is there a way automatically populate the first address box with your current GPS coordinates?
  6. #446
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can make a button that fills in the variable (SETVAR) with "GPS Position" -- that basically makes the plugin use the current GPS position as your location for that box -- it works for BOTH the TO and FROM address boxes.
  7. #447
    Jan 2004
    California
    Quote Originally Posted by guino View Post
    awesome. Do you think you could be so kind and type out the an example. I am retarded when it comes to using variables
  8. #448
    Jan 2004
    California
    Can Someone post a screenshot of how Road Only Mode looks? I am playing with the skin but i cant notice any appriciable differnce when i choose roadmode
  9. #449
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by antimatter View Post
    Can you post a zip of what your .skin file has for the textboxes ? basically this would just be a SETVAR;MYVAR;GPS Position -- where MYVAR is whatever is used for display of the TO/FROM boxes.
  10. #450
    Jan 2004
    California
    It's the LSXVoid Skin
    "OSKTOVAR;GEBOX1"
    "OSKTOVAR;GEBOX2"
    Below i listed the entire skin.
    From what i can tell they arent text boxes but buttons.
    Basically the way that i want it to work is for the first text box or button (when i tap on it) it populates with current GPS position (instead of going directly to the OSK)
    For the Second Text box i will need to type an address so i do want it to go to the OSK like it usually does however as soon as i hit enter on the OSK the menu is gone and i have to click on the menu button again to bring it back so if i could avoid doing that I may actually use it navigation
    Thanks a million for you help
    Code:
    RoadRunner Skin
    ROADRUNNER GEMENU1 Skin
    /, INC, FILENAME
    INC,LSXCOLORS.txt
    /, V, Percent
    V,100
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,559,62,63,87,"GE_SETDARKNESS;0",
    B,83,18,159,76,"GE_GETDIRECTIONS;$GEBOX1$;$GEBOX2$",
    B,245,19,154,76,"GE_FULLTOUR",
    B,401,19,154,76,"GE_TURNTOUR",
    B,402,101,154,76,"GE_STOP",
    B,151,185,336,47,"OSKTOVAR;GEBOX1",
    B,151,241,336,47,"OSKTOVAR;GEBOX2",
    B,488,240,112,47,"OSKTOVAR;GEBOX2",
    B,42,241,109,47,"ESC||GE_FLYTO;$GEBOX2$",
    B,42,184,109,47,"ESC||GE_FLYTO;$GEBOX1$",
    B,487,185,114,47,"OSKTOVAR;GEBOX2",
    B,245,101,154,76,"GE_PLAY",
    B,83,101,158,76,"GE_SHOWROUTE",
    B,625,14,82,180,"GE_TOGGLEGPS",
    B,-2,-3,82,180,"ESC||GE_START",
    /, I, x, y, w, h, Code;INDICATORCODES
    I,563,10,57,47,"GE_SHOWGPS"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L,151,190,336,40,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=$GEBOX1$","CENTER"
    L,98,44,132,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=DIRECTIONS","CENTER"
    L,98,126,132,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=SEE ROUTE","CENTER"
    L,255,44,133,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=FULL TOUR","CENTER"
    L,255,126,133,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=PLAY","CENTER"
    L,412,44,133,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=TURN TOUR","CENTER"
    L,412,126,133,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=STOP","CENTER"
    L,488,194,123,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=CLEAR","CENTER"
    L,488,249,123,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=CLEAR","CENTER"
    L,28,249,123,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=FLY TO","CENTER"
    L,28,192,123,32,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=FLY TO","CENTER"
    L,151,248,336,40,#COL1WR#,#COL1WG#,#COL1WB#,14,"Arial Black:B","=$GEBOX2$","CENTER"
    END
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-10-2005, 11:39 PM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 11:24 AM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 03:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 03:54 AM
