Page 46 of 54 FirstFirst ... 36373839404142434445464748495051525354 LastLast
Results 451 to 460 of 532
Thread: Needed: BETA Testers for Google Earth Plugin
  1. #451
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I think I figured it out
    To reopen the menu after entering text with the OSK i used for the to and from fields
    "OSKTOCMD;GEBOX1;GEMENU1"
    "OSKTOCMD;GEBOX2;GEMENU1"
    To enter in to the first textbox/button (whatever LSXVoid has) the current GPS position i used
    "SETVAR;GEBOX1;GPS Position"
    Does this look right to you?
    I havent tested this in the car but it seems to work from my home computer though
  2. #452
    Jan 2004
    California
    I just tested these changes in the car and it works perfectly. Thanks for your help
    Now Guino can you tell me what these darkness controlls and the Day/Night/Road mode do. I can't get these commands to do anything.
    Am i missing something or is this a bug?
  3. #453
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Day mode is the standard mode.
    Night mode darkens the map so it's not so bright.
    Road mode shows only the roads (no satellite imagery) -- this only works for some zoom levels though.
    The Night/Road feature require a file "Black.jpg" in the folder of the plugin/.kml files to work.
    Ride Runner RR's Myspace
  4. #454
    Jan 2004
    California
    Quote Originally Posted by guino View Post
    I can see the value in the Road Only Mode because at certain zoom levels the roads completely dissapear. However when i enable road only mode it seems to do nothing eregardless of the zoom level.
    How should i troubleshoot this.
    BTW this plugin is the freekin bomb, it has brought a whole new life to the carpc
  5. #455
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by antimatter View Post
    Please verify you have these required files in the folder with RREarth.dll:
    GPS.kml.ini
    Mode.kml.ini
    NET.kml.ini
    Zooms.ini
    RoadZooms.ini
    If one of these files is missing, one feature or another may not work correctly. The Zoom while in Road Mode will follow the settings in RoadZooms.ini, when in standard mode it will follow the Zooms.ini. Black.jpg is used to put a "shade" on top of the satellite imagery when in Night mode. It is possible that changing some settings in GE (outside RR) may affect functionality of certain features. The Plugin was made to work using the default/standard settings that come configured in GE -- the only setting I recommend adjusting is the speed of the fly-to feature (so it goes faster and thus updates at faster intervals while driving).
    BTW this plugin is the freekin bomb, it has brough a whole new life to the carpc
    I know what you mean, that's an entirely different level of driving with that map moving on screen.
  6. #456
    Jan 2004
    California
    Hmm... all of those are there already, any other ideas?
  7. #457
    guino's Avatar
    Nov 2004
    Toronto, Canada
    What version of GE are you using ? I have to give it a try with the latest, but this could be related to your issue.
  8. #458
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    Hello,
    Does anyone know how to change the default tilt for Google Earth starts up with in RR. Im using the LSX Void skin, I'd like to change it so it starts with 0 degree tilt.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This should be in the txt file included with the plugin. I believe you can change the GE_START command to add a default tilt parameter. Let me know if you couldn't find it and/or which files you looked at..
  10. #460
    Nov 2006
    Hi Guino,
    I did find the text file which mentioned the GE_START command, but I'm not sure which file I should add the GE_START command too or is it already located in a file that I need to modify?
    Thanks again
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 12:24 PM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 04:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
