Page 49 of 54 FirstFirst ... 39404142434445464748495051525354 LastLast
Results 481 to 490 of 532
Thread: Needed: BETA Testers for Google Earth Plugin
  1. #481
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I fixed the issue
    adding "ESC","MENU;menu.SKIN" to the exectbl.ini
    and using the "ESC" command did the trick
    I still have issues with 4.2 when in road only mode where it still loads the satilite imagary
  2. #482
    May 2010
    Quote Originally Posted by pierrotm777 View Post
    Ok Guino,
    Thanks for your dll . I had created a skin for this plugin and GE5 is very well embedded .
    The menu run very well tilt + and - , gps on/off also .
    I think that my skin file is incomplete (button don't run)
    I upload my files here with probably bugs or error .
    I cannot get the GE embeded. Here is what I have done:
    1-Installed the last GE version.
    2- Installed Ride Runner.
    3- Copied the pierrotm777 skin inside the main Carwings_Dynamic_Lite folder.
    4- Edited the main Carwings_Dynamic_Lite skin with the Ride Runner editor and added a buttom, put command "LOAD;RREARTH.SKIN||GE_EMBED"
    5- Changed the exectbl.ini as you described, Myapp11.
    When I press the new buttom starts the skin by pierrotm777 but when press the options and GE starts doesn´t start embeded, it starts normally.
    My XP is spanish, so my folder is not c:/program files/ is c:/archivos de programa
    Do I need to change anything? Create some googleearth.ini or something? What may be wrong?
  3. #483
    May 2010
    Hell, tried the .dll you posted for G5 and it works. Why did you not post in the first post?
    Have two questions:
    1- If the original skin is 800x600 can´t be modified? If my laptop has 1280x756 resolution I must look for a skin for that?
    2- Is there any way to change te position icon? I mean, by default, the position is on the center on the screen, when using a more horizontal angle, you see with more detail in the back. It would be better (like typical gps) to have the 80% for the screen to see de destiny and only 20% to see backwards. Can´t this be changed anyway?
    Thanks a lot fot the skins.
  4. #484
    Jan 2004
    California
    Did you make sure that
    X,RREARTH is added to menu.skin file
    I know that this plugin is a bit finnicky. I ended up going back to version 4.2 of google earth to get everything to work as it should since i do use it so much
  5. #485
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have just tested the new Google Earth 5.2 version .
    The plugin is no compatible with this 5.2 version .
    Google Earth is launched but the screen stay black !
  6. #486
    May 2008
    Bordeaux, France
    Smile
    Ok,
    After to reset my computer, now the plugin run well with GE 5.2, but after 2 minutes, the computer freeze and i must to use the reset button !
    It's a GE issue or a plugin issue ?
    Any idea is welcome
  7. #487
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok,
    Any idea is welcome
    when the computer freezes: can you use CTRL+ALT+DEL to start task manager and kill GE/RR ?? If you can NOT do that, then this is a HARDWARE/DRIVER issue, not a software issue (not GE/RR at least).
    Ride Runner RR's Myspace
  8. #488
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I tried Google Earth 5.2 just my curiosity, and only a black screen appears with a plugin. Task manager shows RR cpu utilization is 50% with dual core.
  9. #489
    May 2008
    Bordeaux, France
    Quote Originally Posted by Dartman_71 View Post
    if you restart RR , the plugin run well but RR freeze after one minute
  10. #490
    Jul 2010
    Bodř¸, Norway, Norway
    Trying to make this work in the default carwings skin and can't seem to get it to work.
    Using GE 5.0
    -Unzip the package wherever you'd like to run it from (unzipped to riderunner/plugins folder)
    -Register RREarth.dll (regsvr32 rrearth.dll) (done as administrator because of W7)
    -Add to menu.skin ONLY: X,RREarth (added to the .skin file)
    -Copy the files under the "Test skin" folder to your skin of choice (done, to carwings)
    -Make a button with the code "GE_START" to load the above skin with GE in it. (added button "GE_START||GE_EMBED")
    It loads RREarth.skin but I just get a black screen.
    If GE is closed it wont try to open it, and if its open it wont embed.
    Any ideas to what I could have done wrong?
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 12:24 PM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 04:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
