Page 7 of 53 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 528
Thread: Needed: BETA Testers for Google Earth Plugin
  1. #61
    Sep 2006
    Similar Issue
    I have a similar issue, installed per instructions. When I activate skin it comes up blank, if I exit back to main RR skin then reactivate I get GE maximized over the skin. Alt-Tab will put the skin over GE, but GE is not visible. Works good except that I cannot use the skin interface and I have to do the activate/deactivate trick to get it to come up.
    I am using GE Plus which may have something to do with it. For the life of me I cannot get it back to GE Standard...
    Would a video of the GE initialization process help to debug it? I get several popups about logging in, etc... I also seem to get one that says your kml will load once GE login is complete, that requires an ok to continue.
    thanks,
    Chip
  2. #62
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Guino,
    I've tried several skins/setups, same outcome. Seeing a few here having similar problems, I wonder if it is GE Plus being installed as I have that since I had Plus before this and upgraded to version 4beta. Since Plus shows "GoogleEarth Plus" in the application window when task manager is opened.
    I tried to uninstall plus clean it and then do the free version of 4beta but the install just sees the previous plus version and installs back to there.
  3. #63
    Sep 2006
    Red face Reverting to "Free" Version
    I sent an email to google on how to switch back, they didn't respond with a message, but sent me an email saying that a refund had been processed. When I logged back in it asked if I wanted to resubscribe or switch to the free version...
    Quino, is it possible the RREarth.exe is still not the right one, I downloaded today and can't get it to do anything... Unfortunately I overwrote the version from a couple of days ago so it may just be something else dumb I did...
    Great work by the way!
    My wife was riding with me yesterday and said something was wrong because there was a lot more traffic around us than the screen showed...
  4. #64
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    What the hell ? it shows Google Earth Plus on the taskbar -- if so, that's the problem right there -- I did not build any support to search for possible matches when embedding it... can anyone (with plus) pull up the exact window title and class name using WinsPectorSpy ? Then I can add support for it.
    Ride Runner RR's Myspace
  5. #65
    FLAC djmickyg's Avatar
    Feb 2004
    i got no idea how to get this dam thing to run..
    ive dont everything im ment to
    adding theline to the menu skin, adding the line to a button, running the exe once.. instaling GE4.
    .. but i get nothing
  6. #66
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    me too..i ve done everything..the skin won't even load
  7. #67
    May 2006
    mee too, only the last version... the previous worked good.
  8. #68
    Apr 2006
    Greece
    does the rrearth.skin loads in your case?
  9. #69
    May 2006
    nothing happened.
  10. #70
    Oct 2005
    Arkansas
    guino,
    I'll run WinsPectorSpy later today and upload the results..
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 12:24 PM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 04:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
