Page 13 of 23 FirstFirst ... 345678910111213141516171819202122 ... LastLast
Results 121 to 130 of 221
Thread: Velleman K8055 USB I/O Board Extension plugin
  1. #121
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Here you go mate, let us know if it works OK.
    http://www.wrx-carpc.co.uk/downloads/K8055D.zip
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  2. #122
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    thanks, put it in the rr dir andx tried to register it but it said it wasnt a valid dll or ocx, is there a oxc to go with it? or it is corrupt.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
  3. #123
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    You dont need to register the DLL because the functions are called directly from the RRK8055.DLL. Just need to be able to find the DLL in the search path. So placing it in the RR directory of windows\system32 should do.
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  4. #124
    Apr 2005
    UK
    OK, ive copied the new one to the system32 dir but its still not working, could you post your k8055d as im not sure the one that tissy posted unzipped ok.
    Type-R Mini
  5. #125
    Nov 2006
    Romania
    dll
    here is the one i have in my RR folder and the one in Veleman demo folder . hope that it helps...
    Attached Files Attached Files
    My second Subaru skin
    Full screenshots second skin
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  6. #126
    Apr 2005
    UK
    that worked, thanks a lot
    Type-R Mini
  7. #127
    Nov 2006
    Romania
    Now i feel better. Thanks to 307SW_NLD not to me...
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  8. #128
    Apr 2005
    UK
    think the anlog inputs on my board are shot if i connect one or two to the analog ground nothing changes, ive set it the pot on 1 to 3.5 volts and it doesnt change.
    it is just me being dumb or does it sound like my board has had it? it was a b grade on maplins so may have just found out why, although they never said it was faulty on the site, presumed it was just a return.
    Type-R Mini
  9. #129
    Apr 2005
    The Netherlands
    The potmeter only works if you install jumper SK2 and SK3. This will let you regulate the analog in 1 & 2 between 0 and 5 volts
    Connecting A1 and/or A2 to analog groud should give a zero reading.
    NEVER supply more the 5 volts to the analog in
  10. #130
    Apr 2005
    UK
    yeah i have the sk2 & 3 jumpers in place and set it so it reads at 3.5V, then connect 1 to ground, should that not read 5V? the reading doesn't change, stays at 3.5V, tried it with 2 as well and its the same.
    haven't tried it with an external input so will try removing the jumper and use a battery
    Type-R Mini
  1. Replies: 10
    Last Post: 08-22-2008, 06:36 PM
  2. i think i burn my USB controller board
    By susuking in forum LCD/Display
    Last Post: 01-26-2006, 12:55 PM
  3. USB Control Board component burned
    By carfreak01 in forum LCD/Display
    Last Post: 08-24-2005, 03:43 PM
  4. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
