Page 14 of 23 FirstFirst ... 4567891011121314151617181920212223 LastLast
Results 131 to 140 of 221
Thread: Velleman K8055 USB I/O Board Extension plugin
  1. #131
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    No, when both jumpers are set you can change the readout between 0 and 5 volts using the potmeter. If the jumpers are removed it will measure the voltage between analog in (1 or 2) and analog ground. So the jumpers are just there to test the analog in without supplying voltage to the analog inputs
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  2. #132
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    Oh OK so even with the jumpers on and pot set so its showing 3.5, when i connect 1 to ground it wont change.
    also, what is 'clamp' for on the outputs?
    Thanks for all your help
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
  3. #133
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Anyone using this board with standby, and if so, are there any resume probs?
    Kinda got me thinking about getting one of these, but I only use standby/resume, not hib...
    Thanks for any info!
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #134
    Apr 2005
    UK
    ok is this possible, ive got illumination hooked into analog 5, at the moment ive got it on press that it changes gama, the problem is that it doesnt trigger gamma again when you turn the lights off, ive tried it with long and switch, what should i have it on so that it triggers the event when it goes live and when it goes dead?
    going a bit further, is it possible to set gamma to dark when live and bright when dead, instead of toggling in case its already dimmed and then i put the lights on it would go bright.
    Type-R Mini
  5. #135
    Apr 2005
    UK
    ok i was being dumb, i set the wrong one to switch, set 5 as switch and it works ok, is it possible to say switchon=NIGHTGAMMA and switchoff=DAYGAMMA (the day and night gamma are RR existing commands)
    realy should of read the documentation lol got it working now, the problem is it will only work in the realys skin,not the menu, the DEAFULT & menu.skin section both have the same content and i havent changed anything else other than making Analog 5 a switch, any ideas?
    Edit: Now working fine, i had the 2.1.0.0 dll, downloaded the 2.1.0.3 and registered it, works great thanks for such a great plugin.
    Type-R Mini
  6. #136
    Nov 2006
    Romania
    Back again with a question for the plugin:
    i want to use one "analog-in" to measure and display weight. Any ideea what should i use for the sensor? Or how can i display how comprimated my suspensions are... Should i make it optical based, because seems to be the most reliable, having a optocoupler installed under the feather or similar idea ?
    P.S. i read somewhere that are actually "pressure" sensors available..
  7. #137
    lambosprit's Avatar
    Sep 2006
    UK
    Hi all, Firstly I like to say thanks for all the hard work you've put into this plugin. I have my board all built and now I'm testing but cant get it to work.
    The test program works fine but the test screen doesn't. I get the indicators but all zero.
    I'm running the k8055d.dll from this thread. I have 2.1.06 version of the plugin and road runner is on latest version. I have registered the RRK8055.dll in road runner directory and have the K8055.dll in road runner directory as well.
    Is there an indicator that tells me I'm connected to the board? Any other ideas?
    attaching my debug log in case this helps
    thanks in advance
    Attached Files Attached Files
  8. #138
    Nov 2006
    Romania
    if you have registered the rrk8055.dll using the regsvr32.exe it is near to impossible not to work...very strange. You have had the succesfull registration message?
    i had my XP reinstalled 2 days ago, therefore 5 min ago i have also reinstalled the k8055 (just demo mode on the CD) then registered the DLL from here in the RR folder, pluged the board and everything works great...
    be sure that your relays.skin to have the X,RRK8055 part, meaning like this:
    MEDIACAR Skin
    MEDIACAR MainMenu Skin
    X,RRK8055
    /, I, x, y, w, h, Code;INDICATORCODES
    etc...
    etc...
    etc..
    etc...
    My second Subaru skin
    Full screenshots second skin
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  9. #139
    Nov 2006
    Romania
    Some info for K8055 users...
    If the board is not connected, every skin that has X,RRK8055 (to load the plugin for the board) overload the CPU to 98-99%. Forever, even if you leave the skin to enter one without X,RRK8055. This is happening on a P4-3,6GHz machine. If the board is connected, even with the music playing, the CPU stays on 6-8% maximum. I think this is a weakness, if for no matter what reasons the plugin fails to find the board, the RR is doomed.
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  10. #140
    Apr 2005
    The Netherlands
    @mugurg,
    Never noticed it but you are right. It must be in my code. I'll check to see if I can fix that.
  1. Replies: 10
    Last Post: 08-22-2008, 06:36 PM
  2. i think i burn my USB controller board
    By susuking in forum LCD/Display
    Last Post: 01-26-2006, 12:55 PM
  3. USB Control Board component burned
    By carfreak01 in forum LCD/Display
    Last Post: 08-24-2005, 03:43 PM
  4. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
