Page 16 of 23 FirstFirst ... 67891011121314151617181920212223 LastLast
Results 151 to 160 of 225
Thread: Velleman K8055 USB I/O Board Extension plugin
  1. #151
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Quote Originally Posted by mugurg View Post
    I have registered the new DLL , and tried with both my skin files and the one attached. I can't get it to work at all. Using back my previous DLL/INI files everything works perfect. Where should i see the new indicator to click on it? the one "invisible" named k8055_menu is doing nothing when i am pressing it. What i am doing wrong?
    Sorry to hear this. I checked this on a fresh machine without installing the K8055 software. Only placed k8055d.dll, rrk8055.dll and the rrk8055.ini in the road runner directory. Starting with an older version of my rrk8055d.dll it worked after registring the rrk8055.dll. Replace the dll with the new version and it did not work!! Did and regsvr32 rrk8055.dll /U and a regsvr32 rrk8055.dll and it worked. Please could you try the same thing. Please redownload the latest version as I have my K8055d.dll included in there.
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  2. #152
    Nov 2006
    Romania
    Will do now.
    Later edit: downloaded the last version.
    Unregistered the DLL first then placed the files in the RR folder and registered the files you sent. Got the confirmation of unregistering and registering as succeded...
    Nothing.. the board displays 0 (zero) on the indicators and that is all.
    RE-done all steps again. Still nothing...using also your SKIN file not mine.
    BTW, of course the board works perfect with its own software...and with the previous DLL version.
    My second Subaru skin
    Full screenshots second skin
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  3. #153
    Apr 2005
    The Netherlands
    Will do now.
    Could you please try this one? If took out a few changes that might have caused problems in your case. Need to now what language version of windows you are using and how you date/time format looks like.
    Attached Files Attached Files
  4. #154
    Nov 2006
    Romania
    hi
    Win XP Pro, SP2
    Time/date: Friday, February 02, 2007
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  5. #155
    lambosprit's Avatar
    Sep 2006
    UK
    hi 307
    tried the new dll but its still not working for me. I tried to unregister my previous version of k8055d.dll and I get a "K8055d.dll was loaded, but the dllunregisterserver entry point was not found. File cannot be unregistered" message. Got something similar when I tried to register it afterwards.
    My own app still works fine and controls the board no problem. Any ideas?
    thanks
  6. #156
    Apr 2005
    The Netherlands
    Quote Originally Posted by lambosprit View Post
    hi 307
    thanks
    You can't register the k8055d.dll. You'll have to register the rrk8055.dll. Please have the k8055d.dll in the same dir as the rrk8055.dll (c:\Program Files\Road Runner)
  7. #157
    lambosprit's Avatar
    Sep 2006
    UK
    ok. I've run out of things to check now. Just cant seem to get it to work. I have the rrk8055 dll registered and the k8055 dll in my rr directory. I've added the indicator to my skin but nothing appears. Using the test program supplied with the board everything works.
    Thanks for your help but I'm lost now
  8. #158
    Apr 2005
    The Netherlands
    Sorry to hear this. I don't know what is going on here. I'm building some debug code in my plugin to see if it's even called. If it's not called I can understand it has problems. If it's being called I will write some messages in a debug file what the results are of the initialization of the board. Can you in the mean time send me your debug.txt from the roadrunner directory. (please delete the current and restart road runner and open your screen with the k8055 controls.) If debuging is not on you can enable it in the RRconfig utility.
  9. #159
    lambosprit's Avatar
    Sep 2006
    UK
    Thanks for putting in the time to help its greatly appreciated because I really want this to work. If I can test the new debug messages for you I will. Heres my debug. I can see an sdk message calling the dll but nothing else
  10. #160
    Apr 2005
    The Netherlands
    The RRSCREEN call you saw in the debug.txt means that RR has successfully loaded rrk8055.dll. So it has problems initializing the board itself. Will see what I can do with debug messages.
  1. Replies: 10
    Last Post: 08-22-2008, 05:36 PM
  2. i think i burn my USB controller board
    By susuking in forum LCD/Display
    Last Post: 01-26-2006, 11:55 AM
  3. USB Control Board component burned
    By carfreak01 in forum LCD/Display
    Last Post: 08-24-2005, 02:43 PM
  4. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 04:09 PM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
