Page 17 of 23 FirstFirst ... 7891011121314151617181920212223 LastLast
Results 161 to 170 of 225
Thread: Velleman K8055 USB I/O Board Extension plugin
  1. #161
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    OK,
    For the people having troubles to get the plugin to work please use the attached dll. This dll will create a k8055debug.txt with some debug info. Please let me know the results.
    Attached Files Attached Files
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  2. #162
    lambosprit's Avatar
    Sep 2006
    UK
    here's my debug log. Hope it helps. Just in case I de-registered and re-registered the dll. Had trouble finding the k8055debug file. It was in the road runner gamma folder for some reason
  3. #163
    Apr 2005
    The Netherlands
    Quote Originally Posted by lambosprit View Post
    This is indeed strange. I'm writing the debug file in the same location as I'm expecting the rrk8055.ini. Can you copy the k8055d.dll and the rrk8055.dll and the rrk8055.ini to this directory and try again?
  4. #164
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    thanks for this brilliant plugin, only problem i have it it is that i have to load the relays skin before it will work, i have moved the X,RRK8055 from the relay skin to the menu skin but i still have to load the relays skin before it will work.
    Any ideas?
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
  5. #165
    lambosprit's Avatar
    Sep 2006
    UK
    Hurray. Success. If I put the files in my gamma folder everything works perfectly. Now why does it look in the gamma folder. I have checked my rr config and all seems ok. I haven't actually set the ini file path on rr config, could this be it?
  6. #166
    Apr 2005
    The Netherlands
    Since I don't want to use a fixed path but use the one Road Runner is using this could be it. When the plugin loads it is using the current directory of the road runner process. If this has been set to the gamma folder for some reason (maybe your are using gamma functionality in your skin) the plug in will load from there. I can set a working directory in the rrk8055.ini but still the rrk8055.ini will have to be in the current dir or I can move it to the windows\system32 dir (which I don't like)
    I'm happy it now works for you.
  7. #167
    Apr 2005
    The Netherlands
    Quote Originally Posted by dan__wright View Post
    Any ideas?
    What are you using on the first screen? If you're only loading the plugin and want to use the menu functionality try putting one off the digital-in indicators on the first screen. This will in fact initialize the board for you. Loading the DLL will not initialize the hardware. The first access to one of the k8055 objects will.
  8. #168
    Apr 2005
    UK
    Quote Originally Posted by 307SW_NLD View Post
    ah ok guessed it may have been something like that, im rubbish when t comes to skinning, can you tell me what line i need from the relays skin that will show Digital 4?
    Type-R Mini
  9. #169
    Apr 2005
    The Netherlands
    I,391,13,43,40,"k8055_di_bit_4" should do the trick (4 is fourth bit counting from 1, last bit is 5)
  10. #170
    Constant Bitrate Volsfan's Avatar
    Jan 2006
    Kingsport, TN
    Got my board all put together and the demo seems to run just fine.
    regged the dll inside RR however the only thing that seems to work inside the
    road runner skin are the counters. I can press the buttons and the numbers change, but there is no levels on the sliders.
    Attached is my debug
    Tennessee Vols Fan
  1. Replies: 10
    Last Post: 08-22-2008, 05:36 PM
  2. i think i burn my USB controller board
    By susuking in forum LCD/Display
    Last Post: 01-26-2006, 11:55 AM
  3. USB Control Board component burned
    By carfreak01 in forum LCD/Display
    Last Post: 08-24-2005, 02:43 PM
  4. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 04:09 PM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
