Page 2 of 23 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 221
Thread: Velleman K8055 USB I/O Board Extension plugin
  1. #11
    Newbie The_Rocket's Avatar
    Sep 2006
    Norway
    Nice work.
    Haven't tested the plugin yet but seeing you have allready made the 2 wire option in (steering wheel) working I now have most off my setup in order.
    Suggestion:
    Wouldn't it be quite easy to use one or both the analogue port as temperature sensors. The LM35 would be a nice choice but if opamp is needed I don't know.
    Found this article in Elektor.
    Opamps the 0-1V range to go to 0 - 5V.
    2000 Ford Focus - Worklog
  2. #12
    Sep 2006
    Norway
    Tried testing the plugin but ended up with the following 2 errors.
    The .dll is registered with regserv and the skin commands added.
  3. #13
    Sep 2006
    Norway
    Fixed!
    Just moved the k8055d.dll to the roadrunner folder.
  4. #14
    Aug 2005
    Athens,Greece
    Hello, just fixed my carpc and started experementing with K8055 and this plugin..
    I was wondering, can this plugin execute a command on button press and another when this button is depressed?
    What I'm thinking to do is wire my 12v reverse through a relay to a digital input of the board. When it is triggered I'll have a MUTE command but when it is released is there a way to issue a MUTE command again?
    The same goes for the car's doors.. Mute when open, unmute when closed...
  5. #15
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Excellent plug-in, i actually bought the K8055 board after seeing this.
    Everything on the skin loads OK etc, but the skin buttons don't seem to activate the board, well the LEDs on the board don't light when the skin button is pressed.
    I have the rrk8055.dll and .ini in the RR directory with the k8055d.dll in the system32 directory with both DLLs registered.
    I'm running version 08/10/06 (latest) of RR, is this the right version or do i have to use the beta version?
    Any ideas?
    Many thanks.
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  6. #16
    Aug 2005
    Athens,Greece
    Quote Originally Posted by Tissy View Post
    If I recall correct, it does need of the latest beta...
    Why have you registered it twice? Use regsvr32 -u rrk8055.dll to unregister it, delete the copy in system32 and register again the one in the RR dir... Should work that way... Btw have you checked that the kit number is 0 (shorted SK5,SK6) ?
  7. #17
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    I have one of these K8055's sitting around somewhere. How would I go about performing a different command based on an analog input value?
    I want to use it for steering wheel buttons on a 2-wire resistive circuit. Would I have to connect one wire to the A1 and the other to GND, are any voltages required or is this handled by the K8055?
    Jarrod - Holden VX S!
  8. #18
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    You will need to put one wire to the analog in (channel 2) and the other wire to a voltage that makes the voltage on the analog in between o and 5 volts depending on the button pressed. You could use a 5volt source but probably a 12 volt source with an additional resistor will do the trick aswell. The ground has to be the ground of the power source you supplied to the second wire. Can make a drawing if you wish.
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  9. #19
    Apr 2005
    The Netherlands
    Any ideas?
    Many thanks.
    Steve
    You will need the latest beta for the indicator click functionality and the sliders for the analog in and outputs. The skin will not give you an error if the board was not found. Please check the jumpers on you board. By default is board address 0 (both jumpers placed). Check if the RRK8055.DLL and the k8055d.dll are in the roadrunner dir and register them using regsvr32.exe <dllname>
    Hope this helps
  10. #20
    Apr 2005
    The Netherlands
    Quote Originally Posted by gaslan View Post
    Cool idea. Will add it to the functionality. Be patient...
  1. Replies: 10
    Last Post: 08-22-2008, 06:36 PM
  2. i think i burn my USB controller board
    By susuking in forum LCD/Display
    Last Post: 01-26-2006, 12:55 PM
  3. USB Control Board component burned
    By carfreak01 in forum LCD/Display
    Last Post: 08-24-2005, 03:43 PM
  4. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
